Question about GE 25932 Twin Cordless Phone
Problem with charging
My phone does not show any sign of charging.There is no display when i connect to the electric plug
If your charger is ok check fuse its 100k
Posted on Mar 09, 2008
  • KANUNGU KANUNGU Mar 09, 2008
    so if da fuse is ok and diod next in bbb5,dct4 4nes mainly its power ic.
    U ARE VERY HELPFULY
I dropped my phone in water and i got it out i dryed it with a towel i woke up the next day and plugged it in to charge it and it and it shows the verizon sign and then breifly shows the battery charging...
the best option is to give it for a service they will dry in with a methyl solution to make it work !! if its salt water thats the end of your phone!!
Jun 13, 2011 | Cell Phones
Just got a HTC incredible s and i plugged it in to charge and the phone shows no signs of charging. help!!!!!
I would take the USB cord and plug it into your computer and charge it that way. There has been some trouble with the wall charges coming with phone not working. If it still won't charge, its time to take it back to were you got it. Good Luck!
May 17, 2011 | HTC Wildfire Cell Phone
Does not work, we tired a new battery, but no help.
Instructions
    Technical Difficulties
  1. If the phone doesn't turn on, make sure battery is charged and fully plugged into phone. Remove battery from phone and use rag to brush away dirt that may interfere with connection. Reconnect and try again. If using cigarette-lighter adapter, make sure it's properly plugged in. Make sure charger is properly plugged into outlet and into battery.
  2. When the battery doesn't charge, plug lamp or other electrical device into outlet to verify that outlet works. Borrow friend's charger to see if charger or battery is problem. Replace charger or battery if necessary.
  3. In case the phone gets wet, remove the battery from the phone and allow both to dry thoroughly. If rust or corrosion develops, wipe it off with a stiff brush. If phone still does not work, replace it.
  4. Should the display not be working, try getting it to room temperature, extremely cold or warm conditions may affect display functions.
  5. If the keys don't work, look for a display of a symbol that looks like a lock. The keypad may be locked. The display often tells you how to unlock it. If not, check owner's manual.
Jan 24, 2011 | Lands Phones
Hi i bought a nokia n97 almost a month ago,and one time i went to bed and left it to charge and woke up with the charger not working. ive been told its an electrical problem so i changed the charger,now...
In the manual with my Nokia 5230 Nokia says that when the indicator gives a sign about the unit being fully charged one is supposed first to take charger connected to the phone first and then the plug from the electricity. Take another look at the manual of your phone and checkonthe information on charging
Jun 13, 2010 | Nokia N97 Cell Phone
I plugged the BB on the charge 4 an hour!now it cant turn on
hello.
The solution to your phone problem is this, fix up your battery back to your phone then plunge back your phone to AC (electric) then allow the phone to booth up the phone will show sign of charging after this unplugged the phone then turn it ON you will be able to make use of your phone.
Thanks for using fixya.
Good luck.
Mar 16, 2010 | RIM BlackBerry Curve 8520 Smartphone
I tried to charge my Lg Ke970 today and it wasn't charging normally when I plug the charger in and connect it to my mobile it comes up with a battery sign but this time it kept on coming on and off and...
Hello, my friend had the same problem with his LG. He talked with the dealer who told him the battery was "dead". They had to "push" some electrical-shock into the battery, then it worked and the battery charged normally again=). Talk with the phone's dealer for help=) Good Luck! Regards, David.
Jul 08, 2009 | LG Shine KE970 Cellular Phone
New phone won't turn on just has "Hellomoto" screen
hi.there...don't worry.. what happens with your new cellphone..is normal..why? when your battery is low and there a pop up screen at the display "battery low...please recharge" that's mean you must charge the battery soon.
when connect your phone to charger adapter and your battery is very low / weak condition the display only showing "hellomotto" and nothing else. but it's normal! diplay need more power from you battery to showing all information.after the battery reach the minimum power to display it ( usually after 15-20' charging) try to push red bottom at your keypad phone and the display will showing again..good luck..
Feb 02, 2009 | Motorola Mobility RAZR V3
Charging
sounds faulty to me, id return it for a new one if i were you. but before you do try updating it, might be a firmware problem. if your unsure how to do that. just go here and install the program.
Nov 05, 2008 | SanDisk Sansa e260 MP3 Player
W810i doesnt turn on or connect via usb
Charge the phone until it has finished charging, The first thing to do is to make sure that the phone is charged. Attach the charger and charge the phone for about 2.5 hours. Please note that the battery icon may not appear until after the phone has charged for 30 minutes. When the battery icon has stopped “flashing” the phone is fully charged.
Jan 17, 2008 | Sony Ericsson Walkman W810i Cellular Phone
GE 25932 Twin Cordless Phone Logo
60 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
