Question about Kitchen Ranges
The oven door is locked shut. can't open. - Kitchen Ranges
  • 2 more comments
  • gfphome Mar 09, 2008
    this is an electric viking oven with gas burners on top...not a microwave
    please be clearer.
    what does "check for the temperature of the door's heat" mean? what ring surrounding what?
    bad circuts where? in oven or at breaker panel?
    it has been stuck for 2 weeks so it must be disassembled????
    thanks
    Brigadier General:
  • Kitchen Ranges Master
  • 3,614 Answers
Try these few steps:
Step 1:
Inspect plastic coupling beneath tray.
Step 2:
Check ring and roller assembly for misalignment or debris.
Step 3:
Make sure that tray is sitting properly on turning mechanism.
Step 4:
If carousel motor is broken, contact a service technician.
Posted on Mar 09, 2008
    Guru:
  • 1,894 Answers
Hello sir
  • 2 more comments
  • dewan nafees ahmed Mar 09, 2008
    check for the temperature of the doors heat. if the ring surrounding that is hot then there may be possible of the door stuck
    this will happen due to high temperatures rising due to bad circuits
    now if this door is stuck for a very long time please leave the door for few hours if needed for more hours.
    if the door is still stuck then it must be removed and pulled apart
    iot may have happened due to over heating
    thank you sir
    good luck
    dont forget to rate this solution
    i said the door will have stuck due to the OVER HEATING OF THE SYSTEM LAST TIME.
    THIS CAN BE EASILY SOLVED IF YOU LEAVE THE SYSTEM FOR FEW HOURS
    IF U HAVE LUCK IT WILL BE NORMAL AFTER SOMETIME. ELSE YOU WILL HAVE TO REMOVE THE DOOR BY DIS ASSEMBLING IT,...
    THANK YOU SIR
    GOOD LUCK
    DONT FORGET TO RATE THE SOLUTIONS
    HAVE A GOOD DAY
    YES SIR
    SINCE IT HAS BEEN STUCK FOR 2 WEEKS IT MUST BE DISASSEMBLED AND THEN REMOVED WITH CARE
    THANK YOU SIR
    IF YOU ARE GOING WITH MY SOLUTION THEN PLEASE RATE ME FIXYA SIR
    GOOD LUCK
Door lock is on but door is not shut, how do I get it unlocked so door can go shut
Unplug the oven for 5 minutes and see if the lock resets.
Nov 22, 2016 | Ovens
My Gibson Oven oven door will not shut because lock mechanism wont retract?
You almost certainly have a bad lock motor & latch assembly. Please provide model & serial # if you'd like more help, and with more detail on exactly what it will take to repair the oven.
Jul 27, 2016 | Ovens
Door will not open and oven will not shut off
The door latch will open after the shut down, therefore go to the home circuit breakers and shut off the power to the oven. Wait a few minutes and try to open the door. If still locked, reset the power to the on position and see if the oven rest and shut down properly and the door lock released.
Dec 31, 2013 | Kenmore Ovens
I have a frigidaire mef352bgwd electric oven- after a power outage the lock engaged (door open) and now blinks continually. Tried shutting off breaker for 30 minutes- no change.
There is a pin that tells the oven the door is open, you need to push it in an hold it. It is pretty stiff, you can't use your bear hand. It will be in the upper left of where the door closes.
Jan 07, 2010 | Frigidaire GLEB27S7A Electric Single Oven
Opened oven door before it could lock while I was
try unplugging the unit,
depending on your exact model it may just be lost in the programming becuse it sensed the door open while locking so it shuts down the lock for safety
just unplugging if for a few minutes might clear the error enough for the lock to rotate back to closed
position
Nov 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven Lock stuck open before start of self-cleaning cycle
Sounds like you bent the door where the lock is. You might have to replace the door.
Mar 12, 2009 | General Electric Stove/Oven/Range Chrome...
Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Oct 27, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire, Gas Oven Door
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%$#
Oct 10, 2008 | Frigidaire Gallery GLEFM397DS Electric...
DOOR SHOWS OPEN BUT IT IS NOT
After self cleaning the range the door won't open....
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Hope this may help;
DON'T FORGET TO HELP
Sep 06, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Kitchen Ranges Logo
44 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
