BIOS PROBLEM When start computer every time ask that chek your cpu speed,but when i go to bios and chenge speed then save and exit the computer was hang,i open my mother bord battery for one hour then start the result was same,if i go to bios and select a speed and exit without saving then computer run properly,so how to solve this problem?the problem creat when i select from bios as a best performance option.please guid me.
  • avishek Mar 09, 2008
    Dear Iqbal,
    i cant find my bios system as a defalt settings option,my pc is p3 and american bios system,please told me which option i found the solution.
    Regards
    Avishek
  • avishek Mar 10, 2008
    Dear Iqbal,
    Thanks for guide me, its helpfull for solve my bios problem,actually i still cant find the default system in my bios system at last i go to bios and simple i exit with saving then the problem was solved,
    Thanks & Regards
    Avishek
I have had the bios chip fail on a couple of Abit motherboards. You may want to replace this or perhaps flash your bios first. these chips are in the $20-30 range and easy to r&r. Make sure you pull the battery first!
Posted on Mar 11, 2008
    Sergeant:
  • 458 Answers
You were told to set the CPU speed to default. What kind of Motherboard?
Posted on Mar 10, 2008
  • 655 Answers
Actully you are not selecting the reall speed of CPU thats why it asks. Its better to use the default setting of your BIOS as it was provided by company as per your specification.
Thanks
Iqbal
Posted on Mar 09, 2008
  • Iqbal Husain
    Iqbal Husain Mar 09, 2008
    Ok,
    When you goto bois setup to set your CPU speed. See there might be an option like "Load Page Default" or some thing like that. In P3 mainly BOIS use the F7 function key for Default value.
    You can also find Default setting on the BIOS main page.
    Thanks
    iqbal
I cant overclock my system but i go to bios now whati had to do
The BIOS. Overclocking is best done in the computer's BIOS (Basic Input/Output System or Binary Integrated Operating System). There are also some motherboards that let you do a basic increase in power by setting a jumper, but this is dangerous and you have no real stability control.
There are some software programs available which allow you to overclock inside the operating system, but the best results are achieved by changing BIOS settings. Usually you can get into your BIOS by pressing DEL (some systems may use F2, F10, or Ctrl-Enter) as soon as your computer begins the POST
(Power On Self Test - when it shows the RAM size, processor speed, etc.).
Here, you can change your FSB (front side bus), memory timings, and your CPU multiplier (also referred to as CPU Clock Ratio).
Clearing your CMOS. Sometimes, an overclock can become unstable. If this happens, or your computer will not boot, you will need to reset the BIOS back to default and start over again.
This is done by clearing the CMOS (a small piece of memory on the motherboard which stores your BIOS configuration, and is powered by a small battery). Some newer motherboards will bypass user settings in the CMOS if the computer fails POST (often caused by a faulty overclock). However, most motherboards require a manual clear.
This can be done in two ways, depending on your motherboard. The first way is by changing the position of the clear CMOS jumper on your motherboard, waiting a few minutes, then repositioning the jumper to its original place.
The CMOS Jumper
The second way, if your motherboard doesn't have this jumper, consists of unplugging your computer, removing the little CMOS battery, then pressing the power button (your capacitors will discharge), and waiting a couple of minutes.
Then you have to refit the battery and plug in your computer. Once your CMOS is cleared, all BIOS settings are reset back to default and you'll have to start the overclocking process all over again. Just so you know, this step is only necessary if your overclock becomes unstable.
Locked or Unlocked. The first thing to know when you start the process of overclocking, is whether your processor is multiplier locked or unlocked.
To check whether your CPU is locked, lower your multiplier via the BIOS one step, for example from 11 to 10.5. Save and exit your BIOS and your computer will restart.
If your computer posts again and shows the new CPU speed, it means your CPU is unlocked. However, if your computer failed to post (screen remains black) or no CPU speed change is present, this means your multiplier is locked
Multiplier Unlocked Processors. Usually, your max overclock is limited by your memory, or RAM. A good starting place is to find the top memory bus speed in which your memory can handle while keeping it in sync with the FSB. To check this, lower your CPU multiplier some steps (from 11 to 9, for example) and increase your FSB a few notches (e.g.: 200 MHz to 205 MHz).
After this, save and exit your BIOS. There are a few ways to test for stability.
