Question about Microsoft Windows XP Home Edition
Command prompt window closing automatically - Microsoft Windows XP Home Edition
  • Anonymous Apr 06, 2008
    having the same problem
  • 73 Answers
Hi anil
just run cmd & type shutdown it will show the details of shut down
Posted on Mar 09, 2008
Granddaughter changed password on my computer unable to access anything help
copy d:\utilman.exe d:\windows\system32\utilman.exeYou can boot from your windows 7 disc and use the system recovery command prompt to change the password:
  1. Put windows 7 disc in computer and reboot
  2. When prompted to press any key to boot from CD/DVD, press a key such as the space bar
  3. Wait for the Install Windows screen to appear, there will be language options, press the "Next" button
  4. There will be an Install Now button and a couple links at the bottom of the window, press the "Repair Your Computer" link
  5. Wait for the "System Recovery Options" window, it will show you which drive windows is installed to (such as C: or D:) under the location column. Remember this letter and press the next button
  6. You will now have a list of options, press the "Command Prompt" link
  7. Assuming the drive letter you saw was D:, type these commands (if it was not D, then change to the letter you saw)
    1. copy d:\windows\system32\utilman.exe d:\
      1. Completion of this command will say 1 File(s) copied
    2. copy d:\windows\system32\cmd.exe d:\windows\system32\utilman.exe
      1. You will be prompted to overwrite, type Y and press enter
  8. Remove your windows 7 disc, close the command prompt window, and press the "Restart" button on the system recovery options screen
  9. Once your computer comes up to the log-in screen, there is a little button in the bottom left corner for ease of access options, press this button and a command prompt window will appear.
  10. In the command prompt type
    1. net user
      1. make note of your user name that is listed
    2. next type "net user" without the quotations followed by your username and whatever password you want.
  11. Close the command prompt window, then log in to your computer
To reverse the changes made to the file when in the windows repair command prompt:
  1. Insert your bootable Windows 7 media.
  2. Click the Next button.
  3. Click the Repair your computer link.
  4. Wait while Windows is found on your hard drive.
  5. Select Windows 7 and then click Next.
  6. Click on Command Prompt.
  7. Type the following command followed by enter
    1. copy d:\utilman.exe d:\windows\system32\utilman.exe
      1. If your drive letter was not d, then replace it with the correct one
      2. you will be prompted to overwrite, press Y and enter
  8. Remove your windows disc, close the command prompt, and press the restart button again
Oct 16, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Tip
How to recover shortcut files from a flash drive or memory card
Ever experienced plugging your flash drive or memory card and found that your files have been made shortcut and when you tried opening the file nothing happens? Here is one solution that can recover your files.
1. when you plug your flash drive and see the shortcut files, do not delete the files as it will take longer time to recover it. Take note of the drive that reads your flash drive. (see the highlighted text)
3. open the command prompt window which looks like this
4. then on the c prompt type: chkdsk (name of the drive of the flash drive {e.g. g or d}) the command prompt will look like this:ninyarica_3.jpg
5. then you will see the following words on the command promptninyarica_4.jpg
6. wait until it is completed
7. then type exit, to close the command prompt window
8. check your flash drive now, the shortcut files have been recovered.
9. now, you need to clean your flash drive to remove the virus. You have to have a good antivirus to do this.
10. you can now delete the shortcut files if it not removed automatically by the antivirus you used to clean the flash drive.
these steps helped recover my files from my flash drive. Hope it will help you too.
if the steps above did not work or did not recover your shortcut files, you can try this alternative
11. on the command prompt, type: attrib -h -r -s /s /d g:\*.* your command prompt window will look like this: ninyarica_6.jpg
12. wait until it is finished or until you see: ninyarica_7.jpg
13. then exit the command prompt window then check the files on your flash drive, not only will it recover the shortcut files but it will also recover some deleted folders
on Apr 24, 2011 | Computers & Internet
Tip
Disable/Enable Hibernation in Windows
To make hibernation unavailable, follow these steps: <br /> <ol> <li>Click Start</b>, and then type <span>cmd</span> in the Start Search</b> box. <li>In the search results list, right-click Command Prompt</b>, and then click Run as Administrator</b>. <li>When you are prompted by User Account Control, click Continue</b>. <li>At the command prompt, type <span>powercfg.exe /hibernate off</span>, and then press ENTER. <li>Type <span>exit </span>and then press ENTER to close the Command Prompt window.</li></ol> To make hibernation available, follow these steps: <br /> <ol> <li>Click Start</b>, and then type <span>cmd</span> in the Start Search</b> box. <li>In the search results list, right-click Command Prompt</b>, and then click Run as Administrator</b>. <li>When you are prompted by User Account Control, click Continue</b>. <li>At the command prompt, type <span>powercfg.exe /hibernate on</span>, and then press ENTER. <li>Type <span>exit </span>and then press ENTER to close the Command Prompt window.</li></ol>
on Mar 26, 2011 | Computers & Internet
No network coverage
Set IP Address Configuration
Click the "Start" button and select the "Control Panel" from the right column to open it.
