Question about GE JRS04 Electric Single Oven
Time flashes ...No other electronic button function
The power flickered in my home ...Just long enough to disrupt my digital clocks ... My GE Oven's clock was flashing .... I tried to reset it but have NO electronic functions from any of the buttons .... Is there a way to reset this electronic Control Panel
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 68 Answers
You may have the dreaded F7 problem. Go to the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
Please let me know if this works for you. I have shared this fix with over 1600 folks and most report success. You can email me at hutchipop@yahoo.com
Regards,
Charlie Popeck, P.E.
Consulting Engineer
Posted on Mar 10, 2008
CONVECTION OVEN CONTINUES TO GIVE fault code and doesn't heat
you either have a bad sensor or a bad clock assy. change the sensor first or check it with a meter it should read around 1080 ohms if this is good you have a bad computer board or clock assy. same part.if this a slide in stove with the burners on top there should be a tech sheet on the back,if this is a wall oven there should be a tech sheet below the top panel,slide it out and tilt it forwards enough to remove the top panel and of course kill the power to it first
Nov 03, 2017 | GE Ovens
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    Power was disrupted and stove needs resetting
    Try turning the power off to the oven totally and leaving it for a few mins, then turn it back on. If this doesn't work you may have to have a new clock/timer. espares used to have them. If you don't see it listed, send in a request.
    Jul 29, 2011 | Stoves 720EF Electric Double Oven
    Clock constantly flashes `A` and cannot get top or bottom oven to come on. Have tried resetting the clock but the buttons do not appear to be functioning. The mains power `has` been off due to having a...
    It looks like the clock has failed. Try leaving the power off for at least 10 mins, turn it back on at the main switch and then try it. If it still doesn't work Espares can get you a new one. Incidentally, if there is power to the oven, the grill will work even if the clock is not set.
    Jun 28, 2011 | Stoves 720EF Electric Double Oven
    Reset clock and oven light came on flashing
    THERE IS A PROBLE WITH THE ERC (CLOCK) NOT TO SURE IF I WOULD USE IT EITHER. THE PART IS EASY TO CHANGE JUST TURN POWER OFF AT THE BREAKER FIRST. YOU CAN FIND THIS PART HERE.
    http://www.searspartsdirect.com/partsdirec
    Apr 22, 2010 | GE Profile JTP18 Electric Single Oven
    My GE Oven heating element and timer clock went
    Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
    Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
    Clock on cooker flashing
    Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
    Apr 28, 2009 | Hotpoint UY46 Style Line Stainless Steel...
    Error code F7 keeps coming up, what does this mean?
    F1 error and beeping. Don't bother getting GE out there. Cost me $90 to learn they don't make the clock. WOuld have been $500+ for the control panel anyway. Better off just buying a new one. Planned obsolescence I guess. I won't buy GE again.
    Mar 16, 2009 | GE JKP27 Electric Double Oven
    GE JRS04 Electric Single Oven Logo
    367 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Oloyede Monsuru
    Are you a GE Oven Expert? Answer questions, earn points and help others
