Question about Behringer (UCA202) Sound Card
Beginners problem: "The selected device has no input controls."
I'm a bit of a newby with recording so this is probably something pretty elementary...
I've plugged in my guitar into input 1 of my UCA202, & that in turn to my mac... but when I select "USB Audio Codec" from the "Sound Input" menu it says "the selected device has no input controls."
I've just plugged it in with a regular guitar cable - I'm not sure if I need some sort of converter to split it into both inputs.
Any ideas or help would me much appreciated!
  • 2 more comments
  • kgasser2 Sep 03, 2008
    i have the same problem. i plugged my alesis multimix 8 usb into my macbook pro. i'm kind of new at all of this too. this sucks
  • Anonymous Dec 30, 2008
    Macbook and Fast Track Pro or Tascam US-122L, same problem
  • Anonymous Mar 15, 2009
    i have the same problem with my Behringer, XENYX2442
    seems like nobodies answering this all
  • Thunderthud Apr 04, 2009
    no input controls show up with UCA202. Tried every version of driver that I could find on Behringer website plus the Asio4all driver with same results. Have an M-Audio usb sound device which works fine on same computer.
2 Suggested Answers
  • 15 Answers
SOURCE: Sound is good, but guitar input doesn't seem to
Have you tried selecting the option for microphone boost under your sound card settings (If you are using a windows operating system)? Its a check box option.
Posted on Feb 14, 2010
I can't find the drivers for my Olympus Digital voice recorder VN-2000PC. What can I do? I can't tranfers my audio files to my PC.
Do you need the software/drivers for the VN-2000PC or the VN-2100PC? The software for the VN-2100PC is available here: . Select your OS and you'll find the software.
The VN-2000PC doesn't connect to the computer via a USB port. To transfer your files to a computer, connect the earphone jack to the line In (blue) jack of the computer with a 3.5mm to 3.5 mm audio patch cable. Use a program like Audacity to record the audio track during playback. Make sure to set the Audio input to Line In. (In Windows 7, click Start > Control Panel > Hardware and Sound. Under Sound, click Manage Audio Devices. Then select the Recording tab and set the input device.) Then set the recording device in the software as well. Click the Record button in the software and then start the play back on your VN-2000PC. You should see a flat line for a bit then see a wave form start. If the line stays flat, you haven't set the Line In device properly.
I hope this helps.
Sep 01, 2012 | Olympus VN-2100PC Digital Voice Recorder
How do you record to channels 9-24 ?
Press the select button for channel 9 (or any channel you're wanting to record on) and hold it down. While holding down the select button of your chose, press one of the "input (A-H)" buttons as you would if you were toggling on a regular computer. The Input button you select will become your new available track to record on. Be sure that the input button you select has a mic or something connected to it and its volume is adjusted to control your input level.
Sid from the SBL Network, Inc. - SoundLab
Apr 30, 2011 | Tascam 2488 Portastudio Multitrack...
Probably need to enable in control panel as per instructions below.
You may also need to check you have correct input device (wave) selected in your recording software
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 24, 2011 | CAD Microphones GXL2200 Professional...
Can i hook up a hdmi cable from computer to dvd recorder and record stuff from computer to dvd recorder
The HDMI port on your pc is an output device. That said, if your dvd recorder has an HDMI input or another input device then you can record from your pc to your dvd recorder. To do this, you will need the HDMI to A/V or anyother cable that your dvd recorder accepts as an input device. Another roundabout method would be to connect your computer to the TV which is probably already connected to your DVR for recording and record via that.
If you send your DVD recorder's model no. i can help you with exact instructions
Oct 27, 2009 | Dell XPS M1330 Notebook
No sound from microphone input or line input. says this device is working ok.latest drivers from driver detective. Aspire m3100 with win xp.All controls blanked out.
