Question about Nokia 1100
Insert sim is the error message tha the phone prompted when the sim is already inserted
  • 51 Answers
If the phone is locked to a network it wont take another networks SIM.
If you want to use the phone with a differnt network/service provider you need to get it unlocked.
If not maybe the SIM is scratched or broken?
Good Luck :)
Regards,
Sophiee.
Posted on Mar 09, 2008
Why phone saying insert sim card already inserted
If your phone displays an error message saying "Invalid Sim card" then your phone is probably locked.
You can unlock it easily by using an unlock code.You can get this code at low cost from Unlocking4U.com with easy step by step unlocking instructions.
Oct 18, 2013 | Porsche Cars & Trucks
Insert sim card
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
Jul 30, 2013 | Blackberry Curve 8350i
My flip phone displays message "insert SIM" and
Hello.
You need to have a simcard. If you already have one inserted, then remove the simcard from your mobile phone, then reinsert it back. It is usually found behind the battery. If you are still having the same error, then you might need to change your simcard.
Aug 03, 2011 | Samsung Cell Phones
When I turn on my phone I get message: insert SIM card, but my SIM is already in the phone?!
Try inserting another SIM, your current SIM might have a problem. You can try a friend SIM. Hope this will help you. Thanks for using Fixya.
Jul 18, 2010 | Sony Ericsson K700
Sim card promblem
How to correct sim card error / insert sim card
Procedure to follow
Step 1: Check the sim tray or sim seater to see if it it broken, if it is, replace it
Step 2: If the sim seater/tray is not broken, clean the entire terminal.
Step 3: If the sim seater/tray is not directly on the board, trace the broken led and solder it, or you replace the broken led with another sim tray.
Step 4: If it is still not working, change the battery and put a new battery, because a virus infected battery will always give such problem.
Step 5: Finally, if the problem still persist, then check the sim card and replace with another sim card if the former is bad because a bad sim card will always display such message as insert sim card or sim card error.
Take care
May 07, 2010 | Pantech Slate Cell Phone
"Insert SIM card" Prompt message
Hello
To avoid this kind of problem from recurring;
Make sure your Sim card is properly inserted
Make sure you avoid hitting the phone on objects and also avoid dropping the phone because this can make the Sim card shift out of place
Goodluck
Feb 19, 2010 | Sony Ericsson Aino Cell Phone
Need unlock code for sony ericsson z550a for a tmobile SIM
Hi, If you get error message as PIN blocked. Unlock?" You have entered the wrong PIN code too many times. You need to unlock your phone using the PUK (PIN Unlocking Key) code. Your PUK code is provided by your network operator. If you get error message as Insert correct SIM" You have inserted a SIM card that is not supported. Insert correct SIM card, or contact your Service Provider for a SIM unlock code. If you get error message as Phone locked" or "Enter PIN" Your phone is locked and you need to unlock it with your personal PIN. The default PIN is '0000', but you or your network operator may have changed it. I Hope it helped you. Thank you for using ' Fixya ' and have a nice day!!
Nov 18, 2009 | Sony Ericsson Z550A Cellular Phone
Screen says to "Insert SIM", but it is already inserted in phone and has been since phone wasw purchased. I did remove it and put it back in, but it still has same "insert SIM" prompt. Removing battery,...
If it is giving you that message that means it is not detecting the SIM in the slot. You can try removing the SIM and clean it with a soft cloth and reinsert it. You can also try to use any other SIM and make sure if the phone's SIM contact is working properly.
Nov 09, 2009 | LG Xenon GR500 Cell Phone
Says insert sim card when there is one in it
"Insert SIM" message is normally displayed on phones when a SIM card is not inserted on power-on or it does not detect the SIM card inserted.
Likely Causes:
  1. No SIM card inserted or inserted SIM card is damaged
  2. Inserted SIM card not positioned well in such a way as to make contact with the corresponding contact bridges on phone.
  3. Phone locked to a specific network and can only work on other networks when the firmware version is "flashed", that is completely changed to an unlocked version.
  4. The phone might be faulty (try with another good SIM, if you still get thesame message and its not one of the above reasons... it might be a transciever problem or the phone's SIM card slot's pins might be defective).
cheers.
Apr 30, 2009 | Sony Ericsson Walkman® W880i Cellular...
Insert sim card message
i got problem with my phone n-gage,after i turned my n-gage on..itssays "insert sim car"..i already put my sim card inside of it
Mar 01, 2007 | Nokia N-Gage QD Console
Nokia 1100 Logo
42 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
