Question about Epson Stylus Photo R300 InkJet Printer
Epson r300 message says papper not loaded correctly reload papper then press maintinance button brought of e bay could this be more serios as it isnt nothing to do with papper
    Scholar:
  • 104 Answers
Make sure the Paper Type setting on the printer control panel settings is correct and also any paper type settings in the printer settings on the computer.
Posted on Mar 09, 2008
Epson Stylus Photo R300 My printer has stop
I apologize for a delayed response as i was not at my desk.
I am sorry to hear regarding the problem.Unfortunately, this is a common problem on this printer.There is only one reset procedure that might work. Press and hold the ' Stop ', 'Maintenance ' and ' Power ' buttons for about 10 seconds.Then turn the printer off, and back on.
Note - You still need to get the ink absorber changed.
The repair is not economical as Epson would charge anywhere between $100 - $300 for repair. You could look for the below procedure to DIY :
http://forums.steves-digicams.com/photo-inkjet/50071-epson-r200-210-r300-310-mod.html
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 30, 2011 | Office Equipment & Supplies
The cd/dvd tray is not set correctly.
reload the cd/dvd tray then press the maintenance button
Feb 16, 2010 | Epson Stylus Photo R320 InkJet Printer
NEED TO RESET EPSON r300 PRINTER - MESSAGE- PRINTER NEEDS SERVICE PARTS ARE AT END OF USEFUL LIFE I KNOW I MUST PRESS TWO BUTTONS TO RESET BUT FORGOT WHICH BUTTONS TO PUSH.
Turn off the printer, hold down these buttons for 5-10 seconds (Power, Maintenance, and Stop). The printer should cycle itself back on and go through the reset process.
Jan 18, 2010 | Epson Stylus Photo R300 InkJet Printer
Quits printing and screen says "need service"
A: Power the printer on and press the Load/Eject button to see if
paper will load. If no paper loads, make sure the paper isn't
curled or creased, isn't too old, isn't loaded above the arrow on
the left edge guide, and that the paper isn't jammed in the printer.
If the Paper Out light is on solid, reload the paper, making sure
the paper edge guide is adjusted to fit the paper's width, and then
press the Load/Eject button again to see if the paper will now load.
If the Paper Out light is flashing, turn the printer off, reload
the paper, turn the printer back on, and try pressing Load/Eject
again to see if the printer will now successfully load the paper.
If the printer still will not load paper, power the printer off,
remove the printer cable, and make sure all of the packing materials
are removed. If the problem persists, the printer may need to be
sent in for service and you should contact the EPSON Connection for
assistance.
Jan 13, 2010 | Epson Stylus Photo R300 InkJet Printer
My epson stylus photo R300 will not print anything, and all it says is 'error' on the status. it once upon a time used to print, but suddenly isnt. please help! thanks, laura x
check for any obstructions inside the printer that may cause a jam within the printer. if all are clear pls resend the exact error message on the lcd of your printer
Oct 12, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson Printer Waste
you need software is the best way to do let me no if you dont haveit
Nov 27, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson r300
Power on...press advance button....press down arrowed button until options in printer screen stops...press maintenance button....ink cart replacement appears in window ...press OK
Jul 11, 2008 | Epson Stylus Photo R300 InkJet Printer
Epsom Stylus Photo R300
Yes I had a similar problem and in fact returned my printer for a replacement. You need clearance as the CD tray emerges some 2.5 to 3 inches behind the printer. If the tray hits an obstacle it is unable to correctly line up for printing and the trat is rejected
Dec 24, 2007 | Epson Stylus Photo R300 InkJet Printer
Printer stopped printing. Error message
Thjis is indication the Waste in collector pades need changing eventually.- but no now. you have plenty of warning
Reset Epson R300/200
press three buttons to reset the counters
The buttons are "STOP" "Maintenance" and "POWER"
or down load the epson utility www.ssclg.com and use the reset counter feature
The printer will sound like its going to blow up, but thats normal.
You can do this about 5 times before your printer starts to piss out ink over the table because the Waste Ink Ink Pad is full
To avoid eventual flooding go to rear of the machine- remove the little door and rake around for a small plastic pipe buried under some padding under the left side.
Fix to this a thin piece of ploythene tube[Fish tank air supply], extend it to our side the machine and place in a suitable container to collect the waste ink..
Nov 21, 2007 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
164 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
