SOURCE: speedometer cable 1998 Harley Road Glide
There is a little set screw that stops it from coming out. remove the set screw then I believe you have to unscrew it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_5bac37c3cb991fdb
SOURCE: I am installing a CB to my 08 Street Glide.
Contact Iron Cross Audio (www.ironcrossaudio.com). They should have a wiring diagram
SOURCE: What's the best way to repair the stripped inserts on Road Glide
There is a thing that acts like a pop rivit tool only it puts a threaded nut in the hole. Ask at your full service Ace Hardware store or other fine retailer in your area.
I think this will solve your trouble. You may have to drill out what is in there now.
SOURCE: Do I need to remove my fairing to replace the headling bulbs?
well you can please follow the below steps -
Remove the Fairing - 1. Unscrew all seven outer fairing fasteners using a Torx driver. These screws are located on the inner fairing near the windshield, the speakers, and the handlebar clamps.
2. Stand in front of the motorcycle. Tilt the outer fairing toward you and hold it firmly. Reach in and disconnect the wire connectors for the headlight assembly by hand.
3. Move the fairing to a work bench to continue the procedure.
Change the Headlights - 1. Remove the wire harness connectors from the back of each headlight that need replacement. Turn the plastic retainer counterclockwise by hand to remove each bulb from its housing.
2. Install the new headlight bulb or bulbs, with each bulb's wider ears on the bulb back plates oriented toward the top. Screw in the plastic retainer rings by hand.
3. Connect the headlight wire harness connectors to the back of each headlight.
4. Move the fairing back to the motorcycle. Reinstall the fairing, battery and seat in reverse order.
Please post comments if you need more help or information.........
Good Luck!!
Thanks
SOURCE: Ignition switch wont come out
you need to get a big screw driver pref. craftsman they have the biggest tip you have to align the tumbler all the way to the lock position. Note: turn the bottom one first then the top it is impossible to turn both at the same unless you spend 50 bones on the special tool that Harley f**king Davidson sells go figure more corporate bs. then put it in with the key in and turn it to desired position. Note 2: The handlebars must be turned all the way into lock position as if you were going to lock it. Hope all works
RedRider269
