Archos 605 wifi problems
After attaching usb cable on comp my archos 605 screen shows this message-usb cable attached,windows media device (buttons temporarily (disabled)and wont allow me to connect to computer
    Sergeant:
  • 458 Answers
What does the USB cable have to do with the WIFI
Posted on Mar 10, 2008
Wont install to computer
On the Archos:
In the settings menu from the front screen, set your Archos to 'PC Hard Drive' instead of Windows Media Player.
If it doesn't show as an external hard drive when you plug it into your pc, do this....
On the pc:
Go to Start\run, type diskmgmt.msc and click ok to take you into Disk Management.
Your Archos should show as a drive in here and you can associate your new drive with a drive letter.
If you cannot see your Archos in this windowafter you've set it to 'PC Hard Drive' on the Archos, then you may have a dodgy usb cable.
Hope this helps......
Jul 19, 2010 | Archos 605 WiFi Digital Media Player
Archos won't connect by USB to computers
You should keep your eye on the device after its been plugged to the PC it will give you 2 options "charge" or "usb" you ca not establish a connection without picking usb connection option on the Archos screen when it pops up. If you are doing so and problem still existed then i would recommend you to download the latest windows media player. Because it comes with new devices sync driver update.
Aug 10, 2009 | Archos 605 Wifi Portable Multimedia Player
My archos 605 wifi is stuck in recovery
I fixed my son's 605 4 GB had Recovery code (104) on it These are the steps i followed
* Use the computer for this process that you always used for this archos
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white screen comes up do format
* Wait until all done then put the firmware in to the root sector of the Archos
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug in back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving wait until it is all done and it will shut off. Turn it back on Your archos will be back to normal.
When you go to download from Archos site it will explain how to download depending upon how your device pops up on your Pc.
Hope this helps
Jul 29, 2009 | Archos 605 WiFi Digital Media Player
605 not recognized by Windows Media Player 11.0
You may require a driver to work with your device. Try downloading driver from company's web site.
Jul 15, 2009 | Archos 605 WiFi Digital Media Player
My archos 605 wifi
Try reseting device by inserting a pin in the bottom reset hole. If still non-responsive, try connecting device with usb cable and switch device on then off.
All else fails you have a 1 years warranty on device, which comes standard.
May 26, 2008 | Archos 605 WiFi Digital Media Player
PC no longer recognizes my Archos 605
in the archos....select SYSTEM....change windows media player to PC Hard Drive and this worked for me
Mar 24, 2008 | Archos 605 WiFi Digital Media Player
Recovery code 104
Same issue on my Archos 605 wifi 4GB
The Repair didn't work so here's what I did.
1) connected via USB and got all my Picture, Videos and Music to a safe place.
2) Downloaded firmware update.
fouund it here - http://www.downloadplex.com/Drivers/Firmware/Archos/Download-Archos-605-Wifi-4GB-Firmware-2.1.04_109044.html
3. Copied update to root of archos drive and rebooted
4. Archoes installed the update and rebooted and came up to desktop again
5. reinstalled plugins (thank god I saved them) copied plug-in to root.
6. Back on the road again
Feb 23, 2008 | Archos 605 WiFi Digital Media Player
Firmware upgrade results in arclibrary boot failure
I managed to overcome the problem by doing a factory reset. Unfortunately doing this initially created more problems in that on reboot the main screen appearance looked as it should but was almost inoperable. When the usb cable was connected to my pc the disc did appear on My Computer . The system folder was only 1MB. By good fortune I had copied and saved my Archos files before I carried out the factory reset. Copying the original system files ( about 20MB) back to my Archos returned normal behaviour. Further, two additional buttons appeared. One was a manual arclibrary update button and the other a USB setup button . I cannot get file transfer to operate under windows media player mode and Windows media player 11. No problem though. I use PC hard drive mode and carry out a manual arclibrary update. None of this was possible prior to the factory reset. I believe I would still be having serious problems had I not saved and restored my system files
Feb 08, 2008 | Archos 605 WiFi Digital Media Player
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
