Back to:
Tags:
Motherboards
Generic problem for all Motherboards
Base code
posted by haunted on Mar 09, 2008
i changed the battery in my au falcon now it comes up base code and it runs terrible
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 11, 2008
Not Rated (0)
JetJedi221
Rank:Master Master
Rating: 84%, 20 votes
You may first have to use the jumper on the motheroard itself to reset the BIOS. It should say EEPROM or BIOS next to it. Remove the jumper and put it on the other pins for 5 seconds, then replace in original spot. Make sure that there is no power to the board as it may turn on when jumper is removed.
Also use electro-stataic precautions.
Good luck
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on base code:
I don't want to Accept this solution
Solution #2
posted on Mar 10, 2008
Not Rated (0)
peping
Rank:Wiz Wiz
Rating: 83%, 48 votes
try to inter to Bios setup,there you select the default settings, means the factory settings save and exit.
Thank You!
Can you Help with these Motherboards problems?
EliteGroup P4M800-M7 Motherboard
Is P4M800-M7 mobo can support the pc333 sdram memory?...
AOpen AK77-600n Motherboard
Need to know which posts to hook the wires to , IE on/off...
Matsonic MS9158EP (DSMTSMS9158EP)...
Je n'ai pas de son apr?s avoir reinstall? mon systeme...
MSI Motherboard
ms-6570e(vi.x) atx mainboard fitted with amd athlon xp...
Intel Motherboard
hi guys n iwant to know that which motherboard should i...
Loading problems.
Repair Service
Find Motherboard Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
