Question about Vacuums
Replace power lead on panasonic vacuum cleaner MCE 468
Hello I'm trying to replace the power lead on my vacuum cleaner but I can't fully open up the unit.  Any tips? Cheers Max
  • Anonymous Mar 19, 2014
    to replace power lead
  • 833 Answers
Generally, there are 'hidden' screws which are found under plastic plugs. Look for them. You may also find some screws on the opposite side of the plate holding the lead. Finally, sometimes the plate will slide up or down from its fixed position. I'm not familiar with your exact unit, however.
Posted on Mar 10, 2008
My Dyson v8 stick vacuum isn't charging.
Hello, this is Ava with Think Crucial.
If your vacuum doesn't turn on, make sure that plug is fully inserted into a fully functional electronic outlet. If it still not turning on after verifying this, it could be that the power switch is malfuntioning. You may need to replace the power switch by opening up the handle of your vacuum. I suggest to refer to your manual on how to replace the power cord or contact Dyson for troubleshooting steps. 1-844-679-1647
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Apr 25, 2017 | Dyson Vacuums
My shark nv500w 31 vacuum will not run; any suggestions?
If your vacuum doesn't turn on, make sure that plug is fully inserted into a fully functional electronic outlet. If it still not turning on after verifying this, it could be that the power switch is malfunctioning. You may need to replace the power switch by opening up the handle of your vacuum. I suggest referring to your manual on how to replace the power cord or contact Shark for troubleshooting steps. 1-800-798-7398.
You can purchase a wide variety of high-quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark
Ava B.
Jul 06, 2014 | Vacuums
Panasonic optiflow upright vaccum
Hello, Put the vac on its side and remove the screws holding the cover plate on. This exposes the beater bar and belt on the side. Pull the beater bar out and take the belt off. Reverse this to put the belt back in place.
May 30, 2014 | Panasonic MC-UG323 OptiFlow Upright Vacuum...
Panasonic vacuum cleaner MC-5030 stopped and don't work
Unplug, check if brush has cord wrapped. Check for fuse, if applicable.
Check power lead in another supply socket. Check for reset button, if applicable. Contact Panasonic technical support for suggestions before heading to service centre.
Jun 17, 2012 | Vacuums
My dyson vacuum will not start
If your vacuum doesn't turn on, make sure that plug is fully inserted into a fully functional electronic outlet. If it still not turning on after verifying this, it could be that the power switch is malfunctioning. You may need to replace the power switch by opening up the handle of your vacuum. I suggest to refer to your manual on how to replace the power cord or contact Dyson for troubleshooting steps. 1-844-679-1647
Ava B.
Jun 10, 2012 | Dyson DC14 All floors Bagless Upright...
My Dyson DC25 will not power on
Ava B.
Aug 13, 2011 | Dyson DC25 All Floors Bagless Upright...
The power button quit working
Please click here to see the part diagram for the Hoover Windtunnel Self Propelled model U6446-900
Greetings from GoVacuum,
For replacing the switch, you need to remove the 2 screws that are in the back of the vacuum where the handle connects to the vacuum bag housing, Part # 50 on the first page of the diagram. After the screws have been removed, you may simply slide out the handle from the rest of the vacuum cleaner. You can then at this point view the outside of the switch, however as you'll find you can't replace it from this side. You'll then need to go into the where the tool caddy is in the front top part of the vacuum cleaner. Remove the attachments from the tool caddy, and then you'll need to remove the screws that hold the tool casing in place. Remove screws pictured # 35 on page 1, and the tool caddy is item # 17.
Once the screws and the tool caddy are removed, you may then see the rest of the switch, and the leads that connect to it. The easiest way to remove the screw is to use a flat head screwdriver and pry the switch out from the back of the vacuum cleaner after removing the leads from the switch. The new switch that you'll need to purchase is Hoover part number 28161067 which can be found online here: Hoover Windtunnel Main On / Off Switch Part Number 28161067.
I hope that this helps you replace the faulty switch in yours (and your parents) vacuum cleaners. If you need to place an order for the switch, please give us a call at 1-866-468-2288.
Thank you,
Chris Jones
GoVacuum.com
Mar 18, 2010 | Hoover U6446-900 WindTunnel Bagged Upright...
Cleaner will not come out of dispenser when handle is pressed.
Greetings from GoVacuum.com,
It seems that you may have a bad pump. If you'd please give me the model number of the Bissell, I can give you the parts schematic so you can see how it's taken apart. We'd be happy to help you in explaining how to replace the pump should you have any questions.
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Aug 18, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
It does not ****
It sounds like you have a clog in the vacuum cleaner somewhere. What you can do is remove the hose from the back of the vacuum cleaner and see if the changes the bag full indicator, and pay attention to the sound of the motor. If the motor starts making a high pitch sound as soon as your install the hose, this means that there is a clog somewhere in the hose.
If you can give me your model number, I can send you a parts schematic to your vacuum cleaner.
Thanks,
Chris Jones
GoVacuum.com
1-866-468-2288
Aug 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
99 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
