Question about Logitech 967437-0403 Keyboard
Some Keys are not working
I have a logitech internet pro keyboard.
Some keys like Escape,down arrow,keypad 2,home,end stopped working.
I tried opening it but its stuck in the clips . . .I looked at the esc(because it was on the top) but it seemed normal.
Its really annoying and i don't know what to do.
Please someone help.
  • 3 more comments
  • Anonymous Apr 25, 2008
    Hello i m using internet pro keyboard of logitech.Ants have gone inside the keyboard i tried opening it but i failed to do that,because it is getting strucked.What is the solution for this?
  • neanea37 May 12, 2008
    i have a hp dv6327 cl lap top computer and some of my keys 2,W,S, X aren't working I have to use the on-screen keyboard to use these keys. Ho do I solve this problem
  • Anonymous Aug 02, 2008
    Down arrow key and keypad key 2 not working at all. It's not a hardware problem I believe.
  • Anonymous Feb 06, 2009
    exactly same
  • Anonymous Mar 15, 2009
    internet pro key board some keys are not working.
    Brigadier General:
  • 3,614 Answers
There are two reasons you may need to clean a keyboard: the slow accumulation of gunk, and keyboard emergencies such as dumping a cup of coffee on your keys.
If you dump liquid on your keyboard, shut down your computer immediately, disconnect the keyboard, run it over to the sink, and turn it upside down to drain. If you spilled a sticky liquid, such as Coke on the keyboard, you can squirt water on the upside-down keyboard to rinse it, says Mike Nadelman of computer-repair.com. Don’t submerge the keyboard in water; let it dry upside down.
Compressed air is the keyboard cleaner’s best friend, and it’s the quickest and easiest way to get dust and hair out of a keyboard. I started by disconnecting the keyboard, carrying it over to a clean surface, and giving the keyboard a few good zaps with the cold gas. I kept hitting the keyboard with the compressed air pretty often throughout the cleaning process.
To cope with stained keys and the hairs trapped under the plastic, though, start popping keys off. Keyboard manufacturers don’t recommend popping off keys, but it’s generally harmless if you handle the keys gently. Stick two plastic knives under opposite sides of a key and pry upward, exerting equal force on both sides. The key is guaranteed to fly off across the room, but that’s how you do the job without breaking the key or the switch. Once keys are off, they’re actually washable. Rub stains with a wet cotton swab dunked in soapy water, which does the trick for most messes. Save the alcohol for truly stubborn gunk, because it can damage the ink on the keys, and never, ever, ever use ammonia-based solvents such as Windex.
At first, avoid the big keys, such as the Spacebar, SHIFT, TAB, BACKSPACE, CAPS LOCK, and ENTER. Those keys may be loaded with springs or hinges that make them difficult to remove or replace.
If your keys feel sticky or are grinding, a drop of a light machine oil, such as WD-40, placed in the center of where the key strikes the keyboard, on the hinge, or on the spring (if your key has one) should do the trick, Nadelman told me.
As you remove keys, you’ll need to remember where to put them. Some people make diagrams or put them on the table in the exact order they were in on the keyboard.
Posted on Mar 09, 2008
No numlock key on MX5500 logitech
The ten-key keypad is used for the calculator too. The button to swith between these modes is just aboc=ve the key and has a picture of a calculator. To use directional arrow keys, this keyboard comes with it's own separate arrow keys located under the delete button. They felt no need for directional function, number input function, and calculator function.
Aug 16, 2014 | Logitech MX5500 Keyboard/Mouse
K200 keyboard keys not working
daddyodevil try this push them down hard 1-2 sec.work on my keyboard.
Apr 09, 2013 | Logitech k200
Gateway MX6124 laptop: some keys on the right side of the keyboard display numbers instead of letters. Keys involved and actual display are: Row Starting with q: u=4, i=5, o=6, p=*, Row Starting with a:...
Your computer is in keypad mode. To check, turn off your Num Lock. On my system that disables the embedded keypad. To fix, go into setup (usually F1, F2 or delete when booting). Somewhere you should find a setting for using the embedded keypad. Mine has two options, Fn Key Only and By Num Lock. Yours may be different. One activates the embedded keypad, which you are seeing. Try the other setting.
Apr 25, 2010 | Gateway MX6124 Notebook
Pressing arrow keys on my Logitech keyboard flips view on monitor
problem might be with your key board...but you can disable rotation in monitor display properties
Oct 01, 2009 | Logitech Internet 350 USB Keyboard
Arrow keys can not work when i press and hold it. I used the arrow key for race gaming, where the up arrow, down, left and right are gas stroke, brake steer left and steer right. but everytime i press and...
normal keyboard for logitech may have issues with multi keystrokes at once.. try upgrading to the g11 and you will get better results. or if your not into upgrading by a controller and use the profiler.