Select the "Network and Internet" section of the Control Panel.
Click "Network Connections" if using Windows XP to view the available network icons.
Or, click "Network and Sharing Center" if using Windows 7 or Vista and select "Change adapter settings."
Right-click your network connection icon which displays either the yellow triangle or red "x" indicating limited or no connectivity.
Select "Properties."
Click on "TCP/IP" to select and highlight it. Click "Properties."
Select both the "Obtain IP address automatically" and "Obtain DNS server address automatically" radio buttons.
Click "OK" and then "Close" in the Network Connection Properties box. Close the Control Panel.
Manually Renew IP Address
Click the "Start" button and choose "Run" from the list.
Type "cmd" in the "Run" box and press "Enter" to open the Windows Command Prompt.
Type "ipconfig /release" in the Windows Command Prompt and press "Enter."
This releases the current IP address of your computer.
Type "ipconfig /renew" and press "Enter" to obtain a fresh IP address.
When renewing your IP address, Windows automatically attempts to connect to the network.
Powercycle Router and Modem
Turn off your computer.
Unplug both the Internet modem and wireless router's power adapter from the electrical outlet. Wait for two minutes.
Plug the Internet modem into the electrical outlet first. Wait for connectivity lights to appear.
Plug the wireless router's power adapter back into the electrical outlet.
Confirm that lights appear on the router indicating that it has established a connection to the modem.
Turn on your computer.
Open "Network Connections" if your computer does not connect automatically to the network.
Select a network from the list, input the network password if one exists and click "Connect."
Open your Internet browser to test the connection.
Update Network Interface Card (NIC) Drivers
Click the "Start" button. Right-click "My Computer" or "Computer" from the Start Menu. Select "Manage." Click "Yes" if a user account control message appears.
Click on "Device Manager" from the list of System Tools.
Find the "Network adapters" listing and click the "arrow" or "plus" symbol to expand it.
Right-click your computer's network adapter from the list and select "Properties."
Click the "Driver" tab and select "Update Driver."
Follow the on-screen prompts to allow Windows to find and install the drivers automatically. Restart the computer when the process is finished and attempt to re-connect to the network.
Reset Internet Protocol (TCP/IP)
Click the "Start" button and select "Run."
Type "cmd" and press "Enter" to open the Command Prompt.
Type the following line into the Command Prompt and press "Enter":
netsh int ip reset resetlog.txt
Close the Command Prompt. Issuing this command tells Windows to remove and then re-install the two registry keys used by the Internet Protocol (TCP/IP) component of Windows.
Restart the computer.
Attempt to connect to the network if a connection is not established automatically.
Sep 06, 2013 | Computers & Internet
How do you fix error code E000590-0001
Solution 1: Clear the Windows Store cache
To start with, you should simply clear the Windows Store cache as doing so is the solution to a wide variety of different Windows Store-related issues and may just be able to get the job done in this case as well. In order to clear the Windows Store cache, you need to:
  1. Press the Windows Logo key + R to launch a Run
  2. Type WSReset.exe into the Run dialog and press Enter.
  3. Restart the computer and, once it to boots up, check to see whether or not the Windows Store is up and functioning again.
Solution 2: Re-register the Windows Store
When it comes to Windows 10 issues involving the Windows Store, it is always a good idea to re-register the Windows Store and see if that fixes the problem. Many Windows 10 users who have been affected by this specific issue have had success with getting rid of it by simply re-registering the Windows Store. In order to use this solution, you need to:
  1. Press the Windows Logo key + X to open the WinX Menu.
  2. In the WinX Menu, locate and click on Command Prompt (Admin) to launch an elevated Command Prompt with administrative privileges.
  3. Type the following into the elevated Command Prompt and press Enter:
PowerShell -ExecutionPolicy Unrestricted -Command "& {$manifest = (Get-AppxPackage Microsoft.WindowsStore).InstallLocation + '\AppxManifest.xml' ; Add-AppxPackage -DisableDevelopmentMode -Register $manifest}
  1. Once the command has been fully executed, close the elevated Command Prompt.
  2. Restart the computer and wait for it to boot up. When the computer boots up, try launching the Windows Store and see whether or not it successfully loads up.
