Acer LCD monitor Model No:
Acer LCD monitor
Model No: Al 1716A
Version: 1716 As
Broken screen.
Can we change the display/screen?
where can we buy a new/used screen in Derbyshire,UK?
    Sergeant:
  • 458 Answers
CONTACT ACER.
Posted on Mar 10, 2008
Is Acer 1717 Display board and Acer 1716 board are the same? I need a replace ro my Acer 1717.. But there are no boards available.. But Acer 1716 boards are available.. Someone help.. Thanks a lot...
There are more than one version of the AL1717, also more than one version of the AL1716.
See my pictures here:
http://s807.photobucket.com/albums/yy352/budm/ACER/
See if they match your monitor.
Best thing to do is to get the numbers as printed on the board and Google it.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 19, 2011 | Acer AL1717 17" LCD Monitor
I have a AL 1716 monitor and the on/off button is
More likely to be bad caps with bulginh tops in the power supply, common problems, see some example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 06, 2010 | Acer AL1716B 17" LCD Monitor
Acer monitor only display for about 3 to 4 second
Sounds like a busted syncing circuit, probably due to a condenser. It takes about that time to heat or overcharge, at which point a safety feature will turn off the display.
You just MIGHT get some more life hours out of the monitor by tuning it to a lower resolution, but it will buy you a month even in the best hypothesis.
I'm afraid the monitor is in for a repair/replacement.
Oct 30, 2009 | Acer AL1716 F Monitor
Monitor Acer Al 1914, no signal
Check your connections to the PC. Make sure that they are nice and secure. If there is a resolution problem setting it should display the boot process and then go blank after starting the operating system.
Oct 28, 2009 | Acer AL1914 19" LCD Monitor
MONITOR ACER AL1716
1. Unplug the AC power cord to make sure the power is off.
turn the monitor upside down, you need 2 people for this.
2. Pull the 4 hooks on bottom side of the base and hold.
3. Separate the monitor and base.
Nov 05, 2008 | Acer AL1716 17" LCD Monitor
ACER AL 1716
Hi...there,
It's seems your backlight inverter are busted, need to replaced a new one or repaired it.
Oct 11, 2008 | Acer AL1716 F Monitor
ACER AL 1716
There are two types of lines.
Lines caused by a bad LCD screen and lines caused by poor sync.
A bad LCD will cause perfectly straight vertical and horizontal lines that don't move at all. This is because the row and column addressing ICs have gone bad, so you will end up with rows or columns of bad pixels.
Poor sync looks more like what you are describing. The picture will flip vertically and horizontally.
Poor or missing sync can be caused by a bad video cable, or a bad IC on the main board.
If the monitor has a removable video cable, borrow another one from a friend to test if the monitor is working. If it works, head to your local computer store and buy a new cable.
If the monitor still doesn't work with a different cable, you may have a bad main board. The only way to repair the monitor will be to replace the board.
If you open the monitor, be sure to check for bad capacitors. They can cause all sorts of strange faults. Look elsewhere on this site for how-tos on inspecting capacitors.
If your video cable is not removable, there's not much you can do. You will need a way to test that each pin on the cable connector on the main board conducts to a corresponding pin on the other end of the cable. You can do this if you have a multimeter, or a continuity tester.
Mar 28, 2008 | Acer AL1716 17" LCD Monitor
Snowy Raster on display
Hi mcuyg,
Hope this will give you hint in solving this problem. Try configuring monitor settings in OSD mode; contrast; brightness; etc.. other special settings can be accessed using combination of buttons to minimize the raster intensity. On hardware side try resoldering cold soldered points and check the SMPS side.
Best regards,
Rosener Guyano
Jan 27, 2008 | Acer AL1716 17" LCD Monitor
No post (blank screen) after intial driver install Acer 1716 LCD monitor
Please clarify something for me, after installing drivers, system reboots, and you have no POST information or startup screens at all?
Dec 15, 2007 | ATI RADEON 9550 Graphic Card
Computers & Internet Logo
David Payne
David Payne
