Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
I need a java code
I really need a object oriented java code for an atm machine..its for my Final exams..pls help
I really needy of sourcecode of badmintone game in java
pls send it to my ID "firozdost@yahoo.com"
Posted on Mar 10, 2008
What is strings in java?
Handling character strings in Java is supported through two final
classes: Java String and StringBuffer. The String class implements immutable character strings, which are read-only once the string has been created and initialized, whereas the StringBuffer class implements dynamic character strings. All string literals in Java programs, are implemented as instances of String class. Strings in Java are 16-bit Unicode.
Nov 21, 2012 | Sun Java Programming Language (cdj-275)
I wanna to learn java and oop programming
The Java provides a self-guided introduction to Java programming, starting with the basics and covering all the core concepts you need to know to become a productive Java developer. This series is technical, with plenty of code examples to help you grasp the concepts as we go along. Benchfolks is one of the best place to learn Java,they guide you and helps you too get a job , Benchfolks guide you for java certification training.for more details you can visit this website:http://e-learning.benchfolks.com/online-training-java-certification-courses.html
Sep 03, 2011 | Computers & Internet
I need to write a java code for a one player snakes and ladders game
http://www.scribd.com/doc/31905900/Java-Programming-Creating-a-Snake-and-Ladders-Game-and-Object-oriented-concepts
if you go to the website it will teach you how to do it
Feb 27, 2011 | Sun Java Programming Language (cdj-275)
Why main function is made static in java
Its very easy dear. In java everything is object oriented. You will call a function through an object. Now we are calling the main method without any object as we do not create any object of the class that contains a main method. So call the main method we need to declare main as static methos so its not a part of an object but a class so that mian method can be called without having creating any object of the class.
Regards, polysandy
Jun 27, 2010 | Sun Java Programming Language (cdj-275)
What is the purpose of java
high-level programming language developed by Sun Microsystems. Java was originally called OAK, and was designed for handheld devices and set-top boxes. Oak was unsuccessful so in 1995 Sun changed the name to Java and modified the language to take advantage of the burgeoning World Wide Web. Java is an object-oriented language similar to C++, but simplified to eliminate language features that cause common programming errors. Java source code files (files with a .java extension) are compiled into a format called bytecode (files with a .class extension), which can then be executed by a Java interpreter. Compiled Java code can run on most computers because Java interpreters and runtime environments, known as Java Virtual Machines (VMs), exist for most operating systems, including UNIX, the Macintosh OS, and Windows. Bytecode can also be converted directly into machine language instructions by a just-in-time compiler (JIT). Java is a general purpose programming language with a number of features that make the language well suited for use on the World Wide Web. Small Java applications are called Java applets and can be downloaded from a Web server and run on your computer by a Java-compatible Web browser, such as Netscape Navigator or Microsoft Internet Explorer.
Apr 01, 2010 | Computers & Internet
I need a java source code file that is just like a ATM machine which saves the transactions...for example if you have withdrawn $1000 from your atm account and you have $5000 dollars...it would save the...
/* Program to Find whether number is Prime or Not. */
class PrimeNo{
public static void main(String args[]){
int num = Integer.parseInt(args[0]);
int flag=0;
for(int i=2;i<num;i++){
if(num%i==0)
System.out.println(num+" is not a Prime Number");
flag = 1;
break;
if(flag==0)
System.out.println(num+" is a Prime Number");
May 16, 2009 | Microsoft Windows XP Professional With...
Blue Hat Toy Company ATM - help! No setup instructions!
ok i hit the rest button on the back of the machine and it erased all my memory off of it so i had to reprogram it .If u put 1234 in as a pin # it will open then press balance and hit enter and u can change your pin # there .
Dec 25, 2008 | Blue Microphones Blue Hat Little Shots...
I'm interested to learn more java programming but I do not no wer
I advice you to start from this site:
http://math.hws.edu/javanotes/
and watch this video:
http://www.youtube.com/watch?v=KheL6umdW-s
try googl.com and write:
java programming
Nov 21, 2008 | Computers & Internet
J2SE
Many languages claim to be Object-Oriented. While the
exact definition of the term is highly variable
depending upon who you ask, there are several
qualities that most will agree an Object-Oriented
language should have:
1. Encapsulation/Information Hiding
2. Inheritance
3. Polymorphism/Dynamic Binding
4. All pre-defined types are Objects
5. All operations performed by sending messages to
Objects
6. All user-defined types are Objects
Fair enough...
Java IS by virtue of 1, 2, 3, and 6.
Java IS NOT by virtue of 4 and 5 (not all pre-defined types are Objects, and not all operations are performed by sending messages to Objects).
But since the definition says only that an OOPL should have these things, then Java qualifies.
Next up; given that definition, how would one define "100%"? Exhibiting all those qualities? If that's the case, Java fails the "purity test".
Sep 12, 2008 | Sun Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
178 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