Solution 3: Rename the Software Distribution folder
Located in the root folder of your computer's HDD/SSD is a folder named Software Distribution, and there is a pretty decent chance that you'll be able to fix this issue by simply renaming this folder, like many affected users before you have, and forcing Windows to automatically create a new one. In order to do so, you need to:
  3. One by one, type the following commands into the elevated Command Prompt and press Enter after typing in each one:
net stop wuauserv
net stop cryptSvc
net stop bits
net stop msiserver
  1. Type the following command into the elevated Command Prompt and press Enter:
ren X:\Windows\SoftwareDistribution SoftwareDistribution.old Note: Replace the X in this command with the letter corresponding to the partition of your computer's HDD/SSD that Windows is installed on. Usually, it is C:\
  1. One by one, type the following commands into the elevated Command Prompt and press Enter after typing in each one:
net start wuauserv
net start cryptSvc
net start bits
net start msiserver
  1. Type exit into the elevated Command Prompt and press Enter to close it.
  2. Restart the computer.
  3. Wait for the computer to boot up.
  4. When the computer boots up, check to see whether or not the problem has been resolved.
Solution 4: Enable TLS
If none of the solutions listed and described above have worked for you, you may be suffering from this issue because TLS is disabled on your computer. If that's the case, simply enabling TLS will get the job done and resolve this problem. In order to enable TLS on a Windows 10 computer, you need to:
  1. Open the Start Menu.
  2. Click on Settings.
  3. Click on Network & Internet.
  4. Click on Wi-Fi in the left pane and, in the right pane, scroll down and click on Internet Options.
  5. Navigate to the Advanced
  6. Under Settings, scroll down to the Security
  7. Make sure that there is a check mark next to the Use TLS 1.2 option, meaning that the option is enabled.
  8. Click on Apply and then on OK.
  9. Restart your computer. Once the computer boots up, try launching the Windows Store and see if it loads up successfully.
Solution 5: Disable Proxy
Having a proxy enabled can prevent you from accessing the Windows 10 Store.
  1. Press the Windows + R keys to open the command prompt, type inetcpl.cpl and then click OK. This will open the Internet Properties settings.
  2. Go to the Connections tab and click on LAN Settings.
  3. Check the box next to Automatically Detect Settings and uncheck the box under Proxy Server.
  4. Click OK and try to open the Windows 10 Store.
Alternatively, you can follow these steps.
  1. Open an elevated command prompt by pressing the Start button, typing cmd and then opening as a administrator.
  2. In the elevated command prompt type the following command:
    netsh winhttp reset proxy
This will reset the proxy settings and give you a direct internet access.
  1. Try to browse the Windows 10 store and verify if the issue will persists.
Regards.
Microsoft Live Support 24 7 Online Professional Support Chat
Mar 16, 2011 | Office Equipment & Supplies
Local area connection doesnt have a valid ip connection
1. Powercycle you equipment ( Unplug power for 15 seconds and plug back in) make sure that you are directly connected. 2.Open your network connections to do that depending on your OS operating system. Windows XP: Start/Run/Type ncpa.cpl and hit ok Windows Vista/7 Start/Search Bar/Type ncpa.cpl and hit Enter. 3.Windows XP: Double Click on Local Area Connection and hit properties, Click Internet Protocol and hit Properties once again. Ensure Obtain an Ipaddress automatically is checked as well as Obtain DNS server automatically is checked as well if not check them both. Close out of Network Connections. Windows Vista/7: Right Click on Local Area Connection and hit Properties, Uncheck Internet protocol Version 6 IPV6 and Click on IPV4 and hit properties. Ensure Obtain ipaddress automatically is checked as well as Obtain DNS server automatically is checked if not check both. 4.Restart Computer 5.Open Command Prompt: Windows XP: Start/Run/Type CMD hit ok Windows Vista/7 Start/All Programs/Accessories/Right Click Command Prompt and hit Run as Administrator then hit continue. 6. In Command Prompt Write the following commands remember to hit Enter after each command. netsh int ip reset reset.log netsh int ip delete arpcache netsh winsock reset ipconfig /flushdns 7.If unable to renew ipaddress scan for Viruses inside your computer using a security software and if you are still having the issue refer to manufacture. Good Luck 7. Restart Computer
Jan 13, 2011 | D-Link (DI-711) Router
My computer will not install updates. it says it is installing them after it shuts down but they never install.
Try the following steps to install the update successfully.
Stop the services pertaining to Windows Update.
