Where is the waste ink tank -how do i clean or empty it
  • Anonymous May 31, 2008
    cannon printer sends message ink waste tank nearly full how do i get rid of it
  • 81 Answers
Since you didn't even specify the printer I am going to be real generic here. The waste ink tank is below the parking position of the print heads. unless you are really lucky and have a printer that should have died years ago you will never hav to empty it out or clean it. The are designed to hold the equivalent of several complete ink cartridges and are also allowed to dry out leaving only a residue.
I hope this answers your question.
Posted on Mar 09, 2008
Tip
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
on Apr 02, 2010 | Office Equipment & Supplies
I need to know how to empty the ink waste tank so that I can clean up the ink blobs and leakage.
You should be able to go into maintenance in your printer software & it will tell you how to empty the tank.
murf427
Aug 01, 2012 | HP Photosmart C6180 All-In-One InkJet...
Waste ink tank near full
You have to remove the waste toner bottle and put empty bottle.
May 26, 2011 | Canon Office Equipment & Supplies
My instruction screen always reads "Waste Ink Near
Please check the link belwo with a visual display to remove and clean the waste ink tank.
http://www.youtube.com/watch?v=6PbY1gbDw7Y&feature=related
Check related sites in these for more views
Mar 03, 2011 | Canon PIXMA MP170 All-In-One InkJet...
After replacing the ink waste tank, I am still getting an error stating replace waste ink tank full on an Ricoh GX3000 all in one.
This may have to do with the method of replacement. Leave the printer on, remove the waste tank, clean the area (sensors may detect residual ink) replace the empty waste tank. If this doesn't work, there may be a chipset on the waste tank to indicate end of life. This is a way for the manufacturer to continue making a truckload of money from the end user. Generally the only way around this is to modify your printer to by-pass this part of the circuit (an electronic solution to replace the chipset). This method will most likely void your warrantee.
Aug 25, 2010 | Ricoh Aficio GX3000S multifunction Ink...
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
My Canon I550 quit printing.
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
bullet.gif Two flashes: Out of paper or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
bullet.gif Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. However, when printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it will be a cause of trouble.
See Replacing an Ink Tank
bullet.gif Six flashes: No print head installed
Install a print head.
bullet.gif Seven flashes: Defective print head
Contact a Canon service representative.
bullet.gif Eight flashes: Waste ink tank almost full
i_note_us.gif Note
Canon recommends to call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on.
If the problem remains, contact a Canon service representative.
Apr 14, 2009 | Canon BubbleJet i550 InkJet Printer
When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
Here are all the flashing explanations:
Reload the paper correctly and press the RESUME/CANCEL button.
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
Computers & Internet Logo
111 people viewed this question
Alun Cox
David Payne
David Payne
