Question about Nintendo Wii Console
Disc error when l go to put disc into consoles l cant get it in the console wont take disc in at all
  • 101 Answers
Try pushing it may be the belt of the drive has broke....:-(
Posted on Mar 09, 2008
  • 34 Answers
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Mar 06, 2009
  • 3 Answers
SOURCE: console wont read any disc and states an error has occured
the disc mite hav the wrong region code...coz u prob bought it in a different country or the shop sold you a crappy second hand disc or they buy in game stocks from other countries!!!!
if tht is the case then you can buy this disc thing tht sort out ur wii's regional code
Posted on Nov 26, 2008
  • 46 Answers
SOURCE: 2 discs stuck in console
WOW!!! I am so sorry that this happened. Nintendo products are really hard to open. If you cant wedge the game out with a small screwdriver, dont worry about the game, here are the directions on opening it. Just copy and paste to word so you can see the whole thing easily.
How to open your Wii Console Step by Step Instructions
To disassemble:
  1. Flip the device upside down and remove the small silver Phillips screw. Once out, remove the battery tray from the console.
  2. Next remove the rubber foot directly above this battery tray. Also remove the three square white stickers from the bottom of the Wii. The rubber foot and the sticker are covering hidden screws. Figure 3 provides a shot of where these screws are located. NOTE
    Hiding screws under stickers and rubber pads is a common method used by electronics manufactures to help increase the aesthetics of their devices, as well as prevent people from easily locating screws and taking apart their products.
  3. Unscrew the two Triwing screws and three Phillips screws from the bottom of the Wii.
Figure 3 - Bottom Screws
  1. Flip the Wii over onto its right side. Locate and remove the two rear rubber feet and the two rectangle stickers near the faceplate.
  2. Remove the two silver Triwing screws in the holes and remove the two black Triwing screws on the faceplate (Figure 4).
Figure 4 - Left side screw locations
  1. Flip the Wii upright and carefully remove the two socket covers. They come right out with a little wiggling.
  2. Remove the three black Phillips screws from the black plate (Figure 5). Note the one closest to the faceplate is the longest and will need to go back into that hole when putting the Wii back together.
Figure 5 - Top black plate screw locations
  1. With the screws removed, carefully pull off the faceplate of the front of the Wii. You will need to disconnect the red/black wire plug from the Wii to remove the faceplate completely. Figure 6 shows what is hiding under the faceplate.
wiifig06.jpg Figure 6 - Under the Wii faceplate
  1. Remove black plate from memory/controller socket area.
Remove two silver Phillips and two silver Triwing screws from memory/controller socket area (Figure 7). wiifig07.jpg Figure 7 - Topside screw locations
Lay the Wii on left side (with the ATI and Nintendo logo facing you) and slowly work the right side cover of the console off the device.
This will take a little bit of force. If something appears to be stuck, double check to ensure you removed all the screws.
Locate and remove four screws holding DVD reader in place. Two are located in plain site in the middle of the unit. Two are located near the front of the Wii inside the DVD unit (Figure 8). wiifig08.jpg Figure 8 - The insides of the Wii
Slowly tilt the DVD player upward toward top of Wii. There are two wires that need to be disconnected before you can safely remove the DVD unit. One is a plug type of connector that only requires a little tug. The other is a circuit strip connector that requires you to lift the brown catch, which will release the pressure holding the strip in place (Figure 9). Do not break this!
Posted on May 13, 2009
  • 1093 Answers
SOURCE: console wont play games
This can happen as the sensors on the back of the DVD drive overheat, I mean of course check that the discs are clean but it sounds like you will have to stop the heat build up to get your Xbox 360 working again.
You can do this with a good guide or send it in.
Posted on Oct 30, 2009
SOURCE: games wont play says disc error
Replace the laser. This is the cheapest and easiest fix for this problem. You can get one of ebay for under $15
Posted on Nov 03, 2009
damonumber5
  • 340 Answers
SOURCE: Swapped Hitachi boards now have "Put disc into xbox 360 console"
Have you put the sata cable from your drive to your motherboard in upside down? if your not sure turn it around and see if it works.
Remember thumbs up if this works.
Posted on Feb 03, 2010
Testimonial: "I wouldnt of expected the laser would need adjustment, great options i appreciate it."
My wii just stops to blank screen wit white writing and says, error and to remove disc and turn console off which wont turn off by button so has to be plugged out and to go to owner manual which i cant...
Situation:
The Error Message: Error Has Occurred appears when loading or playing a game disc.
Applies To: All Games
What To Do:
There is likely a problem with the Wii console. Click here to begin the repair process.
Nov 15, 2012 | Nintendo Wii Console
My discs wont load
You could find the manual on the internet by google. Im afraid that it's possible that it possibly broke the disc drive or the part of the drive that automatically loads and ejects the disc.
May 17, 2012 | Nintendo Wii Console
XBOX360 WONT READ DISC
Though i fixed the Disc Read Error myself within anhour but please test the below method at your OWN Risk. Please alsonote that microsoft is no longer providing Extended warranty for E74Error.
Check out this DIY Video Guide,that explains step by step instructions to fix Disc Read Error yourselfwithin an hour. It also provides the money back guarantee in case youare not satisfied. As i fixed my Xbox myself so i thought to share itwith you guys....
Apr 06, 2009 | Microsoft Xbox 360 Console
My wii console wont take any disks.I try to put the disk in but it wont go in. The light lights up but nothing happens after that.Everything else works, like it will go to the menu screen but i cant play...
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.........
Mar 04, 2009 | Nintendo Wii Console
Wont play disks
Feb 28, 2009 | Nintendo Wii Console
PS3 WONT LOAD OR READ DISCS. FROZE ON MAIN MENU GAME DISPLAY.
Check out my blog for help fixing the problem.
Start with # 3 on my 5 Most Common Errors entry.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Feb 26, 2009 | Sony Playstation 3 (PS3) Console
Console wont read any disc and states an error has occured
Nov 22, 2008 | Nintendo Wii Console
Wont read disc
Unplug all of the cords from the Wii, TV, and outlet. Wait an hour and plug it all back in and it should work. If it does not, then you will need to call Nintendo to get it repaired or replace the laser yourself. Thanks, I hope this helps!
Aug 27, 2008 | Nintendo Wii Console
Dropped console, now get 'unreadable disc' erro
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Apr 08, 2008 | Microsoft Xbox 360 Console
Nintendo Wii Console Logo
65 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
