Question about Apple Griffin iMic External Sound System
IMick on Mac Mini
On my Mac Mini, I have connected iMic and then to it, a mike that connects to Audio In. iMic is not able to send audio to IMs like Yahoo or Skype.
Does iMic work with Mac Mini?
Regards,
Kiran
Kiran.Prathapa@gmail.com
Yes, it does work for the mini (I have the same). Drivers seem to be built into the system, so you don't need to download anything with OS X 3.9 or later. Make sure your switch on iMic is switched AWAY from the mike input plug, and you may try plugging your iMic directly into your MacMini (or through a powered 2.0 hub).
Good luck.
Posted on Aug 30, 2008
Where can I plug in a microphone on my PC G4, need it to help in learning a new language?
It depends on which G4 you have. If it's a Quicksilver , there is no Mic in, and you'll need a USB audio adaptor to connect a microphone.
Other G4s, it's on the back, right next to sound out.
Griffin iMic http://www.griffintechnology.com/products/imic
May 03, 2011 | Apple Macintosh Server G4
I have connected to my 2311: HDMI 1: Oppo BDP 83 HDMI 2: Denon DVD 1740 HDMI 3: Apple Mac Mini Issue: The Mac Mini works fine and I have audio and video through the receiver, but for the BD and DVD only...
hi,
You have to check the digital audio assignment of you AVR for HDMI 1 and HDMI 2. There is three options for the digital audio for HDMI 1 and HDMI 2. You can set it as optical ,coaxil, or the HDMI itself. In you receiver the assignment may be in optical input or in coaxial input for the two HDMI inputs.
1. Go to the system setup
2. Select input setup
3.Select input assignment.
4. Select all the three input ,you are using as HDMI
ok
Apr 11, 2011 | Denon AVR-2311 Receiver
How do I turn the audio record level off so that I can record an image without sound?
If you don't want sound and have a mini jack cable, you might be able to plug into the mike jack on the side of the camera.
I have an external 2 input audio mixer on my camera. It connects through that input. If I do not have a mike plugged into my mixer and the mixer is plugged in, I will not get audio. You could also maybe try turning your audio levels all the way down.
Jul 11, 2010 | Canon GL2 Mini DV Digital Camcorder
IMic doesn't work with Logic Pro 9
I had a similar problem, but I managed to solve it; however, I'm using different recording software. The iMic simply does not have built-in input monitoring. Chances are, you are getting an input-signal but it is not being monitored. Try to find some kind of input-monitoring in your recording software. I found a toolbar, in my recording software, called "playback state" that has an option for input-monitoring. Search the help file index, within your software, to find something similar. Here's a quote from iMic's quickstart guide that might be of further assistance:
"In order to hear your turntable or microphone, you will need to enable an important preference in your recording software, usually called “Playthrough.” It may also be called Monitor, Passthrough, Cue, Preview, etc. Enabling such a feature tells the software how to route your audio, and is necessary for monitoring even when not recording."
Moreover, once you've solved this, I recommend using the iMic for both input and output, as latency with onboard-sound-output will likely be intolerable for input monitoring.
Mar 29, 2010 | Apple Griffin iMic External Sound System
I want to connect 2 speakers(left and right) to lcd.how can i?
Please follow the steps below:
Step 1: Connect the two RCA plugs on the Y adapter to the right and left Audio Out jacks on the back of the LCD TV.
Step 2: Insert the mini-plug on the cable attached to the right-channel PC speaker into the mini-plug jack on the Y adapter.
Step 3:Connect the mini-plug on the audio cable attached to the left-channel PC speaker to the mini-plug jack on the back of the right-channel speaker. This completes the PC speaker connections to each other and to the television. The TV sends an audio signal to the right PC speaker, which separates the signal and sends the left-channel stereo information to the other PC speaker.
Step 4:Connect the AC power plug to the back of the right-channel speaker and plug the other end into an electrical outlet.
Step 5:Switch on the speakers and the television to enjoy audio from both the TV's built-in speakers and the external pair of PC speakers.
Regards
BEADHZ
Dec 30, 2009 | LG 37LC7D 37 in. LCD HDTV
Buzzing Noise in Sound Studio
hi, check all cables,clean connections. i have had these kind of problems in the past. also coulb be ground loop!? hope this is helpful.glen
Feb 15, 2009 | Apple Griffin iMic External Sound System
Audio Issues With Sony DCR-TVR900 NTSC
Well, it is not a bad mike connection since you connected another external mike to unit. If it worked before then something bad has happened to your audio electronics causing this anomaly.
Apr 27, 2017 | Sony Handycam DCR-TRV900 Mini DV Digital...
Need Adaptor connect DJ Tech Turntable to Sony Mini Hi Fi MHCRG495
The USB turntable is likely a USB data connection and not a USB audio connection, so you will need to take the audio output from your Mac G4 to your Sony Mini Hi Fi...
You will likely need a stereo mini-plug (3.5mm or 1/8-inch) to stereo RCA plug cable (red and white RCA plugs). This is often referred to as a "stereo Y-cable."
Apr 05, 2008 | Televison & Video
Connecting iMic to G4 iBook
Did u try installing the drivers?Here the link..
http://mac.softpedia.com/get/Drivers/Griffin-iMic-Control.shtml
If it still doesn't work then check if the usb port u have connected it in is functional..u can check this by connecting some other device like scanner, webcam etc., into it..
If it still doesn't work..the the device is probably faulty and u might want to get it replaced..
Nov 18, 2007 | Apple Griffin iMic External Sound System
Apple Griffin iMic External Sound System Logo
178 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