Jul 17, 2009 | Logitech 967437-0403 Keyboard
Logitech S 510 keys quit working
The SUGAR causes a very sticky effect to the electronic contacts. The keyboard wil eventually eiter TOTALLY stop working or u will always have a few ones that wont work. .... Not rerally repairable
Jul 08, 2009 | Logitech S 510 (967555) (DH967555)...
Logitech keyboard,s keys are not working
Modern keypads arent as great as old ones where each key had its own switch and you could just open and fix it. new keypads have everything interconnected inside them. The only thing to do is buy a replacement, But if you really love this one keypad, you could try and clean it out with a blower and make sure the keys that are failing arent failing because of dust or unwanted debri.
Jun 20, 2009 | Logitech Keyboards&Mouses: Delux Plus...
CLOCK RESET
Press the FN + F9 keys until the time and date appear on the LCD display.
press the FN + F10 keys to go into the Set Mode.
Use the left or right arrow keys to select the hour.
Change the hour by using the number keys on the keyboard or by up and down arrow keys
Use the right arrow key to select the minutes and change the hour by using the number keys or by using the up and down arrow keys Press the right arrow key again to choose the 12-hour or 24-hour format with the up and down arrow keys.
To change the date, use the right arrow key again and use the up and down arrow to select the month. To change the day, use the right arrow to select and the up and down arrows to change the day.
When you are finished, press Enter on the keyboard to exit Set Mode.
hope this helps
Apr 02, 2009 | Logitech Cordless Desktop MX3200 Laser...
I need a owner manual for a logitech keyboard 431879-0001
You can go to;
http://lsearch.logitech.com/search?q=manual+keyboard&getfields=*&filter=p&hl=lang_en&btnG=Search&region=AMR&rq=0&sort=date%3AD%3AL%3Ad1&entsp=a&client=logi_us_en&lr=lang_en&entqr=3&accept-charset=iso-8859-1&oe=UTF-8&ie=UTF-8&style=us_en&proxystylesheet=logi_us_en&charset=utf-8&country=us&cl=US%2CEN&la=en&ud=1&language=en&getfields=*&output=xml_no_dtd&site=logi_us_en_products
Scroll down to your keyboard.
Click on "How to"
How to Use Your Keyboard and Mouse More Efficiently Whether you use your computer 8 hours a day or just a few times a month, you will benefit from the following user guide. It´s based on Logitech´s years of study into the most efficient ways to point, click, and type. And when you want to learn about how to improve the setup of your workspace, download our comfort guidelines.
Comfort Guidelines >>
A little bit of history: Computer keyboards are the successors of 19th century typewriters. The layout (location of the letters on the keyboard) has not changed since the invention of the typewriter. It is different for every country. The first computer in the 60's required a computer keyboard which had a design that was slightly different from what is available today on the market. However, the key layout is still the same and requires training to be used efficiently.
3192.1.0.gif 1. How to use your Desktop Your desktop comes with a keyboard and a mouse. Both devices work together to offer a typing, editing and navigating solution in a software environment. Follow these guidelines to use your keyboard and mouse:
  • First place the keyboard in front of you on your desk. The right distance from your body is reached when your elbow is close to your side, and your fingers reach the center of the keyboard
  • If you are right handed place the mouse on the right side of the keyboard.
  • Have the mouse as close as possible to the keyboard allowing your hand to move the mouse without touching the keyboard with your thumb.
  • When your hand moves from the mouse to the keyboard, the elbow should stay close to your side.
  • If you have a palmrest, use it between keying tasks, not while typing. Using it while typing may increase pressure against the hand and increase the chance of injury.
  • When mousing with your right hand, it is recommended to use the left-hand side of your keyboard with your left hand. There may be specific functions such as web navigation tools that you can do with your left hand. This is the 2 Handed Navigation feature that some Logitech keyboards have. It has an ergonomic benefit that is explained in the downloadable Desktop Design & Comfort. This may increase your productivity and reduce fatigue. Working, playing, communicating this way may make you more productive and may add a lot of comfort to your computing experience.
Desktop Design & Comfort >>
3193.1.0.gif 2. How to use your Keyboard A keyboard has more than 100 keys that can be typed. All these keys are located in 4 different areas which have different goals:
  1. The alphanumeric keypad: the typing area T
  2. he F row: the function keys
  3. The numeric keypad
  4. The navigation keypad
Keyboard Shortcuts >>
3194.1.0.gif How to position your hands on a keyboard:
  • Position your left hand on the left side of the typing area, have your left index finger positioned above the key F.
