Question about Sony STR-DE345 Receiver
Sony STR-DE545 Amp
I've misplaced my manual for setting up the system and was wondering whether the 345 model is similar to set up? Pls Help?
  • 2,335 Answers
Find the user manual under product details.
Posted on Mar 09, 2008
Turn off demo mode on sony str
Go into the settings and select Demo Mode OFF
Oct 05, 2014 | Sony STR-DE545 Receiver
Str-de545 sony not putting out sound to rear speakers
From page 46 (Troubleshooting)-
No sound or only a very low-level sound is heard from the rear speakers.
>>> Make sure the sound field function is on (press SOUND FIELD - MODE).
>>> Select a sound field containing the word "cinema" or "virtual" (see pages 28-30).
>>> Adjust the speaker volume (see page 19).
>>> Make sure the rear speaker size parameter is set to either SMALL or LARGE (see page 17).
Jan 11, 2011 | Sony STR-DE545 Receiver
Optical digital cable connection ?
It only works through DVD setting
Jun 20, 2009 | Sony STR-DE545 Receiver
Sony str de545 5.1
Make sure the subwoofer is set to On in the setup menu. Should be able to access this setting from the front panel, using the click wheel and the left/right buttons above the wheel. Push the setup button to get to the right menu. Set subwoofer to 'on' and speaker size to 'small'. This receiver has a fixed crossover, so make sure to turn the crossover setting on the subwoofer to the maximum setting (highest frequency) to ensure no signal is lost.
Oct 22, 2008 | Sony STR-DE545 Receiver
Reduced audio output from right channel
Try lightly tapping on chassis to see if you can get audio to cut on or off with vibration if you can most likely cause is bad solder connections. This unit is well known for poor solder connections especially around poweramp driver IC's IC701, IC501. Also Electrolytic Capacitors in unit have fluid in them and heat Evaporates the fluid causing them to not operate properly over time . Caps that usually go bad are around parts that run hot like Power amp drivers
Just a couple likely suspects.
Try unplugging overnight to give unit a Good Reset also double check all setup settings.
If you need service manual I may be able to get you one
kstahl65@att.net
Jan 19, 2008 | Sony STR-DE545 Receiver
Sony STR-DE545 5.1 not working
Are you connecting from your DVD player to receiver using an optical cable or simple AV cable?
Nov 06, 2007 | Sony STR-DE545 Receiver
Sony STR-DE545 5.1 Channels Receiver
It sounds like you have unit in setup mode. The "L C R" is Left, Center, Right. You can set balance and volume levels of each with this mode.
Use remote to select 5.1 dolby surround to get unit out of 2/1 "stereo"
Aug 19, 2007 | Sony STR-DE545 Receiver
Sony STR-DE545 receiver
You should have access to receiver's format from remote or front panel. If the unit was moved around a lot and for a long period, the micro-processor may have locked due to ambient static electricity. Try unplugging unit for seversl hours, then re-try
Sony STR-DE345 Receiver Logo
77 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
