Dyna-glo kerosene heater (rmc-55-r7 )
The wick will not stay lit. Seems to be getting fuel. Also, where can I find a manuel
  • dixielee8486 Nov 10, 2008
    I have the same heater and it will not stay lit, worked fine one day then not the next
  • 4 Answers
Wicks won't light for usually one of 2 reasons. water in the kerosene, which means a new wick and new fuel. or build-up on the wick. check to see if the wick is hard. your wick should be soft. burning out the heater until all fuel is used either by running down all the fuel in the unit or removing the fuel can and lighting to burn off all fuel in the bottom will prevent the wick from getting hard.
Posted on Jan 19, 2009
Need to see pictorial instruction on how to replace wick in a Dyna Glo RMC-95-C2 kerosene heater
I think the Dyna-glow RMC95 series of heaters are equivalent to DH2300 series heaters.
In any event, the wick you purchased should have ahd the installation instructions included with the wick.
If it didn't or you tossed it, Here's a link to the DH-2300 series heater's Owners Manual, which may help you.
http://www.yourheater.com/DH2301-3%20owners%20manual.pdf
Good luck. Be sure to wear rubber gloves when you try to install the wick. Particularly, if you still have kerosene in the tank.
Feb 11, 2011 | Dyna-Glo RMC-8001SS Heater
I just replaced the wick, cleaned up the heater and filled with new K-1 kero. The heater (Dyna-Glo RMC-95-C7) is emitting black smoke worst than ever. The wick is burning a little unevenly.
Either the wick was improperly installed or you may not have allowed enough time for the wick to soak in the kerosene and become evenly distributed. Check the placement of the new wick and allow time (several hours) for the wick to absorb the kerosene.
Jan 31, 2011 | Dyna-Glo RMC-8001SS Heater
I have a dyna-glo portable kerosene heater model RMC-55-R7 just replaced the wick an left wick soak up kerosene for an hour, heater lite fine, but when i hit the extinguishing button heater want go out...
When you hit the extinguish button the wick should drop down so that you can only see just the top of it or maybe none of it. Check the position of the wick. It could be binding up so that it will not go into the lower position. If it isn't you will have to figure out why.
Nov 07, 2010 | Heating & Cooling
Dyno-Glo RMC-95-C7 kerosene heater. replaced wick
once the tank gets low(on E) put the heater outside and let the remaining fuel burn completely out. This will burn off the residue build up on the wick and make it easier to turn off manually. do this often. i also use an old toothbrush to "fluff up" the wick. if the residue is too hard for the toothbrush bristles, flip the toothbrush over and break up the residue with the back side of the toothbrush. once all (or nearly all) of the residue has burned off you may see some smoke when you ignite the wick again. also, it may smell for a bit. I always light and shut off the heater outdoors. I mounted a dolly (table withe 4 wheels) under the heater to make transporting it easier. hope this helps!
Jan 02, 2010 | Dyna-Glo Heating & Cooling
Kerosene heater
Dyna Glo 95 c4 Manual
http://www.owneriq.com/mdownloads/8979e0af-dfee-45f1-a8ba-c05c2f5ed4a8.pdf
Jan 31, 2009 | Dyna-Glo RMC-8001SS Heater
I have a dyna glo heater model # rmc-55-r7 i just bought 2 of them less then 3 weeks ago and ive already burnt up the wicks i dont know why
do not use the RED fuel !! use the clear!! now clean the top of the wick of the hard stuff and run agane.
Jan 08, 2009 | Dyna-Glo RMC-8001SS Heater
Heating & Cooling Logo
1,125 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