  • Position your right hand on the center of the typing area, have your right index finger positioned above the key J. F and J keys have a raised little dot or a bar which allows you to easily feel the keys even if you don't look at the keypad.
  • The navigation keypad and the numeric keypad are used only with the right hand. The F row is shared between both hands.
How to type:
There are 2 ways to type: either you touch-type with your 10 fingers without looking at the keypad while looking at the monitor or "hunt and peck" the keys with several fingers and your eyes look for the right keys. A keyboard is designed to be used with both usages.
  • Every finger has a dedicated position on the typing area so that typing becomes a rapid and easy task. The following drawing shows these theoretical positions which is up to you to follow:
  • Fingers must touch the center of the key and come back to a resting position (letters shown above the fingers) on the home row (the third row from the bottom, as indicated on the picture, where the keys F and J belongs to).
  • When typing, the hand should float over the keyboard. When not typing, the hands can rest briefly either on the table or on the palmrest if it has been attached.
  • Combination of keys: Shift, Control (Ctrl), and Alt Gr keys are used in combination with other alpha numeric keys on the typing area. They have to be pressed when another key is used.
2453.1.0.jpg 3. How to use your Mouse A mouse is designed to be handled with one hand in order to move the pointer (also called the cursor - the little arrow) on the computer screen. A standard mouse has 2 buttons and a roller (also called a scroll wheel) between them.
How to position your hand on a mouse:
Place your hand on top of the mouse, and grip the mouse at your preference. If you are right handed, the index finger should click the left button.
You are now ready to mouse and click.
How to mouse and click:
Mousing should require only the motion of the fingers, not the whole hand. Look at the pointer on the screen and move the mouse between your thumb and pinky fingers according to your desired direction. Remember that the distance to reach an object on the screen is very small for the mouse and your hand on the table. For maximum precision, the 2 fingers should move less than a millimeter. You can configure the pointer speed by launching the Mouse Properties windows in the Control Panel, or with the manufacturer drivers.
The left button of the mouse is used to click on a software button on the screen (or an Internet link on a web page) to launch either a function, or a window etc. The right button is used to open a dynamic context menu close to the pointer position on the screen, from which commands can be launched, and then disappear. The roller between the 2 buttons on the mouse replaces the vertical scroll bar movement on the window to navigate up and down either on a page, a spreadsheet, a picture, etc: roll wheel up (extend your finger) to scroll up and roll wheel down (flex your finger) to scroll down. Usually all buttons are programmable to change their settings and functions depending on your preferences. Also, many mice now have additional buttons like an Internet Back in the thumb scoop of the mouse.
Mar 24, 2009 | Logitech Computers & Internet
Logitech mouse problem
I assume there is no second mouse on the system and you are using keyboard commands. Try the following in the device manager..
  1. Press Control-Esc or press the Windows key on your keyboard to bring up the Start menu.
  2. Using the up arrow key, highlight "Settings."
  3. Right arrow key to "Control Panel" and press the enter key.
  4. Use the arrow keys to highlight the System icon and press the Enter key.
  5. Use the right arrow key to select the Device Manager tab. (For Windows XP/2000 , use the right arrow key select the "Hardware" tab. Now use the tab key, select the "Device Manager" button and press the enter key.)
  6. Use the "Tab" key to select the "Computer Icon" at the top of the list of device icons.
  7. Use the down arrow key to highlight the Mouse icon.
  8. Use the right arrow key to open the mouse icon and verify there is a mouse icon that states, "HID-compliant mouse," and another entry that states the name of your USB device.
  9. If there are any errors reported on these icons by exclamation points or red X's, highlight these icons using the arrow keys and "Tab" to the "Remove" button and press the enter key. (For Windows XP/2000 , highlight these icons using the arrow keys and then press Alt-A keys. From the "Action" menu, highlight "Uninstall" and press the enter key.) When the "Confirm Device Removal" box appears, press the enter key.
  10. Once these icons have been removed, use the Tab key to get to the "Refresh" button and allow Windows to re-detect the pointing device. (If u r using Windows XP/2000 , press the Alt-A keys. From the "Action" menu, select "Scan for hardware changes" and press the Enter key.)
  11. Use the arrow keys to open the Mouse icon again and verify that there are no errors reported.
  12. Power down the computer system and restart Windows.
Apr 16, 2008 | Logitech diNovo LX300 Keyboard/Mouse
Logitech 967437-0403 Keyboard Logo
1,793 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
