Question about Olympus EVOLT E-500 Digital Camera
Flash I am having a problem with the flash on my camera. When I got to take a shot it will flash like 5 times before taking the picture. By this time it has blinded my subject. Help Please
  • Anonymous May 11, 2008
    when trying to take a picture it sometimes flashes 5-10 times and has trouble focusing.
    Problem Solver:
  • 8 Answers
This is the AF Assist feature. If you don't have a hot-shoe flash mounted, but you do have the pop-up flash raised, the camera will strobe the pop-up flash in low-light situations to provide illumination for the auto-focus to work. You can disable it by turning off the AF ILLUMINATOR option in the "Wrench 1" settings menu.
Posted on Mar 23, 2008
  • 42 Answers
Did you turn on the so-called "anti-red-eye" function which for some camera models will fire a sequence of flashes before a photo is taken?
Posted on Mar 10, 2008
Sony CYBER -shot DSC-w190 does not flash when taking picture although flash auto on
It will only flash when there is not enough available light when in AUTO flash mode.
To flash no matter what, go into the camera setting and select that choice.
Normally something like demand flash or a symbol that looks like a lightning bolt. Then it will flash every time. That does use more battery power though. By the way, I like that setting better too.
Dec 29, 2009 | Sony Cyber-shot DSC-W190 Digital Camera
Canon 5d
Make sure you have your flash & timing set where it is supposed to be, usually between 120 & 180. This is the shutter timing and flash duration. It is the syncronizing speed setting. If possible, turn off the automatic review, this slows things up. Also, if possible, use a power cord for the flash instead of batteries. Not all have this feature but, the flash is ready for the next shot in about 1 second.
Jan 27, 2009 | Canon EOS-5D Digital Camera
Shutter button delay
The flash need to be fully charged before it would fire the shot.
In case the battery is old and supply power is not enough to boost the flash, it will await until the orange LED of flash indicator is no longer blinking, means ready to take picture with flash light.
Replace the new full battery will be better and faster to take shot with flash enable.
Jan 01, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
I have a Canon 5D and a 430EX flash. When shooting pictures my flash will delay way to long before I can shoot another picture with flash. One picture is good and 3 are dark. My flash card is a...
The 430ex flash is E-TTL, that means it adapts is power to the scene. If you shoot a scene at 10 meters, the flash will choose to flash at the max power, and will take time to recharg. Try to get closer to your subject, and remember that the flash can only lighting your subject, not the whole scene.
Dec 14, 2008 | Canon EOS-5D Digital Camera
Flash symbol flahing with flashing number E9101 but does not flash only infer red light
Try this........
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Hope it will solve your problem....
Oct 06, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
When using flash, my sony cyber-shot dsc-t10 takes forever to take pictures!
Have you tried Hi-Speed memory cards, as writing speed of the card affects the response time of camera, I am using Sony MSX-M2GN 2GB and it's gives me quite good response.
Other thing you might try is format the memory card using camera, camera has card format functionality and it does also improve the performance of the camera.
Jul 16, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
Camera not taking pictures
The camera may be trying to tell you that your flash is turned off in Auto mode, but to get a proper exposure you will need the flash turned on. Try turning the flash on and see if that works.
Hope this helps!
May 20, 2008 | Canon PowerShot A540 Digital Camera
SB 600 Flash pre fire
The only thing I could think of is that when you use the red-eye on the camera or flash it will flash several times before taking a shot.
Apr 01, 2008 | Nikon Speedlight SB-600 TTL Flash
Pentax S40 Lag Time
It's definitely painful. I set my camera to default to no-flash because of the extra time it takes to recharge the flash. It may be because Pentax allows the use of alkaline batteries, so they've made the peak power usage lower by processing the picture, writing to the card, and recharging the flash sequentially, rather than doing the flash recharging in parallel which would speed up things *alot*. Maybe they can add a Lithium/NiMH mode that would help speed things up?!? I've done some adhoc testing with my new panasonic 10mb/s SD card versus a plain jane Sandisk 2mb/s card and from what I can tell, there's less than 1 sec difference between the two cards in cycle times. So taking pictures with a faster card won't help the cycle time enough to really matter... even without the flash activated. With flash it doesn't matter at all. It may affect movie mode, but I haven't tested that yet.
Sep 08, 2005 | Pentax Optio S40 Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
153 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
