Question about Marshall Mg15dfx 15-Watt Combo Guitar Amplifier
Where is the serial number on my marshall amp mg15fx
  • 31 Answers
Behind the amp, right around where the power-supply is. Usually the right hand side at back of amp. Serial numbers are labeled as: S/N########
Posted on Mar 14, 2010
SOURCE:
Marshall mg15fx no sound coming. only sound i get is buzz when switching the master volume knob. pls help me.
Hi, I have repaired loads of these kinds of amps. The first thing to check is if the input jack socket is still soldered to the circuit board properly. These have a tendency to break.
They all have a dual opamp and a 15 watt power amp chip. Invariably it is the power amp chip that fails IF it is an electronic fault. Both chips can be bought for a few pounds.
The variations, aux input, spring reverb and this, digital effects are extremely unlikely to cause this kind of failure.
At one time anyone with a screwdriver and a soldering iron could fix these, but in the days of health and safety, find someone who knows what they are doing.
It should take half an hour and about £3 worth of bits.
All the best, Chris the Fader.
Jul 04, 2014 | Marshall Amplification Marshall MG15 15...
Marshall mg15fx. no sound coming. the only sound i get is buzz when switching the master knob.
I would test by first trying a different guitar cord. If the fault is still there, try jumpering the effects in and out jacks with a patch cord. If there is sound now, clean the two jacks with contact spray and working a 1/4 inch plug in and out of the two jacks.
Serial number, where is it located?
Some Marshall serial numbers might tell you the year your 3005 was made, Marshall stamped the different years of the micro's in different spots, your number could either be on the back metal plate stamped right above the AC power cable port, or barely visible on the front gold plate above the power switch just under the Tolex, at least that's where my 1988 3005's serial number is stamped. But it should have one on it somewhere, could even be inside the head too, my sis plays and has an old 1977 50watt tube head with an interior serial number. I've been a huge fan of the Micro stacks since they came out in the mid-80's. I believe the 3005's were only produced from 1985 or so till around 1988 or 89 in Black, White, Red, Orange, Blue, Purple, and Grey, a Camo Tolex was a custom option as far as I remember. 1987 was Marshall's Silver 25th Anniversary, so a Silver Tolex Jubilee edition was made that year only. Than the newer MG15-II's were made from around 2004 till 2010 along with the Zakk Wylde signature series micro stack,. And now they make the newer MGD's since 2010, I just tried one last week at my local guitar shop, I liked it a lot, it's very different sounding than my old 1988 or my 2009 micro's and has a few built in effects which weren't great, but not that bad at all, I have a 1988 3005 stack that came with Celestion G-10's in the cabs and an MG15-II series micro stacks, that one came with some no name 10's, but believe it or not they sound better than the G-10's! Mine are all in black, I have been after an original micro stack in white for many years.Did your old 1x10 cabs come with Celestions too?
Apr 23, 2014 | Marshall Amplification Music
Marshall mg102fx cuts out
I've seen a bunch of Marshall Combos and a very common failure comes from broken resistor legs at pre-amp and power amp modules insides, they are the low-value/2-3W rated and the soldered legs broke so easy because of enclosure vibrations, let me know a bit more to improve help...
Nov 04, 2013 | Marshall Amplification Marshall JMD1...
The amp does not work at all even though the lights on the amp come on but when i connect it to the guitar no sound whatsoevva i checked the sound nobs on the guitar and the amp n all r ok but no soun
Have you checked a different cable?. Also, when you plug in the unit, there should be a "pop" if everything is turned on. If there isn't, the connection is bad someplace.
Aug 06, 2012 | Marshall Amplification Marshall MG15FX...
Marshal mg15fx : Noise when i connect the amp to a mixer.
Mixer uses balanced outputs, this unit does not... Also ground loops can be a problem. Make sure this and the mixer are BOTH powered from the same receptacle. The next problem is that the level of the mixer is MUCH too high for an amp designed to recieve guitar signals if you are sending a mixer into this. It is NOT clear how you are connecting this to a mixer... IF you happen to be trying to send signals from this to a mixer, either use a mic OR use a Direct Input box. You should tell us exactly how you are connecting this to the mixer since there are MANY ways, and most do not make sense.
Aug 07, 2011 | Marshall Amplification Marshall MG15FX...
The Overdrive button has stopped working
check to see if your fuses are blown should be an easy fix
May 05, 2011 | Marshall Amplification Marshall MG15FX...
Where is the serial no. on a mhz40c
The serial number for this will be on a sticker on the back. If it is missing then perhaps someone removed it. You may be able to contact Marshal and they may be able to tell you as well. http://www.marshallamps.com/
Mar 22, 2011 | Marshall Amplification Marshall Haze 40...
Marshall Mg15dfx 15-Watt Combo Guitar Amplifier Logo
301 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
rjivaro
Are you a Marshall Music Expert? Answer questions, earn points and help others
