Question about ViewSonic E55 15" CRT Monitor
Resistance value please sir if any body help me to solve the problem because in my monitor two resistors R206 and R207 burnt no colour coding is visibel please help me to find the value of resistors. Thanks Shahid Nadeem
  • shahid_shin Mar 09, 2008
    still waiting help
  • Somsak Tantong
    Somsak Tantong Mar 16, 2008
    He posted on another problem. The model is Viewsonic e55 vcdts21914-2p.
  • 151 Answers
Plz send model number of monitor
Posted on Mar 15, 2008
I need the resistor values used in .gm vat s. nti
if you can see the resistors then you will see that they are coloured coded by a series of different coloured rings around them. Go on line and down load colour codes for resistors and compare each resistor code with the printed results and you will be able to read what is the resistance for each resistor. The colour coding is a universal way of recognizing resistor measurements and is applicable to all resistors.. If in doubt check with you local JAYCAR outlet and it will be explained to you.
Oct 10, 2014 | Cars & Trucks
I have a Westinghouse LCM 19v7 monitor that stays on for a few seconds and picture goes off. I know about the capasitor replacement but there is another conponent that I need to replace. It is the pow
That is the correct value. That resistor just gets very hot and discolors the PC board around where it is soldered. You should be able to remove all of the old solder and scrape the resistor leg to get it bright, resolder the leg to the copper pad and you should be good to go.
Oct 09, 2012 | Westinghouse LCM-19v1 Monitor
Resistors burnt out & I cant make out the colour code as they are burnt black. how do I know what resistance they are so I can replace them?
Hello, resistors burnt out, why? If you replace the resistors will the new ones burn out? What you need is a diagram of the unit and you can get the resistance readings from that. But the question still remains, what caused the burn in the first place and have you repaired that?
Feb 20, 2011 | PowerBright Power Bright 3500 Watt Power...
I HAVE A GALAXY DX 88 HL TALK BACK TO LOUD I WHAT TO DO AWAY WITH TALK BACK THE R189 WIRE IS NOT THERE
See if there is a resistor connected from the junction of C154 and R207 to the junction of C187 and R235.
If there is no resister at these points add one.
Common values used are from 220 k ohm up to 680 or 1 meg ohm. The higher the value, the lower the volume.
If there is, increase the value until you have the volume low enough to use.
Be sure to leave R189 out of the circuit.
Apr 10, 2010 | Galaxy Radios DX- 88HL Base CB Radio
I got this one dead. There is a burnt resistor on the main circuit board ( the one with the on/off sw). Would anyone know what value it could be.
You can determine the resistors value by reading the color code bands that are marked on it. The following picture is an example of the color codes and there values.
To show you how to read the color codes on a resistor, I am including a link to a video that will explain how to do this easier than I could probably explain it.
I hope this helps you in solving the problem. If you need further assistance please feel free to ask.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You
Feb 15, 2010 | Fellowes 3011001 Shredder
Alpine MRP 200 could you pls tell me valu of
I don't have a schematic for your deck however, if the resistors you need are not burnt beyond visibility, this PDF should be alot of help. http://www.electro-tech-online.com/electronic-theory/42899-resistor-colour-code-values-chart.html Hope this helps
Jun 06, 2009 | Alpine Car Audio & Video
Monitor display problem
FLATRON E700S (EB770G-NA)_(CA-109)_(EB770G).pdf search for this file in google and download it for free and this could help ur problem solve
Jun 03, 2009 | LG Studioworks 700S 17" CRT Monitor
Kds vs-f14
There is usually an identical resistor somewhere else on the circuit board, so if you cannot read the colors of the burnt one, you can read the colors from an identical resistor on the same board. If you just replace the resistor, it will probably just burn out again or damage another component, you have to find the cause of the resistor burning out, most likely an electrolytic capacitor failing. Look for bloated or seeping capacitors and replace those as well. Also look for broken or burnt toroid coils.
Jul 15, 2008 | BenQ FP731 17" LCD Monitor
View Sonic monitor
I have Viewsonic 15" CRT Monitor (model E53)
When power ON, ther is only a colour patch appears on the middle of the screen . I observed some resistors and three transistors in horizontal sections were burnt.
I cannot read the real values of them because they are burnt.
Please kindly can you tell me those real values in that section.
Jun 13, 2008 | ViewSonic Computers & Internet
Burnt resistor
You have to check what could cause these resistors to be burnt. It might be because of caps or IC. Unfortunately, I don't have this type of circuit board. If you cannot find it, try with the same value of resistors that are placed close to these fault resisters.
Mar 16, 2008 | Computers & Internet
ViewSonic E55 15" CRT Monitor Logo
67 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
