Question about Microwave Ovens
Help!Need This Fixed!!
Our in the countr above the oven microwave motor ust stopped working.Clock works though.Less than 2 years old.
  • 833 Answers
If the motor alone has stopped working, you can remove the motor and test it. Most...unless labeled as such... are run at mains voltage. Use care and try that. If not working on the mains voltage, find out why you are not getting that voltage locally in the machine. Does the unit heat the food? If not, you may have an issue with the thermal overload sensor. It is black, about 10 mm in diameter and 5 mm thick...two wires coming out. Generally, it is mounted in the keyboard/power supply area against the wall of the cavity. If it is open, no power.
Posted on Mar 10, 2008
Microwave stopped working
Probably a problem with the door latch safety system. This happens every so often with our microwave, which is over 25 years old, and otherwise works perfectly.
If yours is new, it may still be under warranty. If not, there are places that specialize in fixing microwave ovens.
If it is an older, or less expensive oven, it might be time for a new one.
Jul 22, 2014 | Sharp R-1500 Microwave Oven
My microwave doesnt heat up,
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Their contact information will be in your owner's manual.
If for some reason you do not have your owner's manual, please reply back with your brand and model number so we can help you.
Dec 22, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Carousel stopped turning
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
Dec 05, 2008 | Kenmore 63682 / 63684 / 63689 Microwave...
Maytag,model mmv1153bab,serial #10001847ja,output 1000w
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If you still have trouble, since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can find your nearest Maytag-authorized servicer here.
Aug 10, 2008 | Maytag MMV1153A Microwave Oven
Hi, My new Whirlpool microwave oven's turntable stopped working after a few weeks. It was installed in June, 2008. I called last week and a service rep. advised me to unplug and restart after 10...
I'd suggest contacting Whirlpool customer service here to get it fixed free under warranty.
I'd say the motor or coupler has failed.
Aug 06, 2008 | Whirlpool Microwave Ovens
Have a ge spacemaker microwave and the buttons just stopped working last week. The screen only says "press clock". It is not a year old. Bought at home depot and lost original paper work.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
If it's less than a year old, it's still under warranty, and they can tell by the serial number & date on the label that it's sunder warranty.
I would contact GE to get it fixed free. GE Customer Service is here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 17, 2008 | GE Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
