Question about Acer Aspire 3000 Notebook
Key board and touch pad freeze
Help
  • 1 more comment
  • Anonymous Mar 17, 2008
    My computer will no shut off and the mouse is set just above the sign in box and nothing I do will move it.
  • marrty Apr 02, 2008
    had the freeze problem! aND HAVE THE ANSWER.Its a power issue the battery needs replacing! to see if it works just remove battery and plug in power supply.should now be O.K!!!!!!!
  • Anonymous Jun 17, 2008
    my computer acts frozen-i have a cursor and back screen but no other options and it will not turn off.
Para mi la solusion fue no instalar una actulizacion de windows xp, proximamente dare mas detalles
Posted on Jun 20, 2008
Removed the battery and it is working fine.
thanks.
Posted on Jun 15, 2008
Try this it will fix your problem, and it will really help to speed up your PC.
Posted on Apr 07, 2008
Thanks a million for this extra ordinary suggestion.
IT works fine on my Acer Aspire 3004LM laptop.
Just disabled the battery and it goes ZOOM!!! Good as NEW >>GOLD.
Kind regards from Fiji Islands.
Nilesh Chand.
It's the battery, which is nearly dead: see the other thread with almost 40 entries. According to that thread there are three working solutions:
(1) Take the battery out;
(2) Change the power-saving settings to laptop;
(3) Change one of the properties of the battery/power driver.
All 3 work, and all eliminate the root-cause conflict: it's a high-priority loop, triggered by low battery voltage, which trying to deal with the situation doesn't leave room for other drivers to do their job.
Posted on Apr 06, 2008
  • 148 Answers
2 Suggested Answers
SOURCE: keyboard and touch pad locked
How do I unlock key board and touch pad.
Posted on Sep 27, 2008
E2 error on a Samsung washing machine
The E2 error indicates a stuck or shorted key on the touch pad or a wiring problem between the touch pad and the main control board. Sometimes this can be cleared by unplugging the washer for 2-5 minutes. (Note: this is usually a temporary fix.) Next run your fingers across the keys. If you find one is lower than the others, that's the stuck key. Try to get it to move; sometimes just pressing it again will work.
You should check the wiring between the control board and the touch pad for any loose connections and for any corrosion or damaged insulation. Replace damaged wiring; reconnect loose wires. (To access this, unplug the washer and remove either the top or access panel at the back of the washer.)
If these don't help, you'll need to replace the touch pad or the control assembly (touch pad and control board). If you add a comment with the washer model, I may be able to supply the parts information for the unit. If your washer is under warranty, contact Samsung.
I hope this helps.
Jun 29, 2016 | Samsung Washing Machines
Touchpad doesn't work
unlock touch pad locking key (Fn and Touch pad icon key on key board OR near touch pad key)
Aug 19, 2011 | Toshiba Portege R705-P25 Intel Core i3 4GB...
I have a Kenmore Double Oven that's eiving a Code 7 and beeping
Hello,this code is the result of a failed function key on the key pad, or control board. Some control boards will have the touch pad, or key pad combined with the actual control board, as one whole unit. If this is the case, simply have the main control board replaced. Now, if the touch/key pad is separate from the main control board, this will require you to gain access to the control board and key pad, and preform this test below to isolate the failed component.
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Thanks
Jun 02, 2010 | Kenmore 43389 Electric Double Oven
Touch pad problems
Most of the toshiba laptops can disable touch pad with FN + F9.
In F9 key u can find touch pad picture.
May 27, 2010 | Toshiba Laptop Keyboard for Satellite L10,...
Kenmore model 911 4238816 - the f7 code just came on beeping and we can't get it to stop. what is the error code mean, what can we do to stop it
HI. This code is the result of a failed function key on the key pad, or control board. Some control boards will have the touch pad, or key pad combined with the actual control board, as one whole unit. If this is the case, simply have the main control board replaced. Now, if the touch/key pad is separate from the main control board, this will require you to gain access to the control board and key pad, and preform this test below to isolate the failed component.
Jan 03, 2010 | Kenmore Ovens
Oven blinking code F7?
Determine if problem is with the Key Panel or Control by:
Dec 18, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
My touch pad will not work thus rendering the oven useless. It will not respond to touch. Is there anything I can do sans a new processor pad?
HI. Unfortunately, the touch/key pad is not repairable. Once the circuitry is damaged, the entire board must be replaced. Most units will have an Incorporated control board, that will have the touch/key pad integrated into the main board assembly. If this is the case, simply replace the entire oven control board. If the touch pad is separate from the main control board, replace the touch pad board.
NOTE_ This may be a simple control fault. In this case, simply unplug the unit, or shut down the appropriate circuit breaker for five minutes. This will reset the control. If the issue's persist, replace the failed component.
Dec 03, 2009 | Jenn-Air JGR8775QD Gas Kitchen Range
Microwave shows F2 on display with controls non functional
HI. this is a code that represents a failed key pad or touch pad membrane board. replacing this failed touch pad will fix this issue. This touch pad board is separate from the actual control board.
Aug 13, 2009 | KitchenAid KHMS155L Microwave Oven
Touch pad freezes
reinstall your os, install best antivirus of today. it is the problem of your os and virus if its continues then problem with your hardware (cpu fan).
Mar 18, 2008 | Computers & Internet
Mother board problem?
re install touch pad driver and try again
Jan 08, 2008 | Toshiba Refurbished SYSTEM BOARD 400CS...
Acer Aspire 3000 Notebook Logo
146 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
