Question about D-Link AirPlus DI-524 Wireless Router
Cannot connect iMac with DI-524 over wireless! Please help!
I am making a transition from PC to MAC and so far it is being very painful! :( My  Mac connects to the Internet via DI-524 over cable with no problem. But wireless connection doesn't work. I have updated MAC OS to 10.5.2, DI-524 firmware to 2.06, removed security on my router, still no result. MAC sees the network on wireless bet when I try to connect it says "connection failed". When I try network diagnostics it asks for WEP password which my network doesn't have and of course doesn' t connect. The most weirdest thing though is that wireless WAS working yesterday with no problem after I updated to MAC OS 10.5.2 (it was not working with 10.5), then it stopped working for good. I believe it stopped working after I connected MAC and my old PC through the wire via the router but I am not sure. I also got some automatic updates of iLife and so on, but I don't think it caused the problem.  Needless to say that wireless works on my PC like a charm. Seem like the problem is in MAC which is very sad because I like the new shiny machine. Any help is very much appreciated. Boris
    Novelist:
    Scholar:
  • 114 Answers
The most likely answer is that you have an access control list (MAC Address filtering list) set up on your router and have not added your Mac's MAC, also called your Airport ID to the list but there are other possible causes.
Double check that you do not need to add your MAC address to the list, that you did save changes when you removed security from your router and that your PC can still connect.
The hardest part of moving from PC to Mac is learning to trust your computer to do things for you, with Microsoft's OS's you don't just trust the automated set-up wizards because even in the rare circumstance that the wizard actually works you invariably have to finish the settings manually.
With your Mac the exact opposite is true, if you try to do everything manually it'll invariably mess things up, where as using the wizards and trusting the computer to manage things on it's own reaps obvious rewards.
If Airport set-up wizard is asking for a WEP key and leaving the field blank doesn't work you can be comfortably sure that the router has a key set up on it. (BTW: Always be mindful of the fact that WEP is pointless, even 128bit.)
Check that your router has not been hijacked and that you have indeed removed the security from your router, is it possible that you have a WPA key set up on the router? Unlike WEP, WPA and especially WPA2 actually secure your network (in as much as is possible).
Another major cause of connectivity issues for new Mac users is having Norton Internet security installed, for a PC user the idea of not having full-on paranoid security installed is anathema, the idea that your Mac's inbuilt firewall alone is plenty of protection (at time of writing) Other than that ClamXav antivirus will protect your Mac form any viruses that may appear in future. Norton Internet security for Mac is often pushed on buyers by stores that don't know any better, to be honest Norton Internet security for Mac is an awful lot of hassle and performance loss for little or no advantage.
Using a Mac is different to using a PC but once you have got used to using a Mac you will not be able to change back, once you have learned to trust your Mac to do things for you, you will find Windows (any version) to be painfully time consuming, unstable and fiddly to use.
Post back if you are still having problems. :)
Posted on Mar 10, 2008
  • Nicholas Wilson
    Nicholas Wilson Mar 11, 2008
    One last thought Boris, you're not trying to connect to the network wirelessly whilst you also have it connected via a network cable are you? this will not work as your Mac will protect it's self from conflicts by not connecting to the same network over 2 interfaces. (Actually bandwidth aggregation is possible but would only cloud this issue for no practical gain.)
I have a mac and am having trouble with the
Whenever I have problems like you describe, I try to simplify. Remove the encryption key & see if your mac will connect. If YES, then add a simple key. I go with all numbers. Add complexity as you succeed. At the end of this process, reconfig all the other devices.
Jun 04, 2010 | D-Link AirPlus DI-524 Wireless Router
I can see the drivers CD, but can´t install
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 14, 2010 | D-Link AirPlus® G DI-524 Wireless Router
DL 524 router with a mac
When you connect the MAC to the router with the CAT 5 cable it works , that means the wired connection of the router is working but the wireless is not working.
You will need to check the wireless settings of the router.
Is there any computer connected to the router with the cable ?
If not then you will need to connect the computer to the router and open the set up page of the router.
Click Here for step by step instructions
Dec 02, 2009 | D-Link AirPlus DI-524 Wireless Router
Ichat not working
- Setup the required ports of the MAC Ichat on your router
Mar 08, 2009 | D-Link AirPlus DI-524 Wireless Router
DI-524 wireless router no signal missing antenna
tat dlink device is a good device i shld techinically still produce signals
but wat happened to antena if it is broken u might as well go for new router
as far i remember u wont get antena seperatly
on ur mac book scan for signal see if u are pick up signal
if yes you are lucky it shld still transmit else go for a new router
Dec 08, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Secure dlink di 524 with wireless connection.
One of your neighbors may have changed it for you, but you have the hardware, just reset it, and get a LONG cable to it, as you only get problems trying to set the Router with the wireless connection.
After resetting to factory default,
Change admin password
Set wireless security:
Wikreless/Wireless MAC filter.
- here you allow witch MAC address is allowed to access your network.
you find your own MAC address by typing ipconfig /all in a cmd.
/Teis
Dont forget to vote if this is helpful
Nov 23, 2008 | D-Link AirPlus DI-524 Wireless Router
Wan indicator does not light up..
Hi there
Getting Started
Setting up a Wireless Infrastructure Network
Please remember that D-Link AirPlus G wireless devices are pre-configured to connect together, right out of the box, with their default settings.For a typical wireless setup at home (as shown above), please do the following:
1) You will need broadband Internet access (a Cable or DSL-subscriber line into
your home or office)
2) Consult with your Cable or DSL provider for proper installation of the modem
3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
(see the printed Quick Installation Guide included with your router.)
