I have a DVD-1920. DVD discs wont load most times, gives a message that there if a fault on th disc (disc is okay on other payer), I have used a laser cleaner and looked at the set up. It it worth repairing?
  • cuntlips Mar 24, 2009
    the DVD player is rooted, the cost of a Pioneer is your best replacement. Better value for money any day. Get in quick because Pioneer will be out of the market soon.
    Problem Solver:
  • 5 Answers
please try cleaning the lens manually with cotton or check if the flexible board connecting the lens to the mpeg board is ok or may be loose. if the same problem appears, maybe you've got defective lens or affective mpeg board.
joemari
Posted on Mar 10, 2008
The dvd payer is not working.
see this instruction and follow for fix it. God bless you
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Jul 17, 2013 | Televison & Video
Every CD I put in I get a message," no disc"
Hello
The laser pickup lens of your DVD payer is either dirty of faulty. Just put in a claeaning disc, and play if for at least three times. If there is any dust or dirt accumulated on the lens, the cleaning disc will clean it up. If this does not help you, laser pickup assmebly should be replaced with same type and number. OK.
Nov 28, 2011 | RCA DRC277 DVD Player
I am trying to play a dvd in my 2007 Tahoe. It will not play and gives me an optical error message. Any thoughts?
{: ) If you have been playing DVD normally before on your Tahoe, and now you read error messages, it could be the player or the disc at fault. Most of the time it is the disc at fault. As much as possible, the discs shoul be clean and scratch free, not warped, and compatible to your player. Avoid using discs with paper label. Try a known good DVD disc and observe for any progress.
Just in case it's the first time you try and you have a navigation radio, check again your RPO lists. and look for a UVB listed on the RPO sticker. Or simply check the DVD symbol on the left lower corner of the radio, which indicates that it is capable of playing DVD audio or video.
Jun 27, 2011 | 2007 Chevrolet Tahoe
Pioneer DVD 717 - Not Loading Discs Whenever I load a disc, the player spins the disc for a moment before slowing down. to a stop. It repeats this around four times in succession before it then opens...
Hi msaslloyd ,
This could be because of a damaged lens , where the dvd player tries to recognize the disc but is unable to do so and then either sends the disc back i.e. the tray opens up or the message no disc loaded is displayed.
I suggest you to :-
  1. Clean the lens with a lens cleaner available in the market and load any disc in the player to check if it's working fine.
  2. Get the lens replaced from the market and the problem should be solved.
Hope this helps ..:)
May 10, 2011 | Pioneer DV-717 DVD Player
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
My Dvd payer keeps telling me to check the disc,
If it is a commerical disc then your laser may be going out...if it is a material that was burned on a blank disc it might be formatted incorrectly for your player.
Oct 01, 2009 | Televison & Video
Getting "Bad Disc" message after Loading message...
If you've had it a long time and used it often, could be the lens is dirty or something wore down and it should be trashed since newer players have more features like usb ports.
Oct 17, 2008 | Astar PD-3060 Portable DVD Player
Disc error
Assuming you've tried regular nonrecorded DVD discs, there are many things that can cause this:
Dirty or defective laser. (try a cleaning disc).
Disc not spinning.
Laser not moving on slide rail.
I would at least try cleaning the laser lens before giving up.
Hope that helps...
Geno
Mar 24, 2008 | Televison & Video
Unknown disc error message
OKAY GUYS TRY USING THIS VERY COMPATIBLE MEDIA
(MEMOREX BRAND DVD-R) THIS WILL SOLVE A LOT OF YOUR PROBLEMS
Aug 27, 2007 | Televison & Video
Sony dvp-cx777es
when you say wont load up do you mean you cant insert dvd or do you mean,wont read,impossible to give you a cure without more details of fault
May 12, 2007 | Sony DVP-CX777ES Multi-disc DVD Player
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
