Question about Hotpoint NWXR473EV Dryer
Help me fix my dryer
I start my dryer and after a few second it dispalys f08 and flashes ... its a hotpoint vtd65 aquarius please help
  • cath28 Aug 23, 2008
    same thing F08 flashes while the timer still counts down but it stops drying, any suggestions?
Could be that the belt has gone. I think it does one cycle, then when it tries to reverse it gives the F-08 error and stops - and I think it cuts the heat out for safety.
Posted on Oct 16, 2008
After starting its wash cycle an error code flashing F-08 appears Could you let me know the cause of this and if it can be fixed
For most Hotpoint (Indesit) models 'F08' means 'heater relay (possibly) stuck'. 'Check power supply connections to the heater, wiring and module (i.e. PCB) connections' (apparently poor PCB connections are often the cause).
So- if you are not electrically confident and competent yourself, which you may be, you need to employ the skills of a partner, friend or service engineer ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Apr 29, 2011 | Hotpoint Aquarius WD640 Front Load...
My hotpoint aquarius vtd65 keep saying clean filter but i dont that and it still saying it
hi this how it works it just to make you check it it will go out when you start the dryer
Feb 08, 2011 | Dryers
Hi, Error code F-08 is flashing on the display.
F08: Heater control or NTC (Thermistor) temperature sensor problem. hope this helps. also turning off at plug for 5 mins then turning back on might solve it if does not then it is the sensor problem. best thing to call engineer or get new machine if dose not work. hope this helps.
Sep 18, 2010 | Hotpoint Aquarius WD640 Front Load...
Wd640 showing f08
Code F08 indicates heater relay stuck.
  1. Check pressure switch connections.
  2. Check heater connections.
  3. Check control connections.
  4. Check and clean pump filter.
Please rate my sol;ution.
Thanks.
Nov 15, 2009 | Hotpoint Aquarius WD640 Front Load...
Stops near end of cycle and on/off light and drying high heat light flash
error code f08-htr relay stuck-ckeck htr not open citcuit-connections on board are clean especialy botton connecters-if still throws error then req new board
Nov 12, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Washing machine flashing f-02 f-08 hotpoint aquarius
F02 and F08 are 2 completely unrelated problems.
F02 indicates motor problem, and F08 indicates a problem with the heater circuit, the relay is not energising, possibly due to a faulty heater or themistor.
Would advise you call a qualified repair technician.
Please rate my solution.
Thanks.
Jul 23, 2009 | Washing Machines
Hotpoint
F08 is - Static heater relay with contact welded closed.
The door might had been opened with the dryer not cooled.This leads to a heat relay.
Dec 13, 2008 | Hotpoint Aquarius WF000 Front Load Washer
E30 flashing when I try to start wash program on Hotpoint Aquariu
E30 indicates a motor problem, you will need to call an engineer.
Possible worn brushes which you can do if you know what you are doing.
Nov 24, 2008 | Hotpoint Aquarius WD640 Front Load...
Dryers Logo
204 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
