Hi, I have a laptop HP Pavilion ze2308wm When turned on it displays the startup screen with the HP logo and gives directions to press
Have you tried an external keyboard, either PS2 or USB depending on what ports are available?
Did you try booting off a CD?
Is the battery fully charged?
Have you checked the DC input jack? These are notorious for failing. What happens it the center pin becomes loose causing arcing, low power input, over heating of jack, and sometimes melting of AC Adapter power connector where it plugs into laptop.
If none of this works most likely a motherboard fault.
You can get a replacement motherboard on EBay for around $80. Hard to tell if these are new or used and are shipped out of Hong Kong. I have bought many things on EBay from HK with good luck. Your results may vary (disclaimer).
You can buy new ones for around $150 from various locations. Part number for motherboard is 394252-001. Here is one I found.
Good luck, let me know what happens.
hi jim4984, tried usb keyboard but same no response, I guess due to booting hasn't gone past bios and usb driver still not loaded up?
