When i press my shift key and my at key i get " but when i press my inverted commas key i get @ could you please tell me how i can get over this problem
  • 807 Answers
Go to control panel on start menu.You may have to click Classic View. Click Regional and Language options. Click middle tab at the top called Languages. Click the Details button. Click Add and select the English UK option from the drop down list. Apply and Ok.
Posted on Mar 09, 2008
    Sergeant:
    Champion:
  • 326 Answers
I don't know what PC or OS u have, but the properties of the Keyboard set controls what sysmbols are available where.
Comma shift inverted
What does comma shift inverted mean?
Dec 02, 2013 | Sony VAIO VGP-WKB1 Keyboard
Get rid of comma,
To switch the radix mark between the US and European modes, turn the calculator on, then press and release SHIFT, then press and release the decimal point key. You'll note that the shifted function of the key is marked "./," which should serve as a reminder that this functions switches between comma and dot.
Feb 15, 2012 | HP 10bII Calculator
When I type I don't get the inverted comma as it gives me the "at " as in "@" and vice versa. Also the back slash key gives me hush instead and the shift-3 which is supposed to give me...
Be sure that your keyboard is configured properly. You should be able to check under the "Region and Language" area of control panel if you are in windows and select "Keyboards and Languages." Check that it is set as a US keyboard or that it's set to which keyboard type you are using.
May 02, 2011 | Toshiba 310CDT Keyboard
I can access my @ key by using shift and pressing 2. i have to shif key inverted comma. it has only just chaged to this. i have had no problem in the past.
It sounds like num lock is turned on. On your keyboard hold the FN key and then press the symbol for num lock. This should clear the issue up.
Mar 01, 2011 | Toshiba Satellite Pro L300 Notebook
How to find derivatives using fx115-es
The syntax of the command is
where function is the expression you are differentiating
x is the value of variable x at which you are evaluating the derivative, and tol is the tolerance (the error) you are willing to tolerate in the result.
If you do not want to specify a tolerance just omit the last comma and tol.
To enter the command d/dx you use key sequence [SHIFT][Integral]
To enter the symbol x in the expression you press [ALPHA][ ) ]
To enter a comma you use [SHIFT] [ ) ]
To enter a power of 10 in the tolerance use [x10^X] key
Example : Calculate
The key sequence is as follows
[SHIFT] [Integral] 3 [ALPHA] [ ) ] [X^2] [-] 5 [ALPHA] [ ) ] +2 [SHIFT] [ ) ] 2 [SHIFT] [ ) ] 1 [x10^X] [(-)] 12 ) [=]
DO NOT confuse [SHIFT] [ ) ] which enters the comma and [ALPHA] [ ) ] which enters the variable X
Oct 29, 2010 | Casio FX-115ES Scientific Calculator
ViewMate Keyboard: when I press shift 2 I get inverted comma. donot w...
you need to change the keyboard lay out install US if the machine is from US and UK if bought in the UK goto regional settings etc
May 16, 2010 | ViewSonic ViewMate Keyboard
When i press the shift, inverted comma key, I get "" (two sets of inverted commas). When I press the apolstrophe key I get nothing. If I press it twice I get '' Help!
Go to control panel and check the regional and language settings. make sure it all says English and/or United States, if you are in the states that is, otherwise the keyboard will be different.
Oct 14, 2009 | Computers & Internet
Two keyboard keys seem to have been transposed
Yes when going through the setting up procedure for your new computer you should have installed the British keyboard instead of the US one.
Doing the above will correct your problem.
Nov 09, 2008 | Computers & Internet
The@sign
I had the same problem. When I pressed shift and that comma key I got a " instead of a @.
I looked to see what on the leyboard you normally press to get a " and that's the number 2 key.
Tried pressing shift and the 2 key and hey presto, I got a @.
So it looks like @ and " have swapped places.
So shift and 2 for a @!
Lizzie H
Oct 24, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
