Built in echo
I have no manual dont know how to turn down amount of pre prog echo
  • mick 100 Apr 12, 2008
    thanks for your help
In DOS there is an "echo off" command.
Don't know what area or program you're using.
Posted on Mar 13, 2008
How to sync headphone to amazon echo
The first thing you'll need to do in order to pair your Bluetooth headphones is to make them discoverable. Turn on your headphones and press the Bluetooth discovery button. On AirPods, it's the small button on the back side of the case.
While your Bluetooth headphones are discoverable, say, "Alexa, pair my [Name] headphones. If everything is ready, Alexa will automatically pair with your headphones and you're ready to go.
If you're not in a situation where you can or want to talk to Alexa, you can manually pair your headphones. You're going to need to actually touch your Amazon Echo Show screen for these steps, which is nice because ... you know, it's a touchscreen.
  1. Swipe down from the top of your Echo Show screen and then tap Settings.
  2. Tap Bluetooth.
  3. Select your headphones.
Your headphones will pair with the Amazon Echo Show and audio will begin streaming to them instead of the built-in speaker.
Oct 10, 2017 | Amazon Computers & Internet
We dont know how to turn the ringer down on the phone
The IA5864 doesn't have a ringer volume control but it does offer you a choice of several different ring styles, some quieter than others.
With the handset in idle (off) mode, press PROG. Press up/down until the screen displays "RINGER:" and the current setting. Press SELECT and you'll hear a sample of the ring. Press up/down to change the style. You'll hear a sample ring each time.
Full instructions are on page 9 of the manual at
http://vt.vtp-media.com/ecp/documents/product_Product/606/UserManual/1644/ia5864_manual_bkm.pdf
Jul 09, 2011 | Vtech ia5864 Cordless Phone
Our new 6.0 Caller ID phones have an echo. Can you suggest a remedy? John Chalk johnchalk@hotmail.com
as per jonniewalker from one of his posts:
"it may be due to interference from electronics devices around you since its a cordless phone ,or your phone is not getting a complete connection, could be one cause,Please try these solutions when you experience echo sound :
- turn the volume down
- turn the "clarity booster" function on the phone
Follow these steps to turn on clarity booster
1) Press menu/del during talk time (while phone is in use).
2) Press ^/vol or vol/v to move the pointer to Clarity Boost, and then select Boost On and "B" appears on the display. To turn Off the Clarity Booster, repeat above step again. check the owners manual for a full description for your model of phone
*Please note: clarity booster turns off automatically at the end of each call.
- make sure the Echo Canceller Circuit (ECC) has been set properly
*The phone should have Echo Canceller Circuit (ECC) built in.
*This means the circuit will study the Voice Level & reduce/cut the echo automatically.
Follow these steps to set the ECC properly
1. Unplug the battery from the handset for a few seconds.
2. Re-plug the battery back into the handset.
3. Make a phone call & at the initial stage speak loudly into the mic. Please note: The ECC will learn at the initial stage only, so after these steps are followed, the ECC will start working properly.or
just a simple pwr cycle ( turning the phone off) can give you a fresh registratoin, this can improve the quality of the call. hope this helps pls do let me know"
Feb 11, 2010 | Panasonic (KX-TG1032S) Phone
Echo on my end when someone calls! Please help! Thanks!
Jan 04, 2010 | Uniden DECT 6.0 Cordless Telephone...
Hi iam wondering what does this equipment is built for? i have one and dont know what is for PLS.
Used to run your computer for a pre-determined amount of time incase of power failure. Also acts as a good lightning arrestor (filter, surge protector).
Plug it into a powerpoint and plug your computer and equipment into the socket(s) on the device.
Beware, the more equipment plugged through this device the less time it can run this equipment for. Only plug in the essentials to this device.
Nov 10, 2009 | Minuteman MBK 300 (MBK300) UPS System
Fuel mix and manual for Echo SRM 4000
Go to www.echo-usa.com/pdf/documentation/SRM40005000edi_110107.pdf
Mar 28, 2009 | Echo Garden
Echo problem
Germans and americans dont mix,,,dump the car,,
Feb 10, 2009 | Apple iPhone 3G
Radio Shack Pro-82 Scanner
when on the scanning part push the scan part again and push the prog buton that is under the lower arrow key and push it again so it will go to a different (blank channel) . you will know when it you are able to prog when the word prog will be on the bottom of the screen then go to cityfreq.com to find the codes for your area and put them in and then press enter. after you do that press the prog button again and it will move to the next number to program a different on when you get the desired amount of frequencies in your scanner just push scan and it will run through the entered codes.. Or if thats not the problem then on top should be a bank of numbers and andd you have to push the number of what bank you want it to run through at that time.
Jan 25, 2009 | Radio Shack Pro-82 Scanner
Black and decker coffee maker
what type of coffee maker? does it have a model number?
Dec 11, 2007 | Coffee Makers & Espresso Machines
Computers & Internet Logo
247 people viewed this question
Alun Cox
David Payne
David Payne
