Jumper pin configuration
I have a SONY PCV-RS500 desktop computor.My primary hard-disk went out & the jumper block is on #4 & #6 pins on it.Should i need to do the same for my 320GB hard disk in replacement of that hard disk? Ray Ward wacft130@hotmail.com
I have a compaq and want to put a second hard drive in it from a dell can it be done
Posted on Aug 25, 2008
  • 34 Answers
Yes if you are adding one more drive or installing a hard drive to your computer u need to set it to primary location if you want to boot from that Hard disk otherwise u can set it to secondry location .
Posted on Mar 09, 2008
How change prymari device?
You can either look into this online manual or follow the instructions given below.
http://support.dell.com/support/edocs/systems/dim4700/en/om/Y69490LRs.pdf
In the case of loading a particular Operating System(OS) from a specific Hard Disk, you can change the boot priority from BIOS (Hope you know to get into BIOS) as shown in the picture
Or if you want to change the physical configuration of your Hard Disks to Master and Slave, then follow these steps.
  1. Open up the side panel of your PC Case.
  2. Disconnect all the wires from both Hard disks.
  3. Look over the labelled top part of each hard disk to know the settings of JUMPER PIN so as to set it as primary(master) or secondary(slave). Please note that if you are using IDE hard disk, this may be enough. But in the case of SATA, inspite of this, you may also require to install RAID Driver after connecting them back into the computer. These drivers can be downloaded from http://www.dell.com/support/drivers/us/en/19/DriversHome/NeedProductSelection (You may require to set up your product manually and download Serial ATA drivers)
  4. (Connect them back, Screw up- if you haven't done it already). Now you may be able to use the required hard disks as primary(master) and secondary(slave).
You can also watch two videos of changing jumper of the hard disk. But be careful while replacing jumper. Any incorrect configuration or jumper setting or damage of pin may cause in device failure or result in damage of your hard disks.If you have any further doubts, feel free to ask me...
Jan 07, 2012 | Dell Dimension 4700 PC Desktop
How to install a western digital 320gb hard drive as master on pcv rx860
You would put the jumper on PINs 5 and 6 as pe image below to have it as master if it is an EIDE (PATA) drive.
Dec 03, 2010 | Sony VAIO Digital Studio PCV-RX860 PC...
How do i configure this hard drive for a 'slave' ?
Hello
Ok, you ill be able to see the jumper configuration on the hard drive itself. Here is an example on what the jumper diagram will look like on a hard drive.
Now, all you need to do is to have a look on your hard dive and see where you need to place the jumper for the slave configuration. Here is what a jumper looks like.
After you have done this, you only need to plug the hard drive into your pc.
Hope this can be of help.
Kind regards
Aug 13, 2010 | Quantum Fireball 15 GB ATA-66 Hard Drive
How to set the audio jumper pins
Do not move any jumper pins when CPU is on,because it can damage the desktop or other components.
The front panel audio jumper block/connector is J8A1 and BIOS configuration jumper block is J8H3.
Apr 02, 2010 | Intel D848PMB Motherboard
Computer fails to boot. searching for either hard
These pins are referred to as "jumpers". Each manufacturer can have their own jumper settings. Each device should have letters indicating which pins correspond to master, slave, or cable select. The best method to insure operation is to use the cable select (CS) jumper setting. Using this setting, the hardware will be automatically configured.
Mar 11, 2010 | Compaq Presario 5000 PC Desktop
New larger hard drive can only be detected as Primary Slave
Floydage, some ribbons are different in the orentation of pin#1. try a differnent cable...but you said that you tried that right.? have you tried to make sure you have the latist BIOS. It could be this paticuler drive have a different bios it self...and yes drive's do have chip's and software in them. If nothing ells just load the OS to that drive anyway and than change the drive letters in windows.
Feb 16, 2010 | Computers & Internet
Replacing a hard drive on Sony PCV-RX550 with a Western Digital 320 gig. With the orig disc as primary master, the wd drive is recognized by the bios as secondary master. But when I remove the original...
if you want to connect two hard drive together then remove the jumper of the primary hard drive and don't touch the setting of the secondary drive then start the system.always make primary drive which have the os.
Jan 26, 2010 | Sony VAIO Digital Studio PCV-RX550 PC...
2 primary ides 2 secondary ides
Ok.... The Primary IDE Should be configured so that your Primary Hard Drive is Set To Master (the jumper pins must be set to the same, each drive has a guide on top or back, or it's written above or below the jumper pins on the back of the drive.
Primary = Hard Disk 0 (Your Main Hard Drive)...This one is to be set as Master and plugged to the END of the IDE Cable....Another Hard Disk / Drive can be connected as Slave (sometimes Cable Select Will Work depending on the motherboard). Remember The Jumper pins on the Drives!
Secondary= One drive must be set as Master, The other as Slave.
That Should do it.
Go into your bios setup screen, go to the boot configuration and set it up so that your boot order goes as follows:
1. Floppy Disc Drive
or........
1. Optical Drive (cd or dvd)
2. Hard Disc 0 (this will be named whatever your Hard drive model number is)
3. Hard Disc 1 (this is the second hard drive, if you want it to be bootable, it's your choice, if not, then set it up to boot off your secondary optical drive,
Make Sure that under IDE devices menu, everything is detected correctly.
Now Save Settings and Exit.
That should do it
Apr 21, 2009 | Computers & Internet
Need master slave configuration
You should have a jumper configuration written somewhere on the front (up) side of the hard Disk ... Look there, or look just around the Pins... Look for M, S, CS (Master, Slave, Cable Select)
Darko, Serbia
Mar 20, 2009 | Western Digital 60GB U100 5400RPM 2MB...
Hi i have a 10.1gb Maxtor model 31024H1 IDE hard drive and i need the jumper setting for slave
slave is NO jumpers at all
(Master) - The vertical jumper over the J50 pins is configuring the drive as a Master. The horizontal jumper over the J48 and J46 pins is in the Storage position.
(Master with CLJ) - The vertical jumper over the J50 pins is configuring the drive as a Master. The vertical jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Slave) - No jumper is required to configure the drive as a Slave. The jumpers over the J48, J46, J44 and J42 positions are both in the storage position.
(Slave with CLJ) - The jumper over the J44 and J42 positions is in the storage position. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Cable Select) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J44 and J42 pins is in the storage position.
(Cable Select with CLJ) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
Oct 13, 2008 | Computers & Internet
Computers & Internet Logo
244 people viewed this question
David Payne
David Payne
