The front power accessory outlet is not working but the cargo area one is. My son is going on a trip to florida. Could it be a blown fuse or is the accessory outlet bad and is it easy to replace myself
-   Same problem. Replaced fuse #15 and it works fine now. Does anyone know what fuse #18 does?
-   Guest
Aug 08, 2008
-   I am having the same problem. I checked the fuse for the front outlet and it is not blown. I even replaced the fuse and it was still not working.-   mookierox
Jul 02, 2008
-   I blew fuses with my Verizon phone charger. I read somewhere that if you plug the charger all the way in the fuse will blow... It does. I corrected my problem by purchasing a 10 ft extension cord, Bell Automotive for the charger, model num ber 39003-8. My charger has worked well ever since. It was the cheapest and easiest solution I could think of. Hope this helps someone out.
-   stack1111
They can be on separate fuses. Check your owners manual or look at the cover over the fuses. There may be multiple fuse box locations, some in the vehicle, and some under the hood.
I have (had) a 2006 CR-V with the same problem. The identified fuse for the outlet (#18) was not blown. However, there is a fuse identified as "+BR ACC" (fuse #15) that was blown. Both are 15AMP fuses located in the fuse box under the steering column. Replaced the #15 fuse and the outlet is working just fine.
I have a 2wd, no sunroof SR5 sequoia and would like to install a dvd/video player on it.
Are there...
(More)
Are there units that fit into the last opening of the overhead console? Are the ones that are being installed aftermarket fitting in there or behind that overhead console? Any suggestions of ones that you have found to work would be greatly appreciated.
everything is hooked up have power but no sound what so ever tryed to plug rca plugs in al diffrent...
(More)
everything is hooked up have power but no sound what so ever tryed to plug rca plugs in al diffrent slots and still nothing at all mute button turned off sound level up
What Alpine cable connection is needed to connect my i pod touch so i can play the videos etc... its...
(More)
What Alpine cable connection is needed to connect my i pod touch so i can play the videos etc... its for a alpine iva-d310
