I have a Panasonic DMR-HS2 DVD video recorder. The disc tray appears to be locked. Even if I disconnect the power, or put the DVD in standby, - when the DVD is 'powered' on, it immediately displays the 'playing disc' symbol (as if it has one in its tray), then shows 'BYE' on the DVD. As soon as the OPEN/CLOSE button is pressed it repeats the process ... and we can't therefore open the tray? Any ideas please
  • lasardancing Mar 09, 2008
    It is on a surge protector!
    What exactly is wrong though?
    You say the device is damaged, how was it damaged - the DVD tray was empty, and nothing was being recorded on the HDD - so why should the unit have been damaged?
  • 13,433 Answers
The device is damaged, if you have warranty take it to the shop or a local repair shop / center.
It might have been caused by a power surge, Id recommend buying a surge protector to all the sockets where you have valuable devices connected.
Posted on Mar 09, 2008
  • Ekse Mar 09, 2008
    other option is to dismantle the device and remove the dvd and hope it recovers. but that might not solve the problem.
  • Ekse Mar 09, 2008
    So i still would recommend takeing it to a professional. Or to be warranty replaced.
    Genius:
  • 1,665 Answers
Hi Have nice day!
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Mar 09, 2008
    It seems to be a mechanical position switch problem. Tray wrong alignment.
Hallo, I'm new here, I hope someone can help me with my problem. I have a Panasonic DMR-HS2 DVD recorder, and I've had no problems yet, till recently. I had programmed several TV programs. W
It might well have crashed!
I suggest you unplug or turn off the power to the unit and leave it off for a while to see if it corrects itself when you power up again.
Keep a look out for any codes in the display when it powers up. Was there a disc in the drive when you shut it down? That might be contributing to the problem if there is.
If the hard drive has failed it still might be possible to remove it and recover the contents, before fitting a new one. There are the same ones you buy for home PC's afterall.
Mar 08, 2017 | Panasonic DMR-HS2 DVD Recorder
I want to reset the reorder but i don't know how.
If you do not have your original instruction manual, you can download a free pdf from:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-HS2
(right-click and save link/target as... - it is a 3.2MB file (total size))
It may or may not help. Either way it's free.
Apr 25, 2011 | Panasonic DMR-HS2 DVD Recorder
My Panasonic DMR-ES30 DVD Recorder / VCR Combo is about 5 years old now its fine on stand by but when i put a dvd or vhs in after about 10 seconds it cuts out completly any solutions on how to fix it...
This is a good sign that the power supply is having a problem. In standby or even on without a tape or disc, the current draw is low. Once a disc or tape is inserted there is a higher demand on the power supply. This is usually some defective capacitors that are easily replaced. Realize that there are other possibilities as well, but the power supply is the most common. The parts cost is in the $15 range.
Dan
Apr 28, 2010 | Panasonic DMR-ES30 DVD Recorder/VCR
My Panasonic DMR-EX85 is locked into region 2 Can you help to to make is Region Free please Thank you Roger
TRY DMR-E85 DVD Recorder Firmware Update
Version DL-106
  • Compatible Models DMR-E85HS
  • Issues Addressed Issues Addressed
    1. Corrects DVD Recorder hang-up or freezing during DVD playback caused by connection to Scientific Atlanta cable box model # 3250.
    2. Improves playability of discs with high reflection detected.
    3. Improves playability of discs with fingerprints.
    4. Improves disc playability corresponding to CPRM.
    5. Improves playability of DVD-RAM x16 discs
  • http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Drivers-Downloads/model.DMR-E85HS.D#ts
    Oct 26, 2009 | Panasonic DMR-E85H DVD Recorder
    DMR-EZ48V- DVD drive not working
    Check Panasonic.com for Firmware updates. If it has a reset button reset it. Take off the cover remove dust and lint, also clean laser eye with rubbing alcohol. DO NOT LOOK DIRECTLY AT THE LASER LENS IF YOU PLUG IT IN, DURING THE OPERATION.
    Sep 10, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
    My panasonic dvd recorder dmr-hs2 keeps switching to standby mode
    I have the same problem, but it takes a while longer...just get the circle rotating in the LCD on DVD!
    tried unplugging HDD...still does it.
    Jan 13, 2009 | Panasonic DMR-HS2 DVD Recorder
    Won't recognise DVD Ram and non-finalised discs from own recordings.
    Usually, the U11 error code in a Panasonic DVD player indicates an optical problem. You could of course try doing a cleaning using a CD cleaner normally readily from computer parts stores. Alternately, you can open the unit up and do a manual cleaning with soft bristle brush and/or cotton buds. Other than that, it could be indicative of a weakening laser eye which of course would require parts replacement.
    Hope this be of initial help/idea. Pls post back how things turned up or should you
    need additional information.
    Good luck and kind regards.
    Thank you for using FixYa..
    May 24, 2008 | Panasonic DMR-HS2 DVD Recorder
    Locked DVD Tray
    I'm pretty sure the force disk eject is the same across all Panasonic models - however I couldn't find anything specific for your model number. Still worth a shot, though.
    With the unit in standby, press and hold the 'Stop' and 'Ch up' buttons together. It should power up and force the tray open. If this doesn't work, try changing up your timing by pressing and holding 'Stop' first, then a half-second later, press and hold 'Ch up' and keep them both held together. You can also try the opposite.
    If none of these work, it will have to be taken apart to get the disc out. If you aren't comfortable trying, it will have to go to service.
    Mar 09, 2008 | Panasonic DMR-HS2 DVD Recorder
    Televison & Video Logo
    81 people viewed this question
    Top Televison & Video Experts
