Question about Canon LS-100TS Calculator
CANON TX-1210 E
A FRIEND OF MINE HAS THIS TYPE OF CALCULATOR BUT DE EURO FUNCTION DOESN'T WORK EXACTLY.
THE COEFFICIENT MUST BE 0,0248 AND IS INSTALLED ON 0,81;
WE'RE FROM BELGIUM AND THE OLD BELGIUM FRANK IS 40,3399 FOR 1 EURO.
WHEN WE INPUT 40,3399 AND PUSH THE BOTTOM 'EURO', THE RESULT IS 32,67,BUT IT MUST BE 1,OO.
CAN YOU HELP US TO INSTALL THE RIGHT COEFFICIENT OR TO SENT US DE USER MANUAL OF THIS TYPE OF CALCULATOR ?
E-MAIL : peggy.vandevelde@hotmail.com
namzyanzy
  • 435 Answers
SOURCE: I need a link to download a user manual
Please click the below mentioned link to download the manual:
Canon F-603 Manual
Thank you
Posted on Jan 07, 2009
SOURCE: Canon P170-DH calculator
http://downloads.canon.com/cpr/software/calculator/P170-DH-(USA-HWB).pdf
Posted on May 14, 2009
  • 7993 Answers
SOURCE: need uer manual for Canon P23-DH V calculator
Here is the Link to manual
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=250&modelid=15431#DownloadDetailAct
Enjoy.
Posted on Sep 12, 2009
hmerchant110
  • 7191 Answers
SOURCE: quiero el manual en pdf
Hola y bienvenidos a FixYa,
No sé español. Estoy usando Google Translate para enviar este mensaje. Si hay algún error, por favor perdóname.
Puede descargar el manual de instrucciones en formato PDF desde este enlace.
Gracias por usar FixYa.
Posted on Jul 30, 2010
SOURCE: Canon P100-DH Calculator manual
How to change the roller ribbon on my Canon P100-dh calculator?
Posted on Jun 27, 2011
Coeficient de determination
To get the coefficient of determination you need to be in STAT mode (press MODE and choose 1 for stat) and then choose 1 for line (it only works for linear data). Type in your coordinate points (type in the x value then press the button next to ENT that says (x,y) and then type in your y value and press ENT. Your screen should then say DATA SET = 1.00.
Enter a few more coordinates.
Then to get your coefficient of determination press ALPHA (the blue green button under 2nd F) and press the ( button (above it in blue you will see r). Press = and there is your coefficient of determination.
Apr 14, 2014 | Sharp EL-738 Scientific Calculator
How can i calcute inverse of a 3*3 matrix with my casio cfx 9850gb?
First you have to create it.
Press the [MAT] icon to open the Matrix editor.
(The screen captures below may not look exactly as on your calculator but they are correct.)
On line Mat A use the right arrow to enter one dimension. Press EXE.
Enter the second dimension and press EXE. See screen captures
Enter the coefficients, pressing EXE each time to validate.
Once you finish entering the coefficients, press the menu key to exit the editor.
select [RUN] and press EXE.
In RUN screen press [OPTN], then [F2:Mat] (See screen capture)
The following screen is displayed. (Ignore the command Del Mat A, I used it to verify that the matrix has a non-zero determinant.)
Press [F1: Mat] to type the MAT identifier.
Press [ALPHA] A to type in the name of the matrix (here it is A.)
To calculate the inverse you must use the sequence [SHIFT] [ ) ] to activate (x^-1).
Both commands (Mat A)^-1 and Mat A^-1 on the preceding screen give the same result, the inverse of A. An here it is.
Once you enter the command press EXE, the calculator says DONE and displays the result
Jun 25, 2011 | Casio CFX 9850GB Plus Calculator
How to do equations the papers that come with it doesn't explain it very well. Is there someplace where I can get a better explaination?
You can solve equations two ways: The EQN computational mode or the SOLVE application.
IN the EQN mode you can solve linear equations in one, two and three unknowns; the quadratic equation; and the cubic equation.
Enter the EQN mode by following the instructions on the following screen capture. Press 5:EQN
You have three types of equations.
Once you select the type of equations, a template is displayed where you enter the relevant coefficients.
Under each label (a, b, etc. ) enter a coefficient and press ENTER to move to the next. With a cubic equation, or a linear equation in 3 unknowns, you have to use the Right arrow to display the cells where you enter the value of d.
