Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40S2000 40 in changing from HD to digital channels
My 40" 40S2000 sony lcdtv just got upgraded to comcast HD with new box. Set up and now when going from digital [not HD] channels to HD channels the screen flutters and this goes black-for ever. I can turnoff set and turn it on and the HD channel comes in fine. Problem some happens almost always.
  • bossgeek Mar 18, 2008
    Same problem on a Bravia XBR4 52" HD LCD TV
40X2000, both PS3 and DVD player are using a HDMI input and both flicker and loose signal fully, have to turn TV of then back on to get signal back. Sony say they have never heard this problem and replaced board. NOTHING fixed, still same problem.
Posted on Jul 20, 2008
Channel cable hdmi
You will need to go into the tv's "settings" menu and change the input label from "Skip" to anything else that best describes the device that is attached to it.
Good Luck!!
Rich Lilja
Dec 24, 2013 | Sony BRAVIA KDL-23S2000 23" LCD TV
Sony Bravia 40S2000 when switching to HD video goes black
Contact Sony. There is a software update for this. Go to www.Sony.com for contact information.
Nov 22, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Hdtv picture freeze
I also have a Brand new Sony Bravia 52" LCD with Comcast Cable (motorola box).When switching between HD Channels sometimes the left side of the screen shows a smushed version of the new channel, and the right side is a frozen picture of the previous channel. I correct this by switching to a non HD channel and back. Cable or TV problem I wonder?
Jul 03, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
I have a sony kdl-52S5100,and every so often when i switch channels i get only half a screen,{on the left side of tv}i can channel up and down abd it stays that way untill i push the input button on my...
I work for comcast have seen 2 kdl 5100 with same issue changed to component cables issue resolved
hdmi input is the problem. Yes I did try 3 different hd boxes same issue problem is with tv .
You are obviosly the third customer with this problem
May 17, 2009 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
Remote Codes for new Sony Bravia
you should press 10000, which is the code
Mar 06, 2009 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
I plugged this code in and it worked:
10000
Good Luck
May 12, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
TV not finding Digital Channels from Cable Box
I don't know where you're located but you may want to double check with Time Warner on the availibilty of an HD box. I have TWC with an HD tier package and have an HDMI out on the box that runs directly into HDMI on this TV. Hope that helps!
Jan 17, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia - Picture in ZOOm Mode
I corrected mine by adjusting my cable settings. It had been set to "zoom" / "wide" mode. I reset to "normal" and now channels look fine again.
Dec 30, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony kdl-40s2000
Probably need a software upgrade. Contact Sony for that information. This would be a common fix in most sistuations when using HDMI.
Dec 30, 2006 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
350 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
