Question about Canon CanoScan 8400F Film Scanner
Not scanning My Canoscan 8400F quits scanning after scanning several slides. I have made about 400 slide scans mad e already. I did the following: Checked for virus, spywire and registry errors. Used another Usb cable. Reinstalled the driver. Cleaned up the HDD. I have AMD 2600 computer with 4 Usb ports. Have a Epox nvidia nforce 2 motherboard. I have 3 of Usb ports being used with: (1)Printer (2)Webcam (3)scanner
  • 490 Answers
You have tried everything possible!. Try and reinstall the OS. If some dll files are corrupted, this will resolve it. You may have to reinstall all other software!
S. Mohan
Posted on Mar 09, 2008
Canon 8400F will not scan, error code 5, 155, 45
If it passes 'test' from the computer, then it should be listed in the Device Manager. Uninstall / Remove that device, then Restart and Re-install it.
Tallon41
Aug 22, 2012 | Canon CanoScan 8400F Film Scanner
I have a Canon 8400F film printer/scanner
'Tain't necessary. And not getting the part can be an improvement.
I cut out a cardboard template that allows me to scan 10 slides rather than the 4 of Canon's official slide adapter.
All the Canon part does is position them precisely so cropping and rotation are automatic. With Photoshop skills (File ' Automate), you can do the same yourself for whatever size. I ended up doing Brownie, 35, and 126 (gasp!) also.
For extra credit, make your adapter(s) out of genuine plastic rather than whatever cereal box you have lying around.
Jul 06, 2012 | Canon CanoScan 8400F Film Scanner
Canon 8400f suddenly will not allow neg scan option
just had the same problem, check the connection going into the top part of the scanner at the back and restart which ever program your using... got mine sorted
May 20, 2009 | Canon CanoScan 8400F Flatbed Scanner
The light on the lid, for scanning negatives won't move
You will most likely find that the FAU cable that connects the lift up lid part to the lower part of the scanner has at least one fractured wire within it. There are eight quite fine wires and the constant opening and closing of the lid has caused this to occur. Unless you have some micro-surgery skills and a small soldering iron it's off to the scanner shop, I'm afraid.
Mar 17, 2009 | Canon CanoScan 8400F Film Scanner
Cant scan slides
Make sure the lead from the lid is plugged in properly to back of scanner. I had the same problem and this fixed mine.
Nov 14, 2008 | Canon CanoScan 8400F Flatbed Scanner
Cannot scan film and slides
Check the cable that connects to the lid of the scanner. If it is disconnected, you won't get the Film options.
Jan 21, 2008 | Canon CanoScan 8600F Flatbed Scanner
Unwanted cropping of some 35mm slides using CanoScan 8400F
Turn off the thumbnails view and you can manually set the cropping box.
Nov 29, 2007 | Canon CanoScan 8400F Film Scanner
Selection menu doesn't give "color positive slide"
Check the cable connection to the lid of the scanner. If this is loose, then you will only get the "Platen" option in the drop down menu.
Nov 23, 2007 | Canon CanoScan 8400F Flatbed Scanner
Canon CanoScan 8400F Film Scanner Logo
140 people viewed this question
old marine
old marine
