Question about HP mx705 17" CRT Monitor
Hp mx 705 monitor the brightness menu appears andautomatically increases brightness to 100
Please help
  • 7dhdway Dec 22, 2008
    Brightness and Contrast Menu appear on screen....automatically. I have an ACER AL1914 moniter.
  • 109 Answers
I do monitor repairs, on some other models, i change the 7805 5volts regulator that feeds the microprocessor chips, and the problem of osd displaying is fixed, but on this particular HP mx705 crt monitors, it has no 7805 regulator, but a transistor that is regulated by a zener diode.. will try to replace it and its corresponding filter capacitors..if the problems is fixed..i will post the results..
Posted on May 09, 2010
Facing same issue in HP M704 from 12th Mar 08. It was working good for more than one year. Planning to contact customer support for service.
Posted on Mar 12, 2008
Gracias
Posted on Sep 28, 2008
Contrast Problem
You will need to adjust the contrast and brightness down to about 50%.
Apr 20, 2008 | HP L1706 17" LCD Monitor
Hpm-705 crt monitor fault?
my monitor model is HPm705 CRT as and when i use the system the monitor screen gets switched off and on every 2mins... pls consider the issue and tell the solution for it... to get resolve......
Sep 05, 2009 | HP Computers & Internet
Contrast Ghost
This is common problem observed in many monitors compaq,HP,HCL,IBM this is happens mainly in rainy season due to moisture,by this moisture monitor button circuit get rust inside and button pad remain pressed. so it shows a strip at the middle of monitor like contrast or brightness. So this is minor problem just replace the monitor display control button sensor or circuit.Temporarily you can warm up the monitor by hanging a bulb of 60 watt nearer your monitor to takeoff the moisture.(Dont hang the bulb too near to the monitor). It definitely solves your problem.
Good Luck
Sep 02, 2009 | Computers & Internet
The brightness adjustment bar appears on the screen all the time
Press the menu button on monitor select the brightness press the menuside button increases or decreases.after select exit oress the exit button on monitor.
Jul 13, 2009 | Compaq CV 7500 17" CRT Monitor
On screen display keeps appearing on, and usually
hi..i think you have a problem the CPU/Computer that's whystays on screen for so long.1st step check the IDE cable connection form the mother board to Hard Drive and 2nd check the memory or check all hardware`s.Good Luck and Have a nice day
Jun 17, 2009 | HP mx705 17" CRT Monitor
Philips 170s6fs monitor: OSD menu blocked
.well i had the same problem but my dad fixed it.
.he opened the monitor [like unscrew it.] and just clean it. brush it. and it will work fine.
if it didnt i dont know.
Dec 06, 2008 | Philips 170S6FS 17" LCD Monitor
Problem with brightness of monitors SyncMaster 710n
HelIo! right after computer inclusions on the monitor screen have a tablet with the message which disturbs to work. The message: brightness of the monitor of 100 %! A problem: how to clean from the screen this tablet so she prevents to read the information. I have not found adjustment in the menu of the monitor brightness. And what should be brightness: 100 % or another? have not found adjustment in the menu of the monitor brightness. And what should be brightness: 100 % or another?Thanks and sorry about my bad english. Afzal.
Sep 06, 2008 | Samsung SyncMaster 710N 17 in. Flat Panel...
LG Flatron E700SH
Hi its not problem it is just setting difference
Try this one
go to menu setting and increase TEMPERATURE to 8300 or between 8300 to 9300
this will help you to solve your problem
thanks and regards
Teknas
Aug 17, 2008 | LG Flatron Ez T910BU 19" CRT Monitor
HP mx705 17" CRT Monitor Logo
688 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
