Flatline what is wrong when the tv screen suddenly lost its picture. Instead it only shows a vertical flatline. Sound is ok tho. And when I turn it off for 10 minutes or so then on again then its okay. Then sometimes its goes off again then i do the same process again. What needs to be done?
    Problem Solver:
  • 18 Answers
Please ensure that all the wires connecting to tv are not loose. Keep the air vents of Tv clean and airy. Let it cool if u watch it whole day
Posted on Mar 09, 2008
Tv 27" has only half screen picture horizional I
Possible failure of the VERTICAL SECTION of the deflection circuit. It is possible that the areas related to the vertical circuit is checked , check for weak capacitors near the output vertical drive. Also a faulty vertical coil- deflection coil- can result in half picture.
A vertical signal test can confirm.
Oct 16, 2011 | GE Televison & Video
No picture
the problem of your t.v is either lost contact on the vertical section or the supply of vertical I.C. was lost............if u're not an electronic expert just bring u're t.v to the nearest repair shop.....and that was a very easy problem..........
Feb 12, 2010 | Televison & Video
Flatline!
the vertical drive ic that drives the yoke for vertical sweep has blown.
sometimes it is solder problems like sharp and toshiba had.
the part is 10$ the pc board will label it ,the yoke is the coil setup on the picture tube.if you follow the wiring half goes to the horizontal drive,and the others to the vertical section.the chip drives the coil directly.there are VERY high voltages in there ,even turned off. the pix tube cap on top is 30000v. like a stun gun.the horizontal drive 2000 volts and the main power supply 165 volts dc high current.you need a special setup to discharge the picture tube.
May 15, 2009 | Mitsubishi CK-35308 35" TV
Half screen showing
ok
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Jan 13, 2009 | Samsung TXG2746 27" TV
Quasar TV sp 2724E Loses the picture
Sounds like a failed vertical amplifier circuit. This is normally primarily contained in an integrated circuit mounted on a heatsink.
There are other possibilities along the line but the one above is the most likely.
Now all you need is a TV repair shop that is still in buisness.
Jan 03, 2009 | Quasar SP-2725 27" TV
Jvc av27d201 tv screen problem
You need to have the vertical output IC pins resoldered
Jul 16, 2008 | JVC AV-27D201 27" TV
Samsung TV stopped displaying picture
No picture but sound can mainly be of two problems, most of the times it is caused by a faulty vertical deflection ic, you can diagnose this by slightly increasing the screen voltage by turning the screen control on the LOT, a horizontal line will appear if the vertical ic is shot, and the other problem is the CRT base, but this is less common for shot base won't go off at once, it will show picture faded in the beginning. Now another problem could be the horizontal output transistor, if the tv has a high power sound output, the sound power supply will come from smps itself instead of from LOT, check that too, to confirm this, check if the CRT filament is glowing. Good luck.
Jan 17, 2008 | Televison & Video
LG colour TV RI32CZ10RX problem with picture
My LG tv has suddenly got a problem with the picture. Whilst watching the tv with no problems at all, the picture was suddenly reduced to a thin vertical line down the centre of the screen and an awful smell seemed to come from the tv There is a short ckt in your tv in horl. section. 1 isolate power from horizontal section. 2 check for normal output from power supply. 3 check parts in horl output section a hor.output transistor b diode & cap in h/output trnsformerckt. c check for print. d if all are ok check for eht transformer. e if every thing becomes then reconnect hor output section supply. f put on the set.
Sep 23, 2007 | Televison & Video
TV screen went black, sound OK
check cold solder vertical circuit
Nov 21, 2006 | JVC AV-27530 27" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
