Question about Magnum 257 CB Radio
Magnum 257 off freq
Hi can you help i own a magnum 257 and the radio tx's about 1kc
off centre freq i would love to bring it back to centre freq
i have most of the test equipment and all the right tools for the job
just need to know where to start???
thanx colin
  • 204 Answers
Colin, here is all the tech info on alignments that your looking for,,,go here;
http://www.cbtricks.com/radios/rflimited/magnum_257/index.htm
Hope this gets you on the right track,, let us know.
Mechanic
Posted on Mar 10, 2008
Freq. display not correct but radio is on the write freq.
This of no surprise because it is just that a display not a counter.
There must be an alignment pot for the meter display although there will be some doubt if you just align it with out using a frequency counter.
http://cbtricks.com/radios/rflimited/index.htm
you might find more alignment info under the S45 omegaforce as they have similar boards.
hope this helps...goodluck!!!!
Aug 06, 2011 | Magnum 257 CB Radio
Hi my deltaforce is slightly off on ssb you have to be on 27554 and clarifier at 12 30 to be spot on 27555 thanks vince
Use a known good external freq counter, and do the tx alignment. that will put your meter back on showing the right freq when you are..
Jan 27, 2011 | Magnum DeltaForce CB Radio
Magnum 257: if I push the microphone button for emission , TX appear on the screen in the top right but does not appear the bar signal on the bottom therefore not be heard.If I stop and turn on the radio...
Hi livi, my name is John. Welcome to FixYa. If you have a MIC GAIN, turn it to MAX. If no avail, try a different mic. Are you saying you have no receive, turn the RF GAIN to MAX and the SQUELCH all the way to the left. Let me know. Thanks for choosing FixYa.....John
Dec 07, 2010 | Magnum 257 CB Radio
My 257 magnums audio keeps cutting in and out but my receive is fine
hi it may be a dry joint , on the audio driver or power .if mike is power.could be battery hope this helps
May 21, 2010 | Magnum 257 CB Radio
I fogot how to put my converted 257 magnum into the lower channels and to have it read freq and channel
http://www.radiomods.co.nz/albrecht485magnum257mods.html
Good Luck,
Dodgem250.com
Oct 18, 2009 | Magnum 257 CB Radio
I am wanting to put my rci mic on my magnum 257. everything works accept the up channel button. can anyone help? Thanks Tom
the up down is done differently in the magnum compared to the ranger. it takes a 22k resistor for making it to go up. and ground is down. cb shop temple, tx on yahoo search... do that and should work. its all done off ONE pin not 2 like the ranger
Jul 05, 2009 | Magnum 257 CB Radio
Magnum 257 6 digit display
To tune frequencies in either 10 kHz or 100 kHz increments,
press the STEP button until the desired digit is
flashing. Rotate the FREQUENCY control in either direction.
The entire frequency range of the Magnum 257
can be stepped through in 10 or 100 kHz increments.
To tune in 1 kHz increments, press the STEP button
until the 1 kHz digit flashes on and off. Rotate the FREQUENCY
control. NOTE: When stepping in 1 kHz increments,
you are limited to tuning within a 10 kHz
frequency range.
Dec 22, 2008 | Magnum 257 CB Radio
Magnum s-980
all the s9 do this its not a fault
Oct 16, 2008 | Magnum 257 CB Radio
Magnum 257 No Audio Being Transmitted
Hello.I have a similar situation on a Magnum 257 HP operating on SSB (AM and FM works fine). If i Transmit it works fine, but when i release the Mic button (after TX), in the bottom side were the RX level should be, it appear somth like a signal level 3 to 5 (constant and continous), but i can't get any reception at all. Only if i turn the TX power level to MAXand i transmit, then it goes back to reception, but not every time. Somtime after TX i need to push the mic button 2-3 times to make it recive somthing, but this wors only if the power level is over 60-70% an i repeat, only on SSB.Can i get some help with this issue?
May 10, 2008 | Magnum 257 CB Radio
Magnum 257
Yes, there is info there to do a complete alignment for the transmitter or receiver. I do have to wonder what caused the radio to develop the problem; like did it slide off freq all of a sudden, maybe was bought used with the problem in there? Or someone with that dreaded "golden" screwdriver? lol If the radio has a bad solder joint causing it to slide off freq, then just putting it back with the adjustment is just a band aid approach. Need to figure out what caused the problem, and go after that. I hope this sheds a little more light,, have a good one. Mechanic
Mar 11, 2008 | Magnum 257 CB Radio
Radio Communications Logo
180 people viewed this question
Top Magnum Radio Communications Experts
AnyMHz.com
AnyMHz.com
John Porter
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