go to control panel / sounds and audio properties/( can you move the volume button?) if so then click the advanced button there and then on that window click options then properties then select the recording button and make sure that the microphone box is checked and anything else that you want to use for recording then click ok and select the microphone when the window comes up with the volume controls and check boxes for each device that you want to choose from to record( only one device can be selected
hope this is worth a fixya as all other ratings hurt our scoring
Nov 28, 2008 | Audio Players & Recorders
HD Video Recorder - CEC connection with HDTV
My first question would be, Is your Panasonic HD recorder CEC compliant? CEC means Consumer Electronics Control. That simply allows for the consumer to have better control over their Home Theater set up through the connection of you HDMI cable from their remote control without programing the remote control for every single device that is connected. If your recorder is CEC compliant the television should have automatically recognize the recorder and control you recorder via remote control (I am assuming that your recorder is an HD Camcorder, since your description was very vague). Once you connect your HD camcorder to your panasonic tv the tv should have turned on switching to the correct input and the same for any other CEC comliant devices. If your Panasonic HD recorder is not CEC compliant the you would have to start viewing your recorder the old fashion way, by using the recorder remote control or if your Toshiba remote is universal punch those codes in so that you can control your devices that way. If that don't work, try a different HDMI input and select the input and make sure your recorder is set to output on you tv. Hope this helps.....before I forget, check out this site to learn more about Consumer Electronics Control (CEC)
Nov 23, 2008 | Televison & Video
How do i transfer from tascam DA-30MK11 to computer
From my personal experience, and assuming that you want to do this purely in digital format in order to preserve quality, you need to connect an RCA cable from the digital (SP/DIF) output of the DAT machine to an SP/DIF input of a sound card installed into your computer. Please note that the sound card on your computer must have digital input capability. Also the Digital input (sometimes labeled ‘CD digital’) must be selected in your software as part of the recording controls. To do this, open Volume Control, click ‘Options’, select ‘Properties’ and then select ‘Recording’ (as ‘Playback’ is usually enabled as default), and select the ‘digital’ input. Then using a reasonably good a sound editor or other recording software, start recording keeping in mind that you should configure the software to accept whatever audio data format is used on the DAT tape (i.e. 16 bits, 44.1KHz, or 48 KHz etc) I’m my case the software usually displays a box with these parameters before starting to record. Hope This helps. Good luck!
Nov 03, 2008 | Tascam DA-30MKII
Sonar 6 Producer - palyback quality issue
I had this problem today whilst installing Sonar on my new laptop. It wasn't the click track. It was the playback glitching, clicking and rattling. I put the buffer size to maximium but it was still happening.
I got round it by downloading the latest version of ASIO4all (2.9 beta4) and installing it. I then opened Sonar 6, options, audio, advanced, then selecting ASIO in the driver mode drop down box. Then I closed Sonar and reopened it.
If you use one device for recording and playback it should work now but if like me you use seperate devices or if it doesn't work click, options, audio, general, ASIO panel, advanced options. Here you can select your inputs and outputs. Play around a bit here. Mine worked when the output of the playback device was selected and both the input and output of the recording device was selected.
ASIO4all sorted out my latency issues as well.
Hope it helped.
Mar 12, 2008 | Cakewalk SONAR 4 Producer Edition for PC
Teac rw-cd22 burning problem
You were right! I changed the cd and it does not do DA:D2
Feb 13, 2008 | Audio Players & Recorders
Vista 64 microphone not working
hmmm did you try a different mic, and exure its jacked into the mic in of your sound card.. If you have dual sound devices, ensure its in the correct selected device...
1.)To see which device you have as the selected device, Click Start, All programs / accessories / entertainment, volume controll..
2.)Choose Options and then properties
3.)In the mixer device drop down list, ensure that the correct device is selected. Click on the drop down list to see all aviable devices..
4.) Now under the Adjust Volume For selection select recording
5.) In the Show Following Volume Controll Box, select Mic,(make sure its ticked)
6.) Click Ok
7.) The mic and aother controlls will show up, under mic ensure select is checked..
1.)Start, All programs / accessories / entertainment / Sound Recorder
2.) Click Edit then Audio Properties
3.) Under Sound Recording Select the Appiorate device..
4.) Click Record and try it..
5.) Stop it and play it back..
Jan 13, 2008 | Creative Labs Sound Blaster Audigy LS...
Behringer (UCA202) Sound Card Logo
1,063 people viewed this question
Top Behringer Computers & Internet Experts
Brett Duxbury
Brett Duxbury
Are you a Behringer Computer and Internet Expert? Answer questions, earn points and help others