1. Click Start, click All Programs, click Accessories, right-click Command Prompt, and select Run as Administrator.
2. If you receive a notification from User Account Control simply click Continue.
3. At the command prompt, type the following commands and then press ENTER after each command.
net stop wuauserv
net stop bits
net stop cryptsvc
4. Please do not close the Command Prompt window.
Rename folders pertaining to Windows Update
At the command prompt, type the following commands and then press Enter after each command:
ren %systemroot%\System32\Catroot2 Catroot2.old
ren %systemroot%\SoftwareDistribution SoftwareDistribution.old
Start services pertaining to Windows Update.
net start wuauserv
net start bits
net start cryptsvc
Close the Command Prompt window.
Regards,
Om
Oct 11, 2009 | Microsoft Windows XP Professional
UNABLE TO INSTALL SP2 ON XP OP.SYSTEM
net stop wuauserv
net stop bits
net stop cryptsvc
net start wuauserv
net start bits
net start cryptsvc
Regards,
Om
Oct 01, 2009 | Microsoft Windows Xp Home Edition Sp2...
Need to fix svchost.exe the instruction at
I have a fix for it - it's somewhat lengthy, but it works. Follow the directions below to a T and you'll be all set.
Verify Windows Update Service Settings
  • Click on Start, Run and type the following command in the open box and click OK
    services.msc
  • Find the Automatic Updates service and double-click on it.
  • Click on the Log On Tab and make sure the "Local System Account" is selected as the logon account and the box for "allow service to interact with desktop" is UNCHECKED.
  • Under the Hardware Profile section in the Log On Tab, make sure the service is enabled.
  • On the General Tab, the Startup Type should be Automatic, if not, drop the box down and select Automatic.
  • Under "Service Status" on the General tab, the service should be Started, click the Start button enable it.
  • Repeat the steps above for the service "Background Intelligent Transfer Service (BITS)"
Re-Register Windows Update DLLs
  • Click on Start, Run, and type CMD and click ok
  • In the black command window type the following command and press Enter
    REGSVR32 WUAPI.DLL
  • Wait until you receive the "DllRegisterServer in WUAPI.DLL succeeded" message and click OK
  • Repeat the last two steps above for each of the following commands:
    REGSVR32 WUAUENG.DLL
    REGSVR32 WUAUENG1.DLL
    REGSVR32 ATL.DLL
    REGSVR32 WUCLTUI.DLL
    REGSVR32 WUPS.DLL
    REGSVR32 WUPS2.DLL
    REGSVR32 WUWEB.DLL
Remove Corrupted Windows Update Files
  • At the command prompt, type the following command and press Enter
    net stop WuAuServ
  • Still at the command prompt,
    type cd %windir% and press Enter
  • In the opened folder, type the following command and press Enter to rename the SoftwareDistribution Folder
    ren SoftwareDistribution SD_OLD
  • Restart the Windows Update Service by typing the following at the command prompt
    net start WuAuServ
  • type Exit and Press Enter to close the command prompt
Reboot Windows
  • click on Start, Shut Down, and Restart to reboot Windows XP
Although this method may not solve all of the issues with a SVCHOST.EXE Application error, I have found it fixed the problem with the 0x745f2780 reference error.
Hope this helps! Good luck!
Sep 17, 2009 | Dell Microsoft Windows XP Home Edition
How to Find the Ethernet Adapter's MAC Address
Follow these instructions to find your adapter's Media Access Control address (MAC address). This is not the same as a Macintosh computer, it is a fixed string built in to the hardware, that uniquely identifies a computer device. Windows 2003 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. (no spaces around the /) 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows XP 1. Click Start > Run. A command prompt window appears. 2. Type cmd. 3. Type ipconfig/all. 4. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows 2000 1. Click Start > Programs > Accessories > Command Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Windows 95 and Windows 98 1. Click Start > Run. A command prompt window appears. 2. Type winipcfg. 3. Click OK. 4. Copy down the "Adapter Address" (the MAC address) on a paper where you keep your network configuration settings. 5. You may close the command prompt window. Windows NT 1. Click Start > Programs > MS-DOS Prompt. A command prompt window appears. 2. Type ipconfig /all. 3. Copy down the "Physical Address" (aka the MAC address) on a paper where you keep your network configuration settings. 4. You may close the command prompt window. Macintosh OS (10.3.5) These instructions also work for some earlier OS. 1. Click Apple Menu at top left > System Preferences > Network icon. 2. Select Show: Built-in Ethernet in the pull down menu. 3. Click Ethernet. 4. Your adapter's MAC address is the characters in Ethernet ID.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
Microsoft Windows XP Home Edition Logo
115 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
