Question about Motorola Mobility RAZR V3i Cellular Phone
Pscan interlace screen gone blank
An not reset system coz no manual. how can i reset this old dvd home theater system. its a decktron digi-11 home theater dvd player. i was fiddling with pscan and interlace features on setup menu now screen gone blank
Hi plz go to setting and reset ur fectory its code is 000000.
Posted on Mar 12, 2008
We see a yellow anouncement that says PSCAN and it splits the image
Hello
PSCAN; means Progressive Scan. To get the splitted picture together you have to change the scan system of your tV to progressive scan. Now it runs on Interlace Scan. If your TV has Progressive Scan function; refer to its user manual; set it to progressive scan. An other way is to change the scan system with DVD. Try either. OK.
Jun 20, 2011 | Memorex MVD-2045 DVD Player
My memorex combo dvd & vhs player is not working right. can you help me? the vhs player works fine, but the dvd player display's a split screen on the tv with a large yellow box with the word PSCAN....
PSCAN is a short form for Progressive Scan - a line scanning format used for High Definition TV. Standard TVs use Interlaced scanning. On your DVD/VHS player, the VHS is an analogue signal recorded in interlaced mode so is fine for a standard TV. The DVD is a digital signal and cazn be processed for progressive scan output in order to produce a better picture on a High definition TV (or a TV capable of handling progressive scan). If you cannot to your TV via the HD outputs then you should be able to set the DVD player to output interlaced instead of progressive scan.
Mar 05, 2011 | Memorex MVD4540 DVD Player/VCR
I want to set up my dav-fr10w to 'interlace' option so i can play the dvd's on my tv, but it's set to 'progressive' right now and the instruction manual doesn't give the specific information to change it....
To cancel Progressive scan output or to change output to interlace signal format, follow these steps..
1- Select DVD by pressing Function button on unit.
2- While holding down |<< (review) button, press Function button on unit.
This will change output signal to interlace/ composite video output from yellow pin/ S-Video.
Hope this info will help you.
Thanks.
Feb 05, 2010 | Sony DAV-FR10W System
Split Screen
Go into SETUP
GENERAL SETUP PAGE
Go to VIDEO OUTPUT (can't see through error message, but it is the second one down - If you are on the right one, you will see S-Video, YUV Interlace and YUV Progress. as choices)
Change setting from YUV Progress to YUV Interlace
Mine was set on YUV Progress. and when I changed it, the problem disappeared.
Mar 06, 2008 | RCA DRC200N
Need to reset my dvd player
From the manual:
Press STANDBY/ON to put the system in standby, then press and hold the front panel (stop) button for about 8 seconds until the display shows Mem.clr?.
Press the front panel I<<<< or the >>>>I button so that the display shows Interlace?.
Press the front panel >/II button to set to interlace & switch the system back on.
Feb 28, 2008 | Pioneer DV-285-S DVD Player
DVD player is "LOCKED"
Well, at least the child-lockout works, right?
I have a similar Pan. HT system and I suspect you will have to go through the main menu and look for settings regarding 'tamper-proofing' to prevent just such 16 month-olds from inserting their jelly bread into the DVD player.
Your system may differ from ours but you should be able to find that feature in your user manual.
If the manual is gone, you might want to try this page:
http://www2.panasonic.com/consumer-electronics/support/Audio/Home-Theater/Home-Theater-Systems.list.75434
Your system is not listed directly but there are several from that series and they may share features.
Downloading of the manuals costs nothing.
Good luck-
Feb 27, 2008 | Panasonic SC-HT650 System
Pinoeer DVD-366
Hi there, just got that progresive problem gone :D
- Startup ur DVD (ON)
- Wait until Loading - No Disc (status on DVD display)
- In here, ur screen still blank (black screen)
And here's how:
- Press "Home Menu" button
on ur DVD (it should be on the down left of the circle button)
-- Watch out, the screen still in blank, just feel it right ok?
- Down 2x -- Initial Setting
- Menu / Ok (the circle button)
- Down -- Video Out
- Menu / Ok
- Down -- Component Out
- Menu / Ok
- Down -- It will choose Interlace, it will saved the day :-)
- Menu / Ok
That's it.. Cheers mate ^^
Give me a mail if u still have the problem, coz I Know how it sucks.
Tyraxel@yahoo.com
Dec 02, 2007 | Pioneer DV-366K DVD Player
DVD Home Theatre System Panasonic xv htd-330 dvd won't play
From the manual:
May 04, 2007 | Pioneer HTD-330DV System
Stuck on either PScan or PAL; can i reset the whole darn player?
To reset Cyberhomes DVD players. Take the dvd out close the tray. then press and hold stop for five seconds.
Aug 04, 2006 | Cyberhome CH-DVD 300 DVD Player
Progressive Scan Mode Resetting
Hi, Open the CD and press return on the remote to reset it back to Interlace mode. Thanks Annarr
Jan 14, 2006 | GPX DV7500 System
Motorola Mobility RAZR V3i Cellular Phone Logo
156 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
