Question about Nikon Coolpix S220 - Aqua Green 2.5" LCD Digital Camera
Cost for camera repair-nikon coolpix s220
How much the lens error wiil cost...as one of the guard pin has got damaged.....my camera is in warranty period...
    New Friend:
I have the same problems and I just called the Nikon Company. They say its about $100-$140!! AND I WAS LIKE F*** YOU
Posted on May 12, 2010
  • 2,517 Answers
Depend on the country. approx cost 20$ - 40$. Thanks.
Posted on Mar 14, 2010
SOURCE:
I have a nikon coolpix digi camara and when i turn it on it says lens error .How can i fix it
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Sep 28, 2011 | Nikon COOLPIX S220 Digital Camera
LENS ERROR SHOW NIKON S220
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Re Nikon S220 digital camera. Lens error noted -
A tiny bit of grit can jam the gears of the lens. Sometimes a tap can knock it out. Try this at your own risk. Take out the batteries. Don't hit the camera on a hard surface, just use you hand. If it hurts, that is too hard. Try lens down, then all the sides.
May 29, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Nikon S220. Lens error. Turns on but displays lens error only.. Cannot take pics
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 15, 2010 | Nikon Coolpix 2200 Digital Camera
Lens error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
May 03, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Lens error in nikon s220 digital camera.
Yes you right. After fall down the lens internal guide pin is damaged and thats why its happens. a912d76.jpg So visit your nearest service center for repair. Thanks.
Mar 14, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
S220 Coolpix has a lens error problem, turn camera on tries to focus (Lens moves in and out making a weird noise) but comes up with a lens error problem
Did it drop? sounds like the motor is trying to move the lens as you need, but the lens has come out of its tracking. If there is no outside damage and you still have warranty left, you should get it replaced, otherwise it means opening it to place the lens back on its tracking, but this can be tricky.
Jan 05, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
My sister has a Nikon Coolpix S220 and she dropped the camera on wood floor, now the lens is at a 30 degree angle.
Sorry, but there is no DIY fix for the lens problem, and any attempts at homebrew repair will likely worsen the problem. The camera needs professional repair, so I suggest that you take it to a camera shop (not the camera department at a large store) or contact Nikon customer service via the Nikon.com web site. Be sure to get a firm price before committing to repairs -- the cost to fix it may be close to the price of a new camera, and repairs typically only carry a 30-day warranty.
Dec 06, 2009 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Nikon Coolpix S220 - Aqua Green  2.5" LCD Digital Camera Logo
996 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
