Question about Sewing Machines
Singer inspiration 4212 "bobbin catch problem"
A brand new singer inspiration 4212... the top thread is moving down correctly into the bobbin shuttle, but does not pick up the bobbin thread as it comes back up again. I'm not new to sewing, my needle size is correct, it's not bent, the machine is threaded correctly, tension is perfect and stitch types are locked in correctly. I've taken off the faceplate to watch as the needle goes down.. to try and see what is going on. It's definitely not catching the bobbin thread and I can't understand why. Bobbin is threaded well. I don't see any bend marks on the shuttle.. this happened after a lightweight piece of fabric got caught in my feed dogs and I had to pull a little bit roughly to get it back out again. I was afraid something got bent, but I can't see any damage. Does anyone know where I can find photos/visuals of what an inspiration 4212 bobbin shuttle normally looks like.. so I can see if mine is damaged? Thanks.
  • 4 Answers
SOURCE: Fabric Guide
The above is a picture of the fabric guide in use; it slides into top portion of your presser foot shank. It can be used in either direction for guiding uniform stitch lines.
Hope that helps! Happy sewing!
Posted on Sep 11, 2008
  • 3 Answers
SOURCE: Not picking up the Bobbin thread
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
Posted on Mar 07, 2009
Mimito7
  • 128 Answers
SOURCE: Singer Simple Shuttle Hook Catching Needle
Sounds to me that your machine is out of time. I recommend you take it to your local repair center.
Posted on May 12, 2009
  • 26 Answers
SOURCE: my bobbin thread is loose while stitching. I have
possibly a scratch or rough spot u cant feel, take the hook out and run your finger around the hook you should feel a rough spot. replace he hppk or sand it lightly
Posted on Aug 22, 2009
  • 255 Answers
SOURCE: Singer 4623 bobbin thread won't catch
Hi! Did you by chance, change your needle? If so, make sure you have the flat side of the needle shaft facing the correct direction. If the needle isn't in all the way or the flat side of the shaft facing the right way, the bobbin thread won't pick up.
Let me know if this helps, ok?
Happy Sewing!
Posted on Feb 10, 2010
Singer Model 5523 runs but doesn't make stitches. Needle is threaded and bobbin is fine. It moves but when I check the stitches there are none. Thread is not breaking.
I am not an expert on anything, least of all sewing machines...
The needle should carry the top thread under the table and make a loop that picks up the bottom thread from the shuttle and it is the interaction between the two threads with equal tension that creates the stitches.
The major activity of a sewing machine takes place under the table and in particular it is the timing of that activity in relation to the needle movements that is essential.
The timing is critical but mostly non-adjustable. I suggest you ensure below the table activity is actually taking place and then revisit the winding of the thread onto the shuttle reel and inserting it into the shuttle...
Sep 01, 2017 | Singer Sewing Machines
Diagram of bobbin casing for singer 1036 creative touch?
Try a brand new needle and verify it is installed correctly. Rethread the machine, top & bottom.
If the machine continues to miss the bobbin thread, most likely the timing is off. Search for sewing machine timing or take it for service.
Singer 1036 parts diagram Google Search
May 25, 2017 | Singer Sewing Machines
Why does'n the needle catch the bobbin thread on Necchi BU Nova
Your hook is moving correctly. Not all machines do a continuous circle. If it's not catching the thread, the timing is off. It's a great machine, and worth every penny to have it serviced.
Feb 27, 2015 | Singer Sewing Machines
Thread tension not working
Bobbin is not inserted to spin the correct direction.
Also, it could be that the bobbin tension isn't correct either.
Feb 02, 2014 | Singer Inspiration 4212 Mechanical Sewing...
Singer sewing machine will not catch bobbin thread to sew
Check the bobbin tension and timing. Please top and bobbin using to new quality threads.
Dec 29, 2013 | Singer Sewing Machines
Bobbin won't spin to allow needle to catch thread
sometimes when you break a needle it can cause the machine to
jump time, the machine would have to be taken to a sewing machine
shop to be checked by the technican
Aug 17, 2012 | Singer Inspiration 4210 Mechanical Sewing...
I cannot get the bobbin thread to catch and pull through the footer wen trying to thread the machine?
Make sure your bobbin is placed in correctly. Thread is counterclockwise as you place bobbin in the metal piece. Pull thread end through sliver in metal piece. Hold on to movable metal latch then lock the bobbin in place. Bobbin should not fall out but is able to rotate. Rotate the wheel on the furthest right of your Singer 1507 machine towards you to move the needle downward. The top thread should then be able to catch and pull up the bobbin thread.
Dec 02, 2010 | Singer 1507
Singer Model 5050 Timing Problem
Actually,timing of needle vs, shuttle is not very easy job several factor you should check on.There is belt ot sometime a shafting with worm gear and helical gear under machine w/c drive the shuttle with the bobbins in timing order,Any one of them is present on the timing adjustment can be done by releasing the belt or the helical gear,besure machine is unplug then set all mechanism on low dead center meaning the needle move to utmost lower position catching this by the shuttle and bobbins at center position.No motion applied if this was set up,engage the belt with pulley and the bobbins link holder tigh allenscrew besure the needle is lower dead center at the center of shullle bobbins catching needle without motion when setting back at original position.If this was made manually move it on handwheel going up and side down the needle gradually if the needle move freely several time and it was catching this by the shuttle hook bobbins.if ok put thread bobbins and upper thread dial tension with the needle.Move machine on handwheel try to catch the bobbins thread,If this so your machine is ready to sew again if problem occurs on alignment repeat adjustment on perpect alignment,besure all parts on upper casing of machine specially two drive gear are in normal alignment.
Mar 15, 2009 | Singer 5050 Mechanical Sewing Machine
Threading problem on Singer Sewing machine Inspiration 4206
This can be caused by incorrect bobbin tension or the bobbin is in backwards. Take out the bobbin and put it in according to the instructions for your Singer. If you still have the same problem try tightening the bobbin tension. Please ask if you have any questions.
Dec 30, 2008 | Singer Inspiration 4206
Singer 6267 self winding bobbin winds around shaft under
I just figured out why my bobbine was winding on shaft instead of on the bobbin. first of all make sure the bobbin is setting up high enough, top of bobbin needs to be a fraction higher then the bobbin shuttle, next check to make sure there are no burrs on the bobbin, then make sure that the thear is catching in the groove (**** in top) of the bobbin. In order to get mine to wind i had to lett the tread go down and then slip the thread in the groove. also remember to leave the pressure foot up do not put it down. let me know if this helps.
Nov 12, 2008 | Sewing Machines
Sewing Machines Logo
316 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
