Overfowing Washing machine leeks when a full load is put on.
  • Abraham Holland May 11, 2010
    What model machine do you have? Is it a Top-Loader or Front-Loader?
  • 96 Answers
If your machine is a front loader it could be leaking from the door if the gasket is not properly on. If its a top loader then it could be overfilling due to a faulty water level control pressure switch. Need yo know which it is.
Posted on Apr 06, 2008
My washer machine leaking water on fill or drain
Hi,you need to pull washing machine out and check filler pipe or pipes are not leeking,and take the lid and back off the machine and when it is leeking use a torch to see more cleerly.
Nov 05, 2016 | Washing Machines
MY LG FRNOT LOAD LEAKS WASHING INTO WASHING DRUM WHEN NOT IN USE. WHATS THE PROBLEM
the water valves are clogged with grit empty machine turn off the cold water tap leave it for 3 hours check drum for water if no water in your drum do the same to your hot water the 1 that leeks water into your drum is faulty replace the faulty valve
Sep 29, 2012 | LG WM2487H Front Load Washer
Slight leek on the front
In most cases, leaking is a sign of a clogged drain filter or drain pump. Water backs up and will find the point of least resistance. If you require further assistance, please post back with the make/model of your washer including if it's a top or front load machine.
Dec 29, 2011 | Washing Machines
Water leeking from under machine
check the seal and sump for cuts or damage
Dec 30, 2010 | Kenmore 24032\24036 Top Load Washer
Why machine was leeking and someone told me to turn it off now what will i do it is still full of water
If you can move the machine by a outside door and place the drain hose flat on the floor to outside and machine should drain out.
Jan 20, 2010 | Hotpoint WMA40 Front Load Washer
Whirlpool washer is leeking? water comes out from underneath the washing machine. It was purchased 4 years ago?
it sounds like you have a leaking pump, or a hose has been split, or chewed through by vermin
Aug 18, 2009 | Whirlpool WTW6400SW Top Load Washer
Cabrio leeks when it drains
most probable cause it come from draining pump it has a water seal defective
Jun 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing machine leeking from underneath
Check the door seal carefully. If no holes, then check the hoses and the waterpump.
May 19, 2009 | Hotpoint Aquarius WD640 Front Load...
Water overfowing
can you remove the soap drawer and clean it .Ther may be a build up soap in the drawer assyor your water pressure may be to strong try turning down the taps.if you ring the manufacture thay may have an operating book.hope this helps.
Mar 13, 2008 | Creda W100FW Front Load Washer
Washing Machines Logo
100 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
