Question about RIM BlackBerry Pearl 8100
I have just got a d-link dsl-g624t router the company i got it from told me unplug my orange moden plug this router in to phone line run disk away you go have done all this try to log in says unable to establish connection . have asdl/wlan lights on router have change settings on pc please help
  • 68 Answers
Unable to establish the WAN connection to your PDA? or via the ethernet cable to your desktop pc?
It would depend on the security settings you chose, whether or not you need to enter a wifi key, add the mac address etc. Your ISP should be able to troubleshot you through it aswell.
Posted on Mar 10, 2008
Theres no dsl light on the router, its a d link dsl2640b. so i need to know if its broke, the power light is on and the status light but no dsl light and no internet light on router, the pc is showing...
The flashing DSL light means that the modem isn't seeing the DSL signal on the phone line it's connected to. This might be due to modem failure, but it might also indicate a phone line problem. The most common trouble I run across is an unfiltered device connected on the line that interferes with the DSL signal. Other than the modem, all devices (phones, fax machines, security systems, etc.) need to be connected to the line through a filter. Check to be sure something hasn't been connected without a filter. Sometimes a phone gets moved or a new phone is added that gets plugged in to a handy jack without being filtered.
If you can, try connecting another modem to the line. You may be able to borrow one, or find one at a resale shop. I see them quite often for only a couple of dollars, leftover from people changing to FiOS or cable service. This can help determine if the modem is responsible.
One final possibility: your DSL service has been cut off. I've had two cases where loss of DSL was a phone company issue that they needed to fix at their office. (One following some wiring work done in apartment building, the other when service was mistakenly disconnected from the wrong customer.)
This kind of trouble can be a headache to solve, but it can be solved. Good luck and thanks for using Fixya!
May 21, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
I am trying to access the internet wirelessly from a lap top through a D-Link DI-624 I went throught the steps 1. plugged up the router 2. unplugged the DSL box 3. plugged up the ethernet cable to the DSl...
Unplug the power cables from both your DSL modem and D-Link router.
Verify the Ethernet cable is plugged into both your DSL modem and the D-Link router.
Plug the DSL modem power cable back in and wait for the self-test to finish.
Plug the D-Link router power cable back in and wait for the self-test to finish.
Plug your laptop into the D-Link router using an Ethernet cable.
Can you access the D-Link configuration page now?
Check to see if your computer is getting an IP address from the D-Link router.
Here's how to do that, assuming you're using Windows.
Hold down the Windows key on your keyboard then press the letter R.
In the Run dialog box type 'cmd' (without the apostrophes).
Click OK.
In the command prompt window type 'ipconfig /all' (without the apostrophes).
Press Enter.
Look for the line that reads 'Ethernet adapter Local Area Connection'.
Verify that 'Dhcp Enabled' is set to 'Yes".
Mar 14, 2011 | Computers & Internet
I have been using my DI-524 for about two years now without problems. I went away on vacation, left my computer and routers running and now when I get home I cannot connect nor see the wireless connection...
When you say your rebooted the modem and router, do you mean you power cycled them both? If you're unfamiliar with power cycling, this the technique:
1) Unplug your main Cable or DSL line from your modem.
2) Unplug the power from the modem.
3) Unplug the power from the router.
4) Wait about 20 seconds.
5) Plug the Cable or DSL line into the modem.
6) Plug the power into the modem.
7) Plug the power into the router.
Make sure that all computers are shut down and completely off. After you have power cycled, reboot the computer(s). If you still do not see the SSID (the name of the network), then someone probably hacked into your router and changed the password. Here's how to overcome that:
1) Unplug the power from the router.
2) Press and hold the Reset button on the router for at least 30 seconds.
3) Plug the power into the router.
4) Open an internet browser (Internet Explorer, Firefox, etc.).
5) Type in the IP address of your router. For this router the IP address should be 192.168.0.1
6) You should be at a login window. The User Name is admin and leave the password blank.
7) You should now be in your router's configuration options. You should enable the highest security possible, then change the default User Name and Password to something secure, with letters and numbers.
My information for you router came from this link:
http://www.myacrobatpdf.com/8429/dlink-wireless-router-dl-524-setup-instructions.html
Jan 13, 2010 | D-Link AirPlus DI-524 Wireless Router
The red led light on the internet connection on my d-link router is on. i cannot connect to the internet now. i have a green light above the dsl connection and their is one other green light on. i have...
1st: Have you paid your bill?
2nd: Have you power cycled?
Full Power Cycle is as follows:
Turn off all components plugged into the router(Computers, Printers, etc.) Unplug the power from the router. Unplug the data cable(DSL, Coax) going TO the router. Wait aprox. 1 minute. Plug data cable and power cable back into router. Wait about 1 minute. Turn computers back on. Problem Solved?
If not and you're using DSL make sure all DSL filters are in place and that none have come undone. Make sure the phone line is still plugged in. Problem Solved?
If not contact your ISP and ask if they are doing any maintenance in your area that may by effecting your service. Ask them to perform a line test on you. If all else fails ask them to have a technician come out and help solve the issue.
Oct 23, 2009 | D-Link DI-704P Router
Need drivers for DSL-G624t wireless router
If you're connecting to the router by ethernet cable or wirelessly, you dont need drivers unless you mean the drivers for the ethernet adapter and/or wireless adpater in your PC.
If this is what you're after, your PC's manufacturer's website is the best place to look if you dont have them on CD/DVD.
If you're connecting to the router by USB port, then the D-Link webiste should have the drivers for downloading.
Sep 13, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Have SBCglobal with 2wire but want N wireless capability
Follow the dots -
2 wire DSL wire to back of DSL modem.
Ethernet cable out of DSL modem, to current router (if you have one).
Ethernet cable out of current router (if you have one) to new Wireless N router.
If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
Jan 24, 2009 | 2wire 2700HG-B Router (2700HGB)
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Dlink 2640b cannot get both internet and dsl to work together
Unplug both devices,and remove the cable/dsl line input to modem, wait 5 minutes, plug cable back it, then turn on modem, wait a minute, then plug in router.The signals should mesh.If not, buy a new router, theyre cheap!~
Dec 14, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
How do i connect a d-link dsl-g624t to sky broadband
you can connect a d-link dsl-g624t to sky broadband by connecting the wire in to the appropriate slot or you can connect your d-link into the PCI slot on your motherboard
Nov 01, 2008 | Computers & Internet
RIM BlackBerry  Pearl  8100 Logo
158 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