4) If you are connecting a desktop computer to your network, install the D-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCI slot on your desktop computer. You may also install the DWL-G520, or the DWL-520. (See the printed Quick Installation Guide included with the network adapter.)
5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
(See the printed Quick Installation Guide included with the DWL-G630.)
6) Install the D-Link DFE-530TX+ adapter into a desktop computer. The four Ethernet LAN ports of the DI-524 are Auto MDI/MDIX and will work with both Straight-Through and Cross-Over cable. (See the printed Quick Installation Guide included with the DFE-530TX+.)
Using the Configuration Menu
Whenever you want to configure your network or the
DI-524, you can access the Configuration Menu by
opening the web-browser and typing in the IP Address
of the DI-524. The DI-524 default IP Address is shown
bellow:
-Open the web browser
-Type in the IP Address of
the Router (http://192.168.0.1)
Note: if you have changed the default IP Address assigned
to the DI-524, make sure to enter the correct IP Address.
-Type admin in the User
Name field
-Leave the Password blank
-Click OK
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
Home > Wizard
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
Home > Wireless
SSID- Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
Channel- 6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP- Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-524 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
Key Type- Select HEX or ASCII
Keys 1-4- Input up to 4 WEP keys; select the one you wish to use.
Home > WAN > Dynamic IP Address
Host Name- The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address- The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone MAC Address- The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the “Clone MAC Address” button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Home > WAN > Static IP Address
Static IP Address- IP Address-
Subnet Mask- ISP
Gateway Address- Primary
DNS Address- Secondary
DNS Address- Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address- Input the public IP Address provided by your ISP.
Subnet Mask- Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP Gateway Address- Input the public IP address of the ISP to which you are connecting.
Primary DNS Address- Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary DNS Address- This is optional.
Home > WAN > PPPoE
*** Please be sure to remove any existing PPPoE client software installed on your computers.
Choose PPPoE (Point to Point Protocol over Ethernet) if your ISP uses a PPPoE connection. Your ISP will provide you with a username and password. This option is typically used for DSL services. Select Dynamic PPPoE to obtain an IP address automatically for your PPPoE connection. Select Static PPPoE to use a static IP address for your PPPoeE connection.
PPPoE- Choose this option if your ISP uses PPPoE. (Most DSL users will select this option.)
Dynamic PPPoE- receive an IP Address automatically from your ISP.
Static PPPoE-you have an assigned (static) IP Address.
User Name- Your PPPoE username provided by your ISP.
Retype Password- Re-enter the PPPoE password
Service Name- Enter the Service Name provided by your ISP (optional).
IP Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Primary DNS Address- Primary DNS IP address provided by our ISP
Secondary DNS Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Maximum Idle Time- Enter a maximum idle time during which Internet connection is maintained during inactivity. To diable this feature, enable Autoreconnect.
MTU- Maximum Transmission Unit-1492 is the default setting-you may need to change the MTU for optimal performance with your specific ISP.
Auto-reconnect- If enabled, the DI-524 will automatically connect to your ISP after your system is restarted or if the PPPoE connection is dropped.
Home > LAN
LAN is short for Local Area Network. This is considered your internal network. These are the IP settings of the LAN interface for the DI-524. These settings may be referred to as Private settings. You may change the LAN IP address if needed. The LAN IP address is private to your internal network and cannot be seen on the Internet.
IP Address- The IP address of the LAN interface. The default IP address is: 192.168.0.1.
Subnet Mask- The subnet mask of the LAN interface. The default subnet mask is 255.255.255.0.
Local Domain- This field is optional. Enter in the local domain name.
Home > DHCP
DHCP stands for Dynamic Host Control Protocol. The DI-524 has a built-in DHCP server.
The DHCP Server will automatically assign an IP address to the computers on the LAN/
private network. Be sure to set your computers to be DHCP clients by setting their TCP/
IP settings to “Obtain an IP Address Automatically.” When you turn your computers on,
they will automatically load the proper TCP/IP settings provided by the DI-524. The
DHCP Server will automatically allocate an unused IP address from the IP address pool
to the requesting computer. You must specify the starting and ending address of the IP
address pool.
DHCP Server- Select Enabled or Disabled. The default setting is Enabled.
Starting
IP Address- The starting IP address for the DHCP server’s IP assignment
Ending
IP Address- The ending IP address for the DHCP server’s IP assignment
Lease Time- The length of time for the IP lease. Enter the Lease time. The
default setting is one hour
Advanced > Virtual Server
If you would like to view more of this manual CLICK HERE
Thank you for using FixYa. Have a nice day and please remember to give this solution a good rating.
Jun 28, 2008 | D-Link AirPlus DI-524 Wireless Router
D link and Imac
If you don't put in the same wep key you won't be able to connect....take that S out..also not every device can connect to wpa ...use the same key if not able to connect reconfig the wireless settings change the key..,
Jan 10, 2008 | D-Link AirPlus DI-524 Wireless Router
Mac won't recognise network
Based upon the way you worded the message, you were trying to get the Mac working wirelessly? The description of how you were trying to set up your network (SysPref\Net\BuiltInEthernet) is for WIRED connections, not wireless. If you are running OSX and you have a built-in wireless adapter, use System Preferences\Network\Airport choice to set up for wireless connections. If you are trying to use the wire either because you don't have a wireless card or it is not working, check to make sure that the cable is good...maybe hijack the cable that you know works for your PC and test it. Please let me know if I am on the right track to solve the problem.
Jun 12, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
1,335 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
