Code for calculation of R-R interval
We r doin a project in DSP.. using c50 processor... we need a C code for the calculation of R-R interval in ecg signal.. we tried a lot.. but we cant get it..
Opps!i know how to do that bt kindly tell me what do do wth ur s so iu hev dicided to go wth os
Posted on Mar 28, 2008
  • 981 Answers
J00 shou1d sp3c ou+ R-R in t3h ECG (electrocardiogram, or something else?) 4cc0rding 2 j00r plann'd interva1 4ppl1c4tI0n D0m4iN!!! T3h articles by Medtronics and other remore-monitoring staff (see patent search for names!) go into what they use for R-R and how it was adapted for the particular vertical domains expected.
I wonder why you want C in a processor like the C50 (not just a faster PIC microcontroller); did you really not abstract the signal inputs s.t. failsafe VMs can help you out if one locks up or appears to be integrating suspiciously (or merely in a way which is useless for your signal separability test marks?)
Posted on Mar 11, 2008
How do i put my behringer inuke 6000 dsp in stereo mode?
Behringer iNUKE NU6000DSP
Stereo mode is set by the DSP processor ( I/O amp mode). The link above will lead you to the manual. On the main page go to "documentation" and to "manual , English". Review and study the functions of the DSP processor. Yo'll nedd to find I/O amp mode.
Jun 02, 2014 | Behringer NU6000DSP iNuke 6000-Watt Power...
I do not know what a range is and where to find it on a Casio FX 9750GII Calculator
In statistics, the range of 1-var a data set is the difference between the largest value and the smallest. R=Xmax-Xmin
In functions: the range of a function is the interval (or the Union of intervals) of the real line where the dependent variable takes it values.
Ex: sin(x). Whatever the value of the independent variable x, the values of the function sin(x) are in the closed interval [-1,1]. The range of the functions sin(x), and cos(x) is [-1,1].
No use of a calculator for finding the range of functions.
Feb 04, 2014 | Casio Calculator Graphing FX 9750GII...
How to find z-score using fx-570 es calculator
I dont think its possible with that calculator. You need to use the z-score table.
Dec 08, 2012 | Casio Office Equipment & Supplies
How do i use the equal sign when doin an equation?
With this calculator, you cannot do (solve?) equations. It has a general computational mode (COMP), a table mode (TABLE) and a statistical mode (STAT). You can find these by pressing the MODE key.
Jul 16, 2011 | Casio fx-300ES Calculator
Camera dsp error
Welcome to FixYa,
DSP means Digital Signal Processor and this is the part in your phone responsible for processing digital imaging.
The amount of image data gathered by camera nodes in WMSNs is very large. They need to be compressed before transmission. JPEG2000 is the image compression standard which has many advantages, such as high compression efficiency and high image fidelity. However, its high computational complexity makes it a big problem when using it in WMSNs. To satisfy the low-power and high image quality requirements of WMSNs, studies shows the low-power JPEG2000 realization on DSP-based camera node.Fixed-point LS9/7 wavelet is used instead of CDF9/7 wavelet to decrease the complexity of computation. embedded block coding is improved for high efficient DSP parallel processing.
Some experiments results show that the improved JPEG2000 leads to a great reduction in implementation time, and hence saves energy consumption of camera nodes.
But sometimes, in my experience, pulling out the battery and try to insert it again, will solved the issue.
I hope this information help you to resolve yuor issue.
Thank You for using FixYa.
Mar 04, 2011 | Cameras
I'm trying to do sin-1 7/2 but it keeps saying math error.
That is correct: there is an error in your request. The range of the sine function spans the closed interval [-1, 1]. Thus the domain of the inverse sine function (the arc-sine) is the interval [-1,1]. However you are asking the calculator to calculate outside of the domain (7/2=3.5). If you are using the hyperbolic sine sinh, that is another matter.
Feb 18, 2011 | Casio FX-300MS Calculator
Sound is shorting out...its not the cable that I am using I have no trouble with it in any other amp. The overdrive channel does not work at all. And randomly all the effects will just decide they want to...
It sounds like the DSP processor is either about to go out, or is mostly there. Have a qualified amplifier technician take a look at the DSP. Also look up the cost of a new one.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Feb 12, 2011 | Crate Flexwave Fw120h 120 Watt Head Dsp...
Err:no sign chng
If you were trying to find the roots (zeros) of an algebraic equation with the solve( command or the interactive solver you might have supplied an interval where the function is always positive or always negative. If the expression is always of the same sign on an interval, the interval does not contain a root.
  • If you extend the interval, the procedure may not converge fast enough and the calculator may not find the solution.
  • Abetter way to do it is to sketch the graph of the function and use the graph to choose a reasonable interval that extends on both sides of the root, and a better initial guess.
If you were doing some financial calculations,
  • You attempted to calculate the I% variable when FV, N*PMT, and PV are all positive, or all negative.
  • You tried to calculate Irr( when neither CFlist, nor CFO is positive
  • You tried to calculate Irr( when neither CFlist, nor CFO is negative
Jun 19, 2010 | Texas Instruments TI-84 Plus Silver...
I keep getting no sign change error
To make things easy for the persons who would venture to help you, you should try to supply more information concerning what you are trying to do. We cannot always read people's mind.
If you were trying to find the roots (zeros) of an algebraic equation with the solve( command or the interactive solver you might have supplied an interval where the function is always positive or laways negative. If the expression is always of the same sign on an interval, the interval does not contain a root.
Feb 14, 2010 | Texas Instruments TI-84 Plus Silver...
Need to know how to use the calculator to solve confidence intervals for the mean
I know that you can do 1 and 2 variable statstics, several kinds of regressions analyses, forecasting a value, make statistical graphs. I give you a link to the manual, which you will read to see if the calculator perfoms the calculations you refer to.
http://education.ti.com/educationportal/downloadcenter/SoftwareList.do?website=US&tabId=2&paneId=17
Hope it helps.
Apr 15, 2009 | Texas Instruments TI-86 Calculator
Computers & Internet Logo
438 people viewed this question
Alun Cox
David Payne
David Payne
