Question about EPoX EP-4PLAI Motherboard
Cpu how do i know if my cpu have a problem or overheat?i heard a long beep when i turn on my pc..
  • enigma pulp Mar 09, 2008
    cpu or board problem?
  • 75 Answers
Can u this in your cpu, just remove the Ram & Video Card Clean the contact poin of Ram & Video Card of eraser, and if your CPU Have A heavy Dust clean it with air blower, there are times the dust cost the malfunction of cpu.
Posted on Mar 09, 2008
Hi My compuer won't boot up it has a msi km2m motherboard I heard 1 beep I changed the power supply and made sure the ddr was seated and tight now i get no beeps but does not display anything on the...
Do this, first disconnect your memory into motherboard slot and then power on your PC. if you hear repeated beeping means no memory installed, the motherboard work fine. try to insert again your memory. if your memory are two pcs. insert only one memory and then power on again your PC. (only one by one insert memory for testing so you can trace if one of your memory was defective).
Try this,
Motherboard beeping troubleshooting guide.
(Note: before touching computer parts like motherboard, memory, video card and specially hardisk the very important parts of PC. discharge your static electric into floor ground or the case of your power supply. need also external PC speaker. if no onboard PC speaker ).
No beeps means short circuit, no power, bad processor, open parts or defective parts specially capacitor parts.
See this sample picture of capacitor leakage and defective.
One beep means everything is normal the motherboard work fine.
Two beeps means cmos bios error and defective.
One long beep, one short beep means motherboard need tracing defective parts specially capacitor.
One long beep,two short beeps means videocard problem need tracing of parts CPU and blower fan for working good, also capacitor parts for leakages.
Three long beeps means keyboard error some key press stock up or modules parts defective.
Repeated long beeps means memory not detected, loose of defective
Continuous Hi-Lo beeps means CPU overheat or loose blower fan with heatsink into motherboard chassis.
Try this solution for your motherboard troubleshooting solutions.
Hope this information can help you.
Thanks for using fixya
Aug 12, 2011 | MSI KM2MCOMBOL-6738-010 Motherboard
Got a screen message that fan is not working. Now when I turn on the computer it just beeps at me. What do I need to do to solve this problem?
Open cover and switch it on, check if fans turn (assume CPU fan), if not switch it off and remove from mains, replace faulty fan or clean the fan with a small brush and vacuum cleaner might be clogged with dust. If this fails check bios settings for CPU temperature and adjust accordingly, do not exceed recommended CPU temperature, or CPU will overheat and eventually be destroyed.
Computer shuts down and beeps due to over heating and bios shuts down machine as a precaution.
Jan 15, 2011 | HP Pavilion m7650n (RF254AA) PC Desktop
My desktop pc just beeps and the monitor does not do anything
Welcome to FixYa
Dear User,
First Re-seat your RAM ..check all cables connected properly inside CPU...Also let me know how much beep you heard .It is to provide a better solution..
Thanks for Connecting FixYa...
Dec 05, 2010 | HEWLETT-PACKARD Hewlett Packard Compaq...
No input signal
that is the problem of cpu not a monitor to confirm disconnect signal cable and power on. monitor will show "no signal check signal cable" it means that monitor is ok and fault lies in cpu .then open the cpu and disconnect ram and listen the beep. contineus beep should be heard then ram is faulty replace it. if no beep heard then motherboard is faulty .
Mar 08, 2010 | HP vs17
I hear beeping tone in my cpu when i plug it
When the computer makes those funny sound via the system speaker, it's not doing it because it wants to be heard. The computer is trying to talk to the operator/technician and tell them what's wrong.
So here are some codes to give you an idea of what might be wrong with your PC.
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Nov 30, 2009 | Computers & Internet
For 3 weeks My Dell 4700C had difficulty starting. It took from 3-6 attempts to start. In the 3rd week the fan began to sound like a plane starting up. It would get louder and louder until I thought it...
hi have you heard any beeps when pc starts they tell you whats going on 1 beep all good and so on what ive found over the years is some times things need to be reseated turn pc off unplug try to start to drain power touch psu with hand on metal to earth then take ram out and reseat it same as batt take out try to start with no pwer to drain board again but in go in to bios change any setting like which hard drive you want to start first tell me how that goes cheers mate ps i never heard of cpu being limited by ram its you motherboard and os system which deside how much ram you pc can handle 32bit can read 4 gigs 64 bit over 12gigs
Oct 17, 2009 | Dell Dimension 4700 PC Desktop
T5082 has stared overheating,
1) With the case open, turn on the computer and make sure the fan(s) is working properly.
2) This is NOT for the faint-of-heart! One of the most common causes of overheating requires you to remove the CPU (Intel P4 processor chip in your case), clean it, and re-install it. There is a thin layer of gray goop between the CPU and the Heat Sink (the thing that looks like a radiator, under the fan) which is designed to transfer heat from the CPU to the Heat Sink. This goop is called "thermal paste." If it gets dried out, it will not transfer heat any longer, and your CPU will overheat.
If you are willing to attempt to remove your CPU, clean it, and put a new layer of thermal paste on it, please reply and I will help walk you through the process. You should be aware that there is a possibility that you may completely destroy your CPU if you make a mistake.
Jan 08, 2009 | E-Machines T5082 PC Desktop
Beep sound when swith on
good day,
a beep from your cpu system means that there is an error. and since there is a "cpu overheat" error, it could mean that your cpu cooling system (or its fan) is not working.
the shutdown is a defense mechanism of your cpu in order for your cpu not to self distract.
have the cooling system replaced as soon as possible to avoid further damage.
i hope this will help
Oct 13, 2008 | Intel D845GVSR Motherboard
How to replace CMOS battery
Memory error
if the laptop is running and even boots up and the beeps continue it is the CPU (Overheat, not seated, cache memory error)
Apr 12, 2008 | Toshiba Satellite A105 Notebook
Problem..
you may have a faulty motherboard, im sure its not the aanswer you wanted to hear but generally beeps mean errors!!!
Mar 09, 2008 | EPoX EP-4PLAI Motherboard
EPoX EP-4PLAI Motherboard Logo
Top EPoX Computers & Internet Experts
Marvin
Marvin
David
David
Steven Wander
Steven Wander
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
