Question about Canon PIXMA MP830 All-In-One InkJet Printer
Cannon mp830 I put in new ink in it's proper place....it reads..."the type of print head is incorrect install the correct print head". Help.
  • mrspicky Mar 09, 2008
    Hi Leo..I did that...It is still reading the same thing.
  • mrspicky Mar 11, 2008
    It is a genuine cannon cartridge. It is still reading the same thing. I took the inks out & the print head as requested....to no avail....nothing.
    Master:
  • 619 Answers
Hi try to remove ink cartridge and put it back , push down the cartridge to engage will the micro chip.
Posted on Mar 09, 2008
  • leo2 Mar 11, 2008
    Hi , does your ink cartridge are genuine ? if not replace with canon ginuine cartridge.
Alarm tyoe of print head is incorrect
its usually part of the replacement ink cartridge, are they original inks or 3rd party
Jul 15, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Cannon MP510 printer has Error, - The type of print head
I solved this on mine by removing and reinstalling the print head.
1. Remove and set aside the ink cartidges (don't make a mess)
2. lift the gray print head lock lever that is to the left of where the ink cartridges go.
3. Lift out the print head out without touching the ink ports inside, the contacts on the back, or the print nozzles on the bottom. The print head is the grey thing with circular ink ports that seat the ink cartridges. there are good pictures in the PDF of the Easy Setup Instructions available on the Canon Printer website. Look under the printer, then support, then downloads: http://gdlp01.c-wss.com/gds/0900002776/mp510_esi_us_v2.pdf .
4. Put the print head back in, lock the lever, reinstall the cartridges in the roper positions. And voila!
If this doesn't work you may actually need a new print head.
Oct 08, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Incorrect printhead
It just means that the printhead is defective, All of the Canon machines say that when the printhead goes out.
Jul 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Cannon MP830 Printer cartridge jam
So you cant get the ink tanks in place properly?
Have you tried this method to ensure they're properly seated? Is the printer on or off when you try to seat the tanks?
Refer to the following steps to verify the ink tanks are seated correctly:
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  3. Open the inner cover.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press down on the ink tank until a click is heard, thereby making sure the ink tank is seated properly.
    Note:
    Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
  5. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note:
    Ink Tank Lamp
    You can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  6. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Apr 04, 2009 | Office Equipment & Supplies
CANON MP830 all in one is sayin" the type of printhead is incorrectn Install the correct Printhead."
Hi follow the instructions as above...
ie Remove inks and print head...
But instead...
Whilst Canon print head is out...
Use cotton wool and alcohol and clean electrical contacts on back of print head and where they make contact inside printer.
Then install print head and inks and test.
If it does not work you may need to replace print head.
Mar 14, 2008 | Canon PIXMA MP830 All-In-One InkJet...
My Canon PIXMA MP830 all-in-one is saying "the type of printhead is incorrect, install the correct printhead."
The cartrige is what holds the ink, the printhead is the device that puts the ink onto the paper.
So if your out of ink, then you need a new cartridge, if you have a new cartridge and you are having issues printing good quality, then you may need a new printhead.
you can get the ink here: http://printerinkcartridgesearch.printcountry.com/canon-pixma-mp830-ink-cartridges.htm
printhead is about 49.95
http://www.precisionroller.com/k_canon_pixma_mp830_print_head/m114d8577c104/
Hope this helps!
Brad Nelson
Error: The type of Printhead is incorrect, Install the correct printhead.
Ok i know this is kinda old, but i found a solution.
First to those people to state I found a solution from hp, cannon etc etc and not give out the direct link, or instructions, then whats the point fing posting????
This error happens when you install an oem cartridge onto your system. Or havent used it in a while, so the machine is somehow misfigured.
This solution is for canon mp800, simply switch off printer. HOLD stop/reset and press and HOLD on/off button. release stop/reset. Now press stop.reset twice. then release on/off button, press stop/reset 4 times, wait 20 seconds, press on/off button twice.
switch machine back on and the printer should find the cartridges.
This method maybe the same for your mp*** if not google RESET CANON PRINTER MP*** and you'll find the correct buttons to press.
here's a printer on reseting a bunch of canon printers http://tricks-collections.com/reset-printer-canon-mp140-mp160-mp180-mp210-mp220-mp460-mp470-mp500-mp510-mp530-mp600-mp610-mp800-mp820-mp810-mp830-mp960-mp970/
good luck.. and FU canon for adding you scamming chips into cartridges.
Mar 04, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
453 people viewed this question
old marine
old marine
