Question about Canon PIXMA MP210 Photo All-In-One Printer
Paper completely jammed
Pixma mp210 paper completely jammed
  • 5 more comments
  • Newnig Mar 30, 2008
    At first I kept getting a paper jammed message and there s no paper in the printer, When the paper starts to feed it goes in uneven, then stops and the jammed paper message would appear now the yellow alarm light stays on and nothing happens. There is also an "E" for error message in the l.e.d. what can I do?
  • rgrg Apr 14, 2008
    I am having the same problem. I have checked for anything, small or big in the paper path but still have the "E" message and it will not print. Anyone else with a solution? Don't want to take it in the shop, becasue it will cost more than the piece of **** is worth.
  • ceps44 May 29, 2008
    I also have the same problem and i have checked for any pieces of paper stuck but theres nothing
  • Anonymous Aug 01, 2008
    same problem. paper jammed yet there's no paper. It might be a small one but i couldnt see it probably because it way inside the printer that i'll have to take the parts piece by piece. I wish there's another way that anyone could give some advice on. tnx
  • zzzz99 Aug 02, 2008
    same problem. no jammed paper, but printer is locked up with error 3
  • breezezbabe Sep 20, 2008
    Paper jammed and won't feed paper
  • Anonymous Nov 26, 2008
    i have this problem aswell, odd thing is that it prints the 1st page of a document then it tells me that theres a jam. theres no paper (from what i can see) so wtf do i do...ive only had the damn thing for a week!
I had the same problem and tried everything that was recomended, what worked was loading a single piece of paper in the rear tray and pushing the black or color start button while pushing the paper in the rear tray down as much as i could then i lifted up the front where you change the ink cartridges and grabbed the paper i could see trying to feed through and pulled on it until it came through and low and behold a tiny obstruction flew out!!! yay
Posted on Nov 25, 2008
No jamed paper and error 3 iz there
Posted on Sep 23, 2008
Paper jammed and doesn't feed at all!
Posted on Sep 20, 2008
  • 47 Answers
Check if there is a little paper that stuck on it that causes a paper jam
Posted on Mar 11, 2008
5 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: Canon PIXMA MP2the paper jamming light is staying on. there is no
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 26, 2010
RPFinney
  • 385 Answers
SOURCE: paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Posted on Apr 21, 2009
APremkumar
  • 564 Answers
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
PREM
Posted on May 26, 2009
  • 71 Answers
SOURCE: I need help with my canon PIXMA MP210 printer, the
try to check if there is small particles or small papers that lock inside the printer.. maybe something is blocking the paper
Posted on Aug 25, 2009
Canon MP210 pulls paper to the right.
Hello
So your printer has a paper skew problem? first of all was there any paper jam in the printer earlier?
Jul 14, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Paper dosnt feed in printer pixma mp210 photo. HELP
Either paper jammed, stuck by foreign object or DRIVE ASSY faulty.
May 25, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Canon mp210 will not load paper this is a brand new printer so why error 3 continually?
E3 is paper jam.Make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.
Nov 10, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
I need help with my canon PIXMA MP210 printer, the printer keep jamming paper
Aug 25, 2009 | Canon PIXMA® MP210 Printer
Paper pulls to the right, jams, won't print, tried different paper still won't print
Hope that helps!
PREM
May 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper Jam, yet no paper in printer. The last sheet came out whole.
I have a canon mp210 and it's saying paper jam..there is no jam. Paper is going towards the right when trying to feed but does not feed.
May 17, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon MP210 paper jam
try to get in touch with canon service centre in your area and get it fixed it will be a small problem
Feb 24, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Front tray, paper jam
Please visit below mentioned links to solve the problem of paper jam:
Paper Jam Problem
Thank You
Oct 26, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
The first page keeps jamming when I try to print
move the paper guides as close to the paper as possible. This should solve what seems to be a common problem with these printer see it all the time
cheers
Steve
complete inkjet solutions
Oct 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
494 people viewed this question
old marine
old marine