After you input all necessary coefficients press the = sign to get the solution.
To use the SOLVE feature, see the screen capture that follows. It comes from the Casio manual.
Good luck
Jun 24, 2011 | Casio FX-115ES Scientific Calculator
How do I find the roots of a third degree function using my calculator?
Here is an example for a third degree polynomial. (Screen captures are from an FX9860 G SD, so there may be some differences in screen appearance, but the procedure is the same.)
Press the [MENU] key and select [EQN]
Select the type of equation to solve. Press [F2:Poly] for a polynomial.
Choose the degree of the polynomial. For a 3rd-degree press F2
Enter the coefficients in the template
and press [F1:SOLV]
Here is the solution for the case I took.
Press [F1:REPT] if you want to enter the coefficients of another polynomial.
Jan 26, 2011 | Casio FX9750GII Graphic Calculator
How do i find the inverse of a 3x3 matrix on my Casio FX9750GII calculator? thanks
Create the Matrix in the Run/Mat screen
Press 1 to enter Run/Matrix screen
Press F1 >MAT. The next screen opens. Enter the dimensions (3x3)
In the template enter the coefficients. Press EXE after each item.
Press the AC button to exit thye matrix editor screen.
Press SHIFT 2 to type the Mat identifier on the command line.
Press the ALPHA key followed by A (if you are working with the A matrix.)
At this point you have Mat A on the command line.
Press SHIFT ) to get the x^-1 function. That is the one that calculates the inverse of a Matrix.
Nov 17, 2010 | Casio FX9750GII Graphic Calculator
How to solve matices as in finding the values to
I assume you want to solve a linear system of three equations i three unknowns (x,y,z).
  1. Turn calculator ON.
  2. If you do not see icons, press [MENU] key.
  3. Use arrows to move focus to [EQUA] and press [EXE]
  4. In new screen select F1: Simultaneous
  5. Select the numbewr of unknows (in your case 3): Press [F2:3]
  6. A table opens: it has 3 rows and 4 columns
  7. Enter the coefficients in first equation on first line (a1, b1,c1) and the constant term d1.
  8. Enter the other coefficients and the constant terms at the right places, pressing [EXE] after each entry.
  9. When finished coefficients and constant terms, press [F1:Solv]
  10. The solution vector (X,Y,Z) is displayed on next screen.
  11. Note: if the coefficients are integers, it is possible that the solution vector will be displayed as mixed fractions (exact solutions),
  12. If not, the solution vector will be in decimal format.
Mar 02, 2010 | Casio FX-9750GPlus Calculator
Correlation coefficient of sine regression?
The correlation coefficient does not have meaning (is not defined) for most regression models. Check you theory to make sure it exits for the sine regression.
An easy way to verify that, is to use the Command DiagnosticOn, accessible through the catalog [2nd][0] (CATALOG) . Press [X^-1] (D) to jump to first command that starts with D. Scroll down to DiagnosticOn, select it and press [ENTER]. Calculator replies Done.
Do your sine regression again. If the correlation coefficient has meaning for this type of regression, you will find it with the other statistical variables. You may have to scroll down the statistical variable list to verify the whole contents of the list.
Hope it helps.
Thank you for rating the solution.
Dec 13, 2009 | Texas Instruments TI-84 Plus Silver...
I am not able to do some functions on my TI-84 Plus calculator, such as: coefficient correlations. I was told I may need to reset my calculator. How do I do that?
To have the coefficient correlation show up when you calculate a regression, you must first turn diagnostics on.
The way to do this is press 2nd then zero. You are now in the catalog. Go to the d's in the alaphbetic list, highlight "diagnostic on" and press enter. You will be taken back to the home screen press enter and you get the word "done". The diagnostic is not on unless you get the word "done".
Now when you calculate a regression, the correlation coefficient will show up. It is designated as r = on the home screen.
Oct 02, 2009 | Texas Instruments TI-84 Plus Calculator
How do I find the correlation coefficient on my calculator?
You will find it on the same screen where you find the regression equation, the regression coefficients etc. However it is not defined for certain types of regressions.
Hope it helps.
Sep 26, 2009 | Casio CFX-9850G Plus Calculator
Canon LS-100TS Calculator Logo
245 people viewed this question
old marine
old marine
