I have just purchased a Toshiba Integrated Digital LCD TV and I can't seem to run my DVD and Video player through the TV. I'm probably not connecting it right, but don't know what else to try. Thanks for your help.
    Sergeant:
  • 247 Answers
The DVD and video player have HDMI. Component, S-Video and RCA audio/video output connections that need to be connected to the appropriate inputs on your TV. You select the type of connector and cable to use.
HDMI provides the best quality, if available and works for both audio and video.
The TV's, DVD's and video player's manuals describe how in detail. Look at the connection instructions and diagrams. You then must select the correct input on the TV to play each source.
Posted on Mar 09, 2008
Yamaha RX V992, HDMI 2 mode
tell toshiba dvd 720 p only and use bitstream outsetting in audio of dvd player ok if that dont do it run dvd directto tv then digita opti cable from tv back to sterio ok
Jan 21, 2008 | Yamaha RX-V992
I wish to connect a HUMUX digital video recorder PVR-9300T and a TOSHIBA HDD & DVD video recorder RD-97DTKB to a SUMSUNG LCD TV LE32S73BD
Get a tech to help you, There is to much info to try an (Explain) in writeing how to do it (Properly)
Nov 09, 2012 | Televison & Video
I'm trying to hookup my Toshiba DR430KU to an older tv that require an RF Modulator. I get a skewded sideways picture. Does This DVDR compatable with a RF Modulator?
Probably not. Better picture results are achieved with either S-Video, standard RCA AV cable (yellow-white-red), or YUV component cable (red-green-blue) (component output does not have audio - this requires extra cable to be connected). The video via either one of these 'AV' connections is stunning (based on a standard 16:9 LCD TV using a Panasonic DVD recorder).
RF tends to be lower quality - as opposed to AV/digital input. AV input/YUV component handles digital better. No one connects their DVD devices to their TV via RF (either directly to the antenna socket or with a modulator/attenuator) anyway. Because a VCR is mostly analogue, it will work fine with an RF connection, but DVD is digital, and so won't work as well, if at all.
RF also goes through the tuner in a TV, creating cross-interference, whereas AV is a direct input and is separate to the tuner.
I would say an RF modulator would not be designed to handle the output frequency that your DVD device generates. Throw the modulator out, or perhaps get another TV, or use RCA cables instead if the TV has AV inputs. Whichever is cheaper and easier, but don't use RF accessories except a standard antenna if/as required.
Apr 27, 2011 | Toshiba DR-430 DVD Recorder
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
Our Toshiba 15LV505 15.6-Inch Widescreen LCD TV with Built-in DVD Player, purchased in 2009 is now flashing the onscreen message Digital strength is weak. We have it connected to cable TV. What can we do...
Hello
Hust connect your TV to an external antenna, and set it to auto tune, and see it stores all the transmitting channels at that time, and recieving channels are clear and crisp. If it does, your TV is perfect, and the trouble is with the settop box. Either the set top box doesn't get enough signal to process or its internal digital processing stage is faulty. It should be repaired. If TV doesn't accept of the accepeted signals are weak, the tuner of the TV is faulty, and should be repaired. OK.
Feb 17, 2011 | Toshiba MD14FP1 14 in. TV/DVD Combo
ON-LINE INSTRUCTIONS???
One of the most recognizable makers of TVs in the world is Toshiba. The company's TVs are found in every major electronics store at a reasonable price. Packed with features, they have a model for everyone, whether it be LCD or older, tube-based CRT technology. Toshiba T.v are fairly easy to operate. Basic functions
  • Before you do anything with your Toshiba TV, you have to plug it in to a wall outlet. After plugging it in, locate the power button on the front (or on the remote) and turn on your TV. Depending on if you have cable TV or not, you can use the channel functions to flip between your favorite channels. The "Menu" button is useful to access advanced settings, like channel detection, parental controls, closed captions and picture controls.
  • Using video inputs
  • You can connect a variety of devices to your Toshiba TV via its front, side or rear inputs. If you look at the back, you'll see a variety of audio and video inputs to connect virtually any kind of device. You should see a few kinds of video inputs: Composite and s-video (for connecting older technology like VCRs and cable boxes), component video (for connecting older DVD players) and HDMI (for connecting digital technology like receivers and Blu-Ray players). Audio inputs are analog (red and white) or digital (coaxial and optical). Use digital connections when possible to ensure the best quality.
    To connect VCRs and DVD players, simply connect the proper cable to their audio and video outputs, then match the cable to the proper inputs on the back of the TV. Make sure everything is secure and take note of which input you connected it to. Now, tune your TV to the proper input by pressing "Video" on the remote.
  • Maintenence and tips
  • Your Toshiba TV is a sensitive electronic device, so precautions should be taken to keep it in top working order. If the screen gets dusty, wipe it with a dry, soft cloth. If you own a Toshiba plasma TV, be aware of burn-in and ghosting problems. Avoid watching programs that have static images is left on the TV for hours at a time. If you have a flat-panel Toshiba TV, consider getting it professionally calibrated to get the best possible picture
  • Dec 02, 2009 | Cell Phones
    There is no colour on the movie
    Make sure you have the cables hook up right. If you are running component mode it takes three for video blue red and white ends. If you are running composite it takes red, white, and yellow.
    Nov 20, 2009 | Toshiba HD-A20
    Using remote to play video DVD
    You need to bypass your A/V tuner for your video connections (if possible). Plug your video directly into the TV and audio into the tuner. This will also give you a cleaner signal/picture as it does not have to processed by your tuner BEFORE it goes to your tv. Think of it as cutting out the middle man. Your tuner is best left for powering your speaker and not controlling your video despite all of the available connections in the back of it.
    I would also get rid of your VHS and cassette players as they are dead technology. Clean up your system and remove the clutter. This will lessen your chance of getting interference. Good luck!!
    Oct 01, 2008 | Toshiba 32D46 32" TV
    Proper input for TV audio signal
    Do you have your DVD player running through your receiver? You want the red and white (audio) cables to go from your DVD player to your receiver and the yellow (video) cable to go from your DVD player to your TV. Separate the red, white, and yellow cable into separate strands if you need to, but be careful not to tear the insulation. They should pull apart fairly easily. If I'm totally off or you're using a coaxial or component video/audio cables or a fiber optic cable, let me know. Hope this helps
    Feb 16, 2008 | Pioneer VSX-D812 Receiver
    Televison & Video Logo
    64 people viewed this question
    Top Televison & Video Experts
    Marvin
    Marvin