If you make it into Windows, that is a good start. You can try running a few CPU / RAM intensive programs to stress these components. Some good examples are SiSoft Sandra, Prime95, Orthos, 3DMark 2006 and Folding@Home.
You may also choose to run a program outside of Windows, such as Memtest. Load a copy of Memtest onto a bootable floppy, then insert the disk after you have exited the BIOS.
Continue to increase your FSB until Memtest starts reporting errors. When this happens, you can try to increase the voltage supplied to your memory.
Do note that increasing voltages may shorten the life span of your memory. Also, another option is to loosen the timings on the memory (more on this a bit later). The previous FSB setting before the error will be your max FSB. Your max FSB will fully depend on what memory you have installed. Quality, name-brand memory will work best for overclocking.
Now that you know your max FSB, you'll figure out your max multiplier. Keeping your FSB @ stock, you raise your multiplier one step at a time. Each time you restart, check for system stability. As mentioned above, one good way to do this is by running Prime95.
If it doesn't post (reread the section about clearing the CMOS), or Prime 95 fails, you can try to raise the core voltage a bit. Increasing it may or may not increase stability. On the other hand, the temperature will also be increased. If you are going to increase the core voltage, you should keep an eye on temperatures, at least for a few minutes.
Also note that increasing voltages may shorten the life span of your CPU, not to mention void your warranty. When your computer is no longer stable at a given multiplier setting, lower your multiplier one step and take that as your max multiplier.
Now that you have your max FSB speed and your max multiplier, you can play around and determine the best settings for your system. Do note that having a higher FSB overclock as opposed to a higher multiplier will have a greater impact on overall system performance.
http://www.pcadvisor.co.uk/news/index.cfm?newsid=107977
hope this helps
May 30, 2012 | Computers & Internet
How to change bois setting
Hi, Welcome to FixYa!
Please follow these steps,there are different way od going to BIOS depending on the brand of the laptop.
1 Turn on your computer
2 Hold down F2, this will take you into BIOS. On some computers it might be the DEL key, or F1.
3 Change the settings in BIOS to what you desire. You will see parameters for various devices, if your BIOS allows it, you can even overclock the CPU.
4 Look at the BIOS menu. You will be able to see the make, model, and capacity of your hard drive, processor speed, time and date, among many other settings.
5
Click "exit without saving changes" if you make a mistake, and nothing will be changed.
Hope this will help...Thank you for using Fixya...
Jun 19, 2011 | HP Compaq Presario v3000z Notebook
How do you view the bios settings on the dell precision m4500?
Please follow these steps,there are different way on going to BIOS depending on the brand of the laptop.
5
Hope this will help...Your response is very much appreciated...
Feb 16, 2011 | Dell Precision M4500 Notebook
I have Sony vaio vgn-nr21z how can I go to the bios setup which key to use
5
Feb 15, 2011 | Computers & Internet
Hi I have a Sony vaio vgn-nr21z I don't know how to go bios setup pls tell me how to do that
5
Feb 15, 2011 | Sony Computers & Internet
BIOS won't save changes after changing CPU.
you may need to "flash or upgrade the bios.
Dec 27, 2009 | EliteGroup 848P-A Motherboard
Bios time and boot problem
friend there can only be 2 probs
1. you mb bios cell is dead, so just replace it
2. ur bios is not saving at all, get ur bios updated by a mb technician
thanks
Apr 11, 2009 | Dell Computers & Internet
Bios Can't Memorise Seting.
when you enter your bios and make changes you must save those changes before you exit normally this by pressing f10 wich will save the bios and then exit, and reboot the computer.......
i hope this is what your looking for.......if not please clarify the question for me.
Oct 11, 2008 | Intel DG31PR Motherboard
Computer boots to BIOS screen
apteryx:
Did you try loading the defaults in the BIOS? make sure that you save the changes while exiting BIOS.
-You might also need to install any updates of BIOS on this particular motherboard (going to the manufacturer website of the motherboard will be helpful).
Let me know please.
Hope that helped!
Dec 20, 2007 | ASUS A7V8X Motherboard
Toshiba tecra m2 bios missing sections of video
get to the mainboard
there is a jumper near the cmos battery usually shows the
word (jbat) near it , try to change its position for some
seconds while power is off , this way will clear cmos and set the
mainboard bios to default settings.
start the system hit delete or F2 to enter setup then exit saving changes.
Nov 08, 2007 | Toshiba Tecra M2 Notebook
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
